11-26-2015 10:21 AM - edited 03-17-2019 05:01 AM
Solved! Go to Solution.
11-26-2015 08:28 PM
Most of the conference issues are because of incorrect region and device pool settings. Please ensure that the region settings between conference bridge and all participants must allow 64 Kpbs bandwidth (G711) if you're using SW CFB else you must be having IOS with relevant dspfarm configured in it.
- Vivek
11-26-2015 12:07 PM
OK, and what have you checked so far??
What CUCM version??
What phone models???
SW CFB?? HW CFB???
11-26-2015 08:21 PM
Hi Jaime,
I use CUCM version 10.5.
The phones models are: 7841, 7861, 8945, 8861.
I have SW CFB.
Aristide
11-26-2015 08:23 PM
OK, first thing I can think of, Codec issues, and also, what else have you checked already???
11-26-2015 08:29 PM
Thanks Jaime, ok I will check so far and I will back to you soon.
11-28-2015 03:59 PM
Thanls Jaime,
It was a codec issue. I have fix it.
Aristide
11-26-2015 04:11 PM
Can you ping it?
11-26-2015 08:19 PM
Hi Dennis,
Yes I can ping it. I can make a call also, but I have call conference issue.
Aristide
11-26-2015 08:28 PM
- Vivek
11-28-2015 03:57 PM
Thanks Vivek,
It works fine now.
