ā07-27-2011 08:03 AM - edited ā03-16-2019 06:09 AM
Hi ,
Can any one confirm if call forward all will not work from line 2 from phone in CUCM version: 8.5.1.11900-21 also and only the way to of call forward all is still ccmuser web login and setting call forward.
Brajesh.
Solved! Go to Solution.
ā07-27-2011 08:14 AM
Yes, that's the expected behavior.
You can only CFA the primary line.
You might want to look at this:
http://www.myvoipsource.org/open-source-tools/ip-phone-callforwarder/
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
