Bulk Deleting CTL/ITL file from IP Phones
Vysakh Sundar
Dear All
We were  using uplinx tool to delete the CTL/ITL files in bulk from the ip phones during migration from one cluster unfortunately  license got expired and am looking for an alternative way to perform the same
Bulk Certificate management will be the best option.
For itl removal Turn on the Prepare Cluster for Rollback to pre 8.0 on source cluster and then move the phone to the new cluster.
Response Signature
Response Signature
Jonathan Schulenberg
You don’t need to delete the ITL when migrating between clusters.
https://www.cisco.com/c/en/us/support/docs/unified-communications/unified-communications-manager-callmanager/213407-migrate-phones-between-secure-clusters.html
The phones have to be registered to a cluster to do this in bulk with Uplinx or another tool; the commands are sent to CTI Manager which the. Relays them to the phones through RCC which is exempt from the phone SDK and auth URL. Even if a license expires it should not unregister phones, just block changes to the admin UI. And for that, you can reboot the cluster to get write access restored for 24 hours.
