By pressing the Directory button, the (local directory) is not display
medzeinmaaloum
Good day,
I have a CCME router with some 7945G IP phone, I want access to the (local directory), when I press the Directory button, the IP phone displays (Missed Calls, Received Calls, Placed Calls) it does not display the ( local directory), how can I access to this directory so that I can search for names or extensions.
Best regards,
You have turned off the web server service on your gateway by these commands.
no ip http server
no ip http secure-server
You’ll need to at least have one of these, most likely the one for http, set without the “no”.
Response Signature
12 Replies 12
medzeinmaaloum
when i press the Directory bouton it desplay :
Yes I checked it, this document says that if I press the (Directory Button) the (local directory) will appear, while this is not my case, my case is if I press the (Directory Button) it displays : (Missed Calls, Received Calls, Placed Calls).
Can you please share your running configuration?
Response Signature
Router_Data_Voice#show run
Building configuration...
Current configuration : 5248 bytes
! Last configuration change at 18:36:46 UTC Sun Nov 6 2022
! NVRAM config last updated at 18:36:35 UTC Sun Nov 6 2022
version 15.1
hostname Router_Data_Voice
boot-start-marker
boot-end-marker
no aaa new-model
no ipv6 cef
ip source-route
ip cef
ip dhcp excluded-address 10.40.0.1 10.40.0.10
ip dhcp excluded-address 10.45.0.1 10.45.0.10
ip dhcp pool DATAPOOL
network 10.40.0.0 255.255.255.0
default-router 10.40.0.1
ip dhcp pool VOICEPOOL
network 10.45.0.0 255.255.255.0
default-router 10.45.0.1
option 150 ip 10.45.0.1
voice-card 0
dspfarm
dsp services dspfarm
license udi pid CISCO2921/K9 sn FGL1628137H
license boot module c2900 technology-package uck9
hw-module pvdm 0/0
redundancy
interface Embedded-Service-Engine0/0
no ip address
shutdown
interface GigabitEthernet0/0
no ip address
duplex auto
speed auto
interface GigabitEthernet0/0.40
description this will act as DG for the DATA Vlan = 10.40.0.1
encapsulation dot1Q 40
ip address 10.40.0.1 255.255.255.0
interface GigabitEthernet0/0.41
description this will act as DG for the Management Vlan = 10.41.0.1
encapsulation dot1Q 41
ip address 10.41.0.1 255.255.255.0
interface GigabitEthernet0/0.45
description this will act as DG for the VOICE Vlan = 10.45.0.1
encapsulation dot1Q 45
ip address 10.45.0.1 255.255.255.0
interface GigabitEthernet0/1
no ip address
shutdown
duplex auto
speed auto
interface GigabitEthernet0/2
no ip address
shutdown
duplex auto
speed auto
ip forward-protocol nd
no ip http server
tftp-server flash:apps75.8-3-2-27.sbn
tftp-server flash:cnu75.8-3-2-27.sbn
tftp-server flash:cvm75sccp.8-3-2-27.sbn
tftp-server flash:dsp75.8-3-2-27.sbn
tftp-server flash:jar75sccp.8-3-2-27.sbn
tftp-server flash:SCCP75.8-3-3S.loads
tftp-server flash:term75.default.loads
tftp-server flash:apps45.9-4-2ES26.sbn
tftp-server flash:cnu45.9-4-2ES26.sbn
tftp-server flash:cvm45sccp.9-4-2ES26.sbn
tftp-server flash:dsp45.9-4-2ES26.sbn
tftp-server flash:jar45sccp.9-4-2ES26.sbn
tftp-server flash:SCCP45.9-4-2SR3-1S.loads
tftp-server flash:term45.default.loads
tftp-server flash:term65.default.loads
tftp-server flash:apps37sccp.1-4-5-7.bin
control-plane
mgcp profile default
sccp local GigabitEthernet0/0.45
sccp ccm 10.45.0.1 identifier 1 priority 1 version 7.0
sccp
sccp ccm group 1
associate ccm 1 priority 1
associate profile 1 register CONFERENCE
switchover method immediate
switchback method immediate
dspfarm profile 1 conference
codec g711ulaw
codec g711alaw
codec g729ar8
codec g729abr8
codec g729r8
codec g729br8
maximum sessions 2
associate application SCCP
gatekeeper
shutdown
telephony-service
sdspfarm units 1
sdspfarm transcode sessions 3
sdspfarm tag 1 CONFERENCE
conference hardware
no auto-reg-ephone
max-ephones 50
max-dn 150
ip source-address 10.45.0.1 port 2000
cnf-file location flash:
load 7945 SCCP45.9-4-2SR3-1S
load 7975 SCCP75.8-3-3S
max-conferences 8 gain -6
transfer-system full-consult
create cnf-files version-stamp 7960 Nov 06 2022 16:04:42
ephone-template 1
conference drop-mode creator
softkeys seized Endcall Meetme Redial Cfwdall
ephone-dn 1 dual-line
number 4001
label Reception 1
name Reception-1
ephone-dn 2 dual-line
number 4002
label Reception 2
name Reception-2
ephone-dn 3 dual-line
number 4003
label Conference Station MTRoom
name MTRoom
ephone-dn 4 dual-line
number 4004
label Mohamed Zein Maaloum
name Mohamed-Zein-Maaloum
ephone-dn 5 dual-line
number 4005
label Esma Mohamed T'feil
name Esma-Mohamed-Tfeil
ephone-dn 6 dual-line
number 4006
label Aya Mohamed Maloum
name Aya-Mohamed-Maloum
ephone-dn 7 dual-line
number 4007
label Zein Mohamed Maloum
name Zein-Mohamed-Maloum
ephone-dn 8 dual-line
number 4008
label Sidi Mohamed Maloum
name Sidi-Mohamed-Maloum
ephone-dn 9 octo-line
number 3000 no-reg both
conference meetme
ephone-dn 10 octo-line
number AABB no-reg both
conference ad-hoc
ephone 1
mac-address 203A.07FC.310A
ephone-template 1
type 7975
button 1:1 2:4
ephone 2
mac-address 34BD.C8C7.4DF8
ephone-template 1
type 7975
button 1:2
ephone 3
mac-address 0004.F2F2.70CF
ephone-template 1
username "Conference Station MTRoom"
type 7937
button 1:3
ephone 4
mac-address 203A.0722.D66B
ephone-template 1
username "Mohamed Zein El Maaloum"
type 7945
button 1:4
ephone 5
mac-address 203A.0722.1AB4
type 7945
button 1:5
ephone 6
mac-address 203A.0723.B5F6
type 7945
button 1:6
ephone 7
mac-address 203A.0723.B52A
type 7945
button 1:7
line con 0
line aux 0
line 2
no activation-character
no exec
transport preferred none
transport input all
transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
stopbits 1
line vty 0 4
login
transport input all
scheduler allocate 20000 1000
end
Router_Data_Voice#
I noticed that by pressing the Directory button at the bottom of the displays (Missed Calls, Received Calls, Placed Calls) there is a message saying (Host Not Fiund) this message takes 10 seconds then it will disappear, I don't know if it can help us find the problem.
View the photo
You’ll need to have the web server running on the gateway and configured correctly for CME. That should be part of the documentation shared earlier in another chapter.
Response Signature
Router# configure terminal
Router(config)#telephony-service
Router(config-telephony)# url directories http://10.45.0.1/localdirectory
is that what i have to put?
ip http server
Router(config)# telephony-service
Enters telephony-service configuration mode.
service local-directory
Router(config-telephony)# service local-directory
enables local directory service on IP phones.
Directory entries
directory entry {directory-tag number name name | clear} !!!... Manually add directory entries
Refer the below guide
https://www.cisco.com/c/en/us/support/docs/unified-communications/unified-communications-manager-express/212091-Configure-and-Troubleshoot-Directory-Ser.html
Response Signature
no ip http server
Response Signature
After enabling the http server:
Router_Data_Voice(config)#ip http server
Router_Data_Voice(config)#do write
The problem is solved, the (local directory) is displayed.
View the photo
Thank you very much, you really are an expert.
Glad to hear that and thank you for the kind words.
Response Signature
