Busy Out a B Channel
dconstantino
Level 4
Level 4
I know I can busy out a Bchannel for MGCP in CCM through the service parameters is there a fast way to busy out Bchannels on the gateway. I need to just test one Bchannel on each of my PRI's so I need to Busy Out 22 of the b channels at a time on each PRI so I can test hunting to the next PRI.
paolo bevilacqua
Busy out on ISDN is not easy as it may seem.
When the call comes, in the setup message is already indicated a channel, either exclusive or preferential. That is, is the switch that decides on which channel the calls lands.
However, certain switches support service messages to allow individual B channel busy out.
Check:
http://cisco.com/en/US/products/ps6441/products_feature_guide09186a0080686068.html
