Call Forward All (offnet to offnet not working)
mohsin majeed
Level 2
Level 2
Hi dears,
i am facing issue related to Call forward all
- We have SIP (283XXXX) and E1 trunk (494XXXX)
- I am trying CFA on cisco 7911 and providing mobile as destination.
- I am using user profile to login on the phone for SIP and E1 DIDs
- For SIP when dial DID number from my mobile; it show me message "invalid number" on my mobile
- For E1 when i dial DID number from my mobile; it process sometime and say "your call can't be completed as dialed". I can see the logs on gateway for the destination number and matching dial peer also
Note: I give CFA CSS the same i gave to the line. Also "block offnet to offnet" service parameters is "false".
This issue only for offnet to offnet call.
Simple incoming and outgoing call have no problem with SIP or E1.
From the logs
Sent:
INVITE sip:0501029946@10.200.7.157:5060 SIP/2.0
Via: SIP/2.0/UDP 10.66.7.126:5060;branch=z9hG4bK3EF6E20F
Remote-Party-ID: <sip:28300582210218@10.66.7.126>;party=calling;screen=yes;privacy=off
It appears that the calling number "28300582210218" is not part of your DDI.
To resolve this go to your sip trunk>outbound calls>calling party selection>choose: First redirect number (external)..Then reset the trunk, test again and post debug ccsip messages if it doesn't work
Please rate all useful posts
6 Replies 6
Chris Deren
Please provide the "debug ccsip messages" and "debug isdn q931"
Also, are you using Local Route group in your environment, if so ensure the ingress GW/trunk has DP with proper LRG defined.
Thanks for reply Deren,
I am not using LRG at all
Let me visit the site again, i will post debugs soon.
You can see ccsip debugs are attached also the route pattern
For E1 trunk there is no "debug isdn q931" command availabe on the gateway. Please suggest which other debug i can send you.
From the logs
Sent:
Great stuff dear,
CFA issue resolved on SIP trunk by selecting "First redirect number (external)" under SIP trunk
and on E1 it is resolved by selecting "First redirect number" under Gateway
I hope this project will be closed now. I can sleep well today
You help people, God will help you.
Thank you sooooooooo much
I say Amen to your prayers. Thank you
