Call forwarding not working ( Vodafone Germany)
colcha
Beginner
Beginner
We have a Cisco Model ISR4321/K9 router with Cisco IOS XE Software Version 16.09.04
The problem occurs when we make a call forward to an external number.
The call made by User A to the destination User B (user B has activated a call forwarding to another external number User C)
User C answers the call, user C does not hear anything, User A does not hear anything either, but after 18 seconds the call closes automatically by itself.
User A -->+49xxxxxxx90 ...incoming call
User B--> +49xxxxxxx55 --> call forward to  User C
User C--> +49xxxxxxx30 .....Extern number ( external forwarding is configured on the router)
voice service voip
no notify redirect ip2ip
address-hiding
allow-connections sip to sip
no supplementary-service sip moved-temporarily
no supplementary-service sip refer
fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback pass-through g711alaw h323
voice register global
mode cme
source-address 172.20.XXX.XX port 5060
max-dn 10
auto-register
voice register dn 2
number +49xxxxxx55
call-forward b2bua unregistered +49xxxxxx30
Can someone help me to solve this problem
BR ,
Anibal
3 Accepted Solutions
b.winter
VIP Advisor VIP Advisor
VIP Advisor
First of all: If you have CME and SIP Trunk on the same router, then you must use tenant configuration. Check out the cisco docs and also Cisco forums threads, there are a lot of how to configure tenants on the router.
Second: Without the full config and a debug of the call, nobody will be able to help you. So please provide both.
colcha
Beginner
Beginner
Hi All ,
Thank you very much for your help, I solved the problem myself.
*Vodafone Provider*
Router Cisco --->
Router> enable
Router# configure terminal
Router(config)# voice service voip
Router(config-voi-serv)#notify redirect ip2ip
Router(config-voi-serv)#supplementary-service sip refer
Router(config-voi-serv)# supplementary-service sip moved-temporarily
Router(config-voi-serv)# exit
BR,
Anibal
Hi Roger ,
I have configured the external forwarding in the Cisco Router.
Example :
mode cme
max-dn 10
auto-register
voice register dn 2
number +49xxxxxxxx
call-forward b2bua unregistered +49xxxxxxxx
It is very true that I can do the forwarding from the PBX, but in my case I do it from the GW
BR,
Anibal
20 Replies 20
b.winter
VIP Advisor
Hi winter,
debug of the call   =
000589: Jan 30 09:10:10.316: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
INVITE sip:+49xxxxxxx55@stapad.ngn.vodafone.de;user=phone SIP/2.0
Via: SIP/2.0/TCP 2.207.165.116:5060;branch=z9hxxxxx7b10.1
To: <sip:+49xxxxxxx55@hansx001.ngn.vodafone.de;user=phone>
From: <sip:+49xxxxxxx90@telekom.de;user=phone>;tag=SD5r6ec01-c5f923a9
Call-ID: SDxxxxxxx0
CSeq: 1 INVITE
Max-Forwards: 59
Contact: <sip:+49xxxxxxx90@2.207.165.116:5060;transport=tcp>
Date: Mon, 30 Jan 2023 10:10:10 GMT
Allow: INVITE, ACK, PRACK, CANCEL, BYE, OPTIONS, MESSAGE, NOTIFY, UPDATE, REGISTER, INFO, REFER, SUBSCRIBE
Supported: resource-priority,timer,100rel
P-Asserted-Identity: <sip:+49xxxxxx90@telekom.de;user=phone>
P-Asserted-Identity: <tel:+49xxxxxxx90>
Session-Expires: 1810;refresher=uac
Min-SE: 600
Accept: application/sdp
P-Early-Media: supported
Content-Type: application/sdp
Content-Length: 172
v=0
o=- 0 0 IN IP4 2.207.165.116
s=IMSS
c=IN IP4 2.207.165.116
t=0 0
m=audio 29414 RTP/AVP 8 97
b=AS:80
a=rtpmap:97 telephone-event/8000
a=ptime:20
a=maxptime:30
000590: Jan 30 09:10:10.322: //11758/BB45D80BBE18/SIP/Msg/ccsipDisplayMsg:
Sent:
INVITE sip:+49xxxxxx30@2.207.165.116:5060 SIP/2.0
Via: SIP/2.0/UDP 145.253.139.26:5060;branch=z9xxxxx2E
From: <sip:+49xxxxxxx90@145.253.139.26>;tag=12F7B813-1B9D
To: <sip:+49xxxxxxx30@2.207.165.116>
Call-ID: BBxxxxF@145.253.139.26
Supported: 100rel,timer,resource-priority,replaces,sdp-anat
Min-SE: 600
Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, INFO, REGISTER
CSeq: 101 INVITE
Timestamp: 1675069810
Contact: <sip:+49xxxxxxx90@145.253.139.26:5060>
Expires: 180
Allow-Events: telephone-event
Max-Forwards: 58
P-Preferred-Identity: <sip:+49xxxxxxx65@145.253.139.26>
Content-Disposition: session;handling=required
Content-Length: 226
v=0
o=- 7795 7427 IN IP4 145.253.139.26
s=SIP Call
c=IN IP4 145.253.139.26
t=0 0
m=audio 10050 RTP/AVP 8 101
a=rtpmap:8 PCMA/8000
a=rtpmap:101 telephone-event/8000
a=fmtp:101 0-15
a=ptime:20
000591: Jan 30 09:10:10.323: //11757/BB4562A0BE13/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
Via: SIP/2.0/TCP 2.207.165.116:5060;branch=z9hG4bK67gvn120b8vhd8fe7b10.1
Call-ID: SDxxxxxxE0
CSeq: 1 INVITE
Content-Length: 0
000592: Jan 30 09:10:10.342: //11758/BB45D80BBE18/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 100 Trying
Via: SIP/2.0/UDP 145.253.139.26:5060;branch=z9hG4bK1C81152E
From: <sip:+49xxxxxx90@145.253.139.26>;tag=12F7B813-1B9D
To: <sip:+49xxxxxxx030@2.207.165.116>
Call-ID: BBxxxxxF@145.253.139.26
CSeq: 101 INVITE
Content-Length: 0
000593: Jan 30 09:10:11.118: //11758/BB45D80BBE18/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
From: <sip:+49xxxxxxx90@145.253.139.26>;tag=12Fxxxxx9D
To: <sip:+49xxxxxx30@2.207.165.116>;tag=SDviupa99-f7xxxxxx0000
Call-ID: BBxxxx2F@145.253.139.26
CSeq: 101 INVITE
Require: timer
Contact: <sip:+49xxxxxxxxx30@2.207.165.116:5060;transport=udp>
Content-Length: 168
v=0
o=- 0 7859801 IN IP4 2.207.165.116
s=IMSS
t=0 0
m=audio 27718 RTP/AVP 8 101
a=sendrecv
a=ptime:20
000594: Jan 30 09:10:11.121: //11758/BB45D80BBE18/SIP/Msg/ccsipDisplayMsg:
Sent:
ACK sip:+49xxxxxxxx30@2.207.165.116:5060;transport=udp SIP/2.0
Via: SIP/2.0/UDP 145.253.139.26:5060;branch=z9hxxxxx6
To: <sip:+49xxxxxxxx30@2.207.165.116>;tag=SDviupa99-fxxxxx0-0000
Call-ID: BBxxxxxx2F@145.253.139.26
Max-Forwards: 70
CSeq: 101 ACK
Content-Length: 0
000595: Jan 30 09:10:11.124: //11757/BB4562A0BE13/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
Via: SIP/2.0/TCP 2.207.165.116:5060;branch=z9xxxx10.1
From: <sip:+49xxxxxxxx90@telekom.de;user=phone>;tag=SDxxxxxa9
To: <sip:+49xxxxxxx55@hansx001.ngn.vodafone.de;user=phone>;tag=12F7BB33-CCC
Call-ID: SDxxxxx0E0
CSeq: 1 INVITE
P-Preferred-Identity: <sip:+49xxxxxxxx65@145.253.139.26>
Contact: <sip:+49xxxxxxx30@145.253.139.26:5060;transport=tcp>
Supported: replaces
Supported: sdp-anat
Require: timer
Supported: timer
Content-Length: 223
v=0
o=- 1353 4293 IN IP4 145.253.139.26
s=SIP Call
t=0 0
m=audio 10048 RTP/AVP 8 97
a=fmtp:97 0-15
a=ptime:20
000596: Jan 30 09:10:11.148: //11757/BB4562A0BE13/SIP/Msg/ccsipDisplayMsg:
Received:
ACK sip:+49xxxxxxxx30@145.253.139.26:5060;transport=tcp SIP/2.0
Via: SIP/2.0/TCP 2.207.165.116:5060;branch=z9hxxxx0.1
To: <sip:+49xxxxxxxx55@hansx001.ngn.vodafone.de;user=phone>;tag=12xxx
From: <sip:+49xxxxxxxx90@telekom.de;user=phone>;tag=SD5r6ec01-c5f923a9
Call-ID: SDxxxx
CSeq: 1 ACK
Max-Forwards: 59
Content-Length: 0
000597: Jan 30 09:10:11.892: //11758/BB45D80BBE18/SIP/Msg/ccsipDisplayMsg:
Received:
INVITE sip:+49xxxxxxxx90@145.253.139.26:5060 SIP/2.0
Via: SIP/2.0/UDP 2.207.165.116:5060;branch=z9hxxxxj1.1
To: <sip:016xxxxxxxx90@145.253.139.26>;tag=12F7B813-1B9D
From: <sip:+49xxxxxxxxx30@2.207.165.116>;tag=SDxxxx-0000
Call-ID: BBxxxx53.139.26
CSeq: 102 INVITE
Max-Forwards: 69
Session-Expires: 1810;refresher=uas
Min-SE: 600
Content-Length: 181
v=0
o=- 0 7859802 IN IP4 2.207.165.116
s=IMSS
t=0 0
a=X-UPSPEED
m=audio 27718 RTP/AVP 8 106
a=rtpmap:106 telephone-event/8000
a=sendrecv
a=ptime:20
000598: Jan 30 09:10:11.896: //11757/BB4562A0BE13/SIP/Msg/ccsipDisplayMsg:
Sent:
INVITE sip:+49xxxxxxxxx90@2.207.165.116:5060;transport=tcp SIP/2.0
Via: SIP/2.0/TCP 145.253.139.26:5060;branch=z9xxxx
From: <sip:+49xxxxxxxx55@hansx001.ngn.vodafone.de;user=phone>;tag=12xxx
To: <sip:+49xxxxxxx90@telekom.de;user=phone>;tag=SD5r6ec01-c5f923a9
Call-ID: SDxxx
Min-SE: 600
CSeq: 101 INVITE
Max-Forwards: 70
Timestamp: 1675069811
Contact: <sip:+49xxxxxxxx55@145.253.139.26:5060;transport=tcp>
Expires: 180
Content-Length: 223
v=0
s=SIP Call
t=0 0
a=fmtp:97 0-15
a=ptime:20
000599: Jan 30 09:10:11.898: //11758/BB45D80BBE18/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
Via: SIP/2.0/UDP 2.207.165.116:5060;branch=z9hxxxj1.1
From: <sip:+49xxxxxxxxxxx30@2.207.165.116>;tag=SDxxx
To: <sip:+49xxxxxxxxxx90@145.253.139.26>;tag=12F7B813-1B9D
Call-ID: BBxxx9.26
CSeq: 102 INVITE
Content-Length: 0
000600: Jan 30 09:10:11.934: //11757/BB4562A0BE13/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
To: <sip:+49xxxxxxxx90@telekom.de;user=phone>;tag=SD5r6ec01-c5f923a9
Call-ID: SDxxx
CSeq: 101 INVITE
Contact: <sip:+49xxxxxxxx90@2.207.165.116:5060;transport=tcp>
Content-Length: 172
v=0
s=IMSS
t=0 0
b=AS:80
a=ptime:20
a=maxptime:30
000601: Jan 30 09:10:11.938: //11758/BB45D80BBE18/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
Via: SIP/2.0/UDP 2.207.165.116:5060;branch=z9xxx.1
From: <sip:+49xxxxxxxx30@2.207.165.116>;tag=SDviupa99-f79b94f8-0014-0134-0000-0000
To: <sip:+49xxxxxxxx90@145.253.139.26>;tag=12Fxx
Call-ID: BBxxx
CSeq: 102 INVITE
P-Preferred-Identity: <sip:+49xxxxx65@145.253.139.26>
Contact: <sip:+49xxxxxxxx90@145.253.139.26:5060>
Supported: replaces
Supported: sdp-anat
Require: timer
Supported: timer
Content-Length: 226
v=0
o=- 7795 7428 IN IP4 145.253.139.26
s=SIP Call
t=0 0
m=audio 10050 RTP/AVP 8 106
a=fmtp:106 0-15
a=ptime:20
000602: Jan 30 09:10:11.940: //11757/BB4562A0BE13/SIP/Msg/ccsipDisplayMsg:
Sent:
ACK sip:+49xxxxxxx90@2.207.165.116:5060;transport=tcp SIP/2.0
Via: SIP/2.0/TCP 145.253.139.26:5060;branch=z9hxxx
From: <sip:+49xxxxxxxxx55@hansx001.ngn.vodafone.de;user=phone>;tag=12xx
To: <sip:+49xxxxxxxxx90@telekom.de;user=phone>;tag=SD5r6ec01-c5f923a9
Call-ID: SDxxx
Max-Forwards: 70
CSeq: 101 ACK
Content-Length: 0
000603: Jan 30 09:10:11.963: //11758/BB45D80BBE18/SIP/Msg/ccsipDisplayMsg:
Received:
ACK sip:+49xxxxxxxx90@145.253.139.26:5060 SIP/2.0
To: <sip:0xxxxxxxxxx90@145.253.139.26>;tag=12F7B813-1B9D
From: <sip:+49xxxxxxxx30@2.207.165.116>;tag=SDviupa99-fxxx
Call-ID: BBxxx
CSeq: 102 ACK
Max-Forwards: 69
Content-Length: 0
000604: Jan 30 09:10:30.022: //11757/BB4562A0BE13/SIP/Msg/ccsipDisplayMsg:
Received:
BYE sip:+49xxxxxxx55@145.253.139.26:5060;transport=tcp SIP/2.0
Via: SIP/2.0/TCP 2.207.165.116:5060;branch=z9hxxx1
To: <sip:+49xxxxxxx55@hansx001.ngn.vodafone.de;user=phone>;tag=12xxx
Call-ID: SDxxx
CSeq: 2 BYE
Max-Forwards: 69
Reason: Q.850 ;cause=16 ;text="2"
Content-Length: 0
000605: Jan 30 09:10:30.026: //11757/BB4562A0BE13/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
From: <sip:+49xxxxxxx90@telekom.de;user=phone>;tag=SDxxx
To: <sip:+49xxxxxxxxx55@hansx001.ngn.vodafone.de;user=phone>;tag=12F7BB33-CCC
Call-ID: SD5xxx
CSeq: 2 BYE
Reason: Q.850;cause=16
Content-Length: 0
000606: Jan 30 09:10:30.026: //11758/BB45D80BBE18/SIP/Msg/ccsipDisplayMsg:
Sent:
BYE sip:+49xxxxxxxxx30@2.207.165.116:5060;transport=udp SIP/2.0
From: <sip:+49xxxxxxxxxx090@145.253.139.26>;tag=12F7B813-1B9D
To: <sip:+49xxxxxxxxx30@2.207.165.116>;tag=SDxxx
Call-ID: BBxxx
Max-Forwards: 70
Timestamp: 1675069830
CSeq: 102 BYE
Content-Length: 0
000607: Jan 30 09:10:30.049: //11758/BB45D80BBE18/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
From: <sip:+49xxxxxxxxx90@145.253.139.26>;tag=12F7B813-1B9D
To: <sip:+49xxxxxxxxx30@2.207.165.116>;tag=SDviupaxxx0
Call-ID: BB4xxx
CSeq: 102 BYE
Contact: <sip:+49xxxxxxx30@2.207.165.116:5060;transport=udp>
Content-Length: 0
colcha
Beginner
Beginner
OSTAPB0421#show running-config | section voice register
mode cme
source-address 172.XX.XXX.XX port 5060
max-dn 10
auto-register
voice register dn 2
number +49xxxxx55
colcha
Beginner
Beginner
For security reasons I can't upload the  config file complet . If you need any additional information from the config file, I can upload it.
voice service voip
address-hiding
h323
call service stop forced
sip
bind control source-interface GigabitEthernet0/0/0
bind media source-interface GigabitEthernet0/0/0
min-se 120
registrar server expires max 600 min 60asserted-id ppi
conn-reuse
source filter
privacy-policy passthru
sip-profiles inbound
BR ,
Anibal
b.winter
VIP Advisor
Then its hard to help you. You are even stripping numbers and parameters in the debug ... What is the exact scenario? You wrote something about user A calls B, and B forwards to C (external).
But in the debug, it seems the user A is also an external. If yes, your problem is an old know problem.
What about my point 1?
Hi winter,
Point 1
We only use the cisco router as a gateway that connects to the Vodafone provider, with a NIM-VA-B  " Vdsl2/adsloISDN" (NIM 2) Board , where the additional router has a 1MFT T1/E1 card that connects directly to a PBX.
But why do you have CME config on your router then?
because we monitor the states of the routers PRTG, we access via remote (VPN) for configuration, to back up the system configuration files, etc.
As I said before we do not have Cisco IP phones
I think this graph is better explained
Not going into detail about your setup or config, because this is not a good one. There are configuration templates on how to configure Cisco CUBE for Vodafone Germany.
But as already written, the problem of "no audio when external to external forward" is very known in Germany.
The problem is the SIP platform of Vodafone (and other providers like Telekom, ...).
They have the characteristica, that the platform only starts sending RTP packets, when it first receives RTP packets.
But in the your scenario the both call endpoints are the platform itself, so platform waits on itself, to start sending packets --> Therefore no audio.
Already explained here:
https://community.cisco.com/t5/unified-communications-infrastructure/cube-config-sip-trunk-to-deutsche-telekom/m-p/4447706/highlight/true#M167984
colcha
Beginner
Beginner
Hallo ,
As can be seen in the graph, the call forwarding is being carried out in the Cisco Router
Vodafone---GW2 (Router Cisco)  --- Pbx
The call forwarding is done in the PBX, not in the gateway. If you don’t register any Cisco phones and or 3:rd party devices to the gateway you don’t need CME.
Response Signature
Hi Roger,
Exactly
The cisco router can do external forwarding, as long as there is an external line provider in the configured router
BR,
Anibal
I'm not saying that the router can not handle the call, just that the call forwarding as such is not set in it, that would be done in the PBX. So your call path would be something along with this.
Calling party (A) - > PSTN -> GW -> PBX -> Called party (B) that has CFA set to C (call is actually not going to this entity, it is just a logical step in the PBX) -> PBX -> GW -> PSTN -> Called party (C)
As you can see the GW is just passing the call from one entity to another, it does not set the CFA, it acts on called number, either B or C, as received from the PSTN and/or PBX.
Response Signature
Recognize Your Peers
