Call Forward All Not going to Mobile Phone
davidgray40
Level 5
Level 5
I have an end user that is using an IPC Softphone.  He also uses Extension Mobility with his Softphone.  He is trying to forward his Primary Line to his cell phone and it in going to his Unity Connection Voice Mail.
Even if I UN-Check all of the VM forwarding and VM profile, the call still goes to the Voice Mail box.
We are running CUCM ver. 10.5.2.10000-5.  Softphone client is the latest Cisco ver.
Has anyone experienced this before?
Jaime Valencia
If you have more than one server you want to make sure replication is working fine.
java
if this helps, please rate
Dennis Mink
check the Call forwarding CSS on the line. if need be change iot into the line's CSS for testing.
Please remember to rate useful posts, by clicking on the stars below.
It is already using the same CSS.  The call never reach the Mobile Phone.  They still got to Unity Connection.
I think you still have the Voicemail option checked or it could be that the Voicemail Pilot and the user's cellphone number somehow overlap.
Could you please post the output from Dialned Number Analyzer?
