Bookmark
Subscribe
9919
Call forward busy internal/external - forward to DN not working
Dave Phillips
I have several users DN's set up to have call forwarded to another DN when they are on the phone (busy).  We have this second DN listed as a second line on their phone, as well as their assistants.  Each user has their own secondary DN.  The idea is, if the user recieves a call while he/she is on the phone it forwards to that second number and his/her assistant can answer if needed.
It is set up under Call Forward and Call Pickup Settings by entering the secondary DN in the destination field instead of checking the VM box.  Calling search spaces are the same for all #'s.
This was originally set up before I started at the company and it has worked for years.  It was recenty brought to my attention that it no longer works, and after doing some testing it does not.
The only thing that has changed is we upgraded from CUCM 6.x to 8.6.2 about 5 months ago.  I do not know if this broke after the upgrade or later on.
Any ideas as to what I am missing to check?  I realize I could probably set this up using a hunt group but seems a bit overly complicated for this simple scenario.
Hi Dave,
I think the simplest thing to do would be to remove the
DN from the phone or remove the phone completely, then go
to Call Routing > Route Plan Report > Unassigned DN's and
remove the DN in question. Then reset up the number/phone etc.
and retest
It certainly sounds like there is some remnant reference where the
DN has the Busy Trigger set @ something 2 or greater.
Cheers!
Rob
"Celebration it's around us, every nations, all around us.
Singin' forever young, singin' songs underneath that sun" - K'naan
7 Replies 7
acampbell
Dave,
On the DN page for the users phone primary line.
Check that the max number of calls = 2
and that the busy trigger =1
Alex.
Please rate useful posts.
Regards, Alex. Please rate useful posts.
Dave Phillips
Max calls is 4 and busy is 1. Forgot mention the call will act like a RNA. Rings for caller about 4 times then goes to users vmail.
Is the secondary line unique and in a common internal partition? Nothing tricky configured such as using the exact same extension in different partitions, etc?
If they primary line is busy and a caller rings in what do they get?
Can other users ring the secondary line directly?
Just to test, does call forward no answer work to another phone extension not configured on the same phone?
Let me know how you go.
Heath
Please rate helpful posts
Nothing trickey in the configs at all.  Pretty simple install
I think I have narrowed it down to a problem with the DN.
  • If I take another DN and forward busy to the same DN as the problem DN is set to forward to, it works
  • If I take the problem DN and forward busy to a different DN it does no work
  • If I take another DN and forward busy to the same DN mentioned in the previous step, it works.
I have opened a ticket with TAC since I am not seeing anything wrong in the configs..
Hi Dave,
and retest
Cheers!
Rob
Thanks Rob, that fixed it.  It is also what TAC wanted me to try.
I was trying to avoid this since it happens to be DN of a VVIP at the company and his DN is on many phones.......
Hey Dave,
Nice work here!
If you ever see this behavior again, have a very close look at each and every
line appearance of the DN in question. I've had the same thing happen here
and it turned out that just one line appearance had the Max call/Busy trigger
set @ 4/2 and it messed everything up
Cheers!
Rob
