12-06-2012 12:15 AM - edited 03-16-2019 02:34 PM
12-06-2012 04:37 AM
MoH is provided through the IP Voice Media Services Application (IPVMSA). You would need to active the service under Unified Serviciability then include the MoH server (Media Resources) in the phone/gateways's MRGL. CUCM has a pre-loaded audio file but you can upload others.
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/srnd/9x/media.html#wp1153848
Please remember to rate helpful responses and identify helpful or correct answers.
12-06-2012 05:10 AM
Also, if you have more than one MOH server, make sure to upload the files to all of them.
And if using more codecs than G711, to enable them under IPVMS service parameters.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
