03-01-2012 06:42 AM - edited 03-16-2019 09:53 AM
Is not working. I want caller to be able to dial an extension from a call handler when that extension is not associated with an end user / Unity VM. I have this working for another site but may have forgotten a step when setting up for this site. At this point, I have checked the check box "Allow Transfers to Number Not Associated w/ Users or Call Handlers" under the Call Handler Edit Greeting.
Running CM and Unity Connection 8.5.
Solved! Go to Solution.
03-01-2012 06:51 AM
03-01-2012 06:50 AM
Hi Troy,
You will want to look at the Default System Transfer Restriction table
and compare the two CUC systems
Cheers!
Rob
03-01-2012 06:51 AM
03-01-2012 07:00 AM
Yes! I forgot about the Restriction Tables. I added a new one for the sites extension block and were working. thanks!!
