06-20-2024 09:27 PM
Dears,
I bought C1121-4P router, IP phone and CME lisence(A-FLEX-EP-CME).
I’d like to activate a CME license for C1121-4P, to use an IP phone system.
I assumed that we can authenticate by the SLR method, like with the ISR4K.
How can I activate my license offline?
Network components
Thank you.
Solved! Go to Solution.
06-25-2024 11:34 PM
I'm no expert on licensing,
but I would say yes, you need a UC license and SIP Trunk licenses too (if you connect to a SIP provider).
But you could create a sample order in CCW and it will recommend you the licenses you need.
06-20-2024 11:49 PM
こんにちは
As you mentioned, SLR is the method for offline devices.
Is it not working? If yes, what's the exact issue?
06-22-2024 10:40 PM
Dear b.winter,
Thank you for your prompt reply.
The ISR1K cannot be authenticated by SLR.
As a result of my research, I found the following site. And the following was written:
"Specific License Reservation (SLR) is supported on Cisco 4000 Series Integrated Services Routers." (1)
So I think there are other ways to authenticate. But I don't know what to do.
Can you lend me your wisdom?
Thank you in advance.
06-23-2024 11:27 PM
Which version is your router?
Maybe you need to upgrade it, before you do the SLR.
06-24-2024 12:20 AM
Dear b.winter,
I’ll show my routers version in the following.
My routers version:
Cisco IOS XE Software, Version 17.06.03a
Cisco IOS Software ISR Software Version 17.6.3a
06-24-2024 04:13 AM
What commands do you enter via CLI?
Do you get any error messages?
A little more info would be very helpful.
06-24-2024 06:10 PM
Dear b.winter,
Thank you for your reply.
I’m sorry I couldn’t give you enough information.
The router is configured via the CLI.
I already have a SA/VA so I can use CSSM(Cisco Smart Software Manager).
But the router can't connect to the Internet.
I have to configure a CME offline.
The default setting is Ipbase only.
The router does not accept the command which is for setting a CME.
It displays an error message when I try to enter the commands.
For example:
voice command, dial command, etc.
Router(config)# voice service voip
voice service voip
% Invalid input detected at ‘^’ marker.
→ Do I need to install any software?
If you want more information, I will show it.
06-24-2024 11:11 PM
You need to activate the "Voice" license first and then reload the router, but this has nothing to do with SLR in the first place.
conf t
license boot level uck9
exit
wr
reload
06-25-2024 10:27 PM
Dear b.winter,
Based on your advice, I tried configuring the router. I was able to enter commands which are VoIP settings.
Thank you very much.
About license,
I’d like to use IP phone system (CME) permanently, so I think I need to authenticate it.
I purchased A-FLEX-EP-CME, but I also need to buy a UC license, Is that right?
06-25-2024 11:34 PM
