02-11-2020 10:38 AM
I am needing to change the message heard when an call comes to one of my schools. It is using a call handler. Ultimate goal is to change the pin for this handler or vm box or ...
The extension is 3970. If I press my vm button on my phone and enter *3970, I begin hearing the message I want to edit. However, I cannot find that user in Unity. Where do I go to change the pin for the call handler at x3970?
02-11-2020 12:02 PM
02-11-2020 12:12 PM
02-11-2020 01:01 PM
Just an FYI, in updated versions of Unity, the play/record module is changed to work in almost all browsers.
02-11-2020 12:16 PM
Is there another way to record the message other than via the Java applet in the UI?
02-11-2020 01:00 PM
You can check in call handlers as well as users and search by extension 3970.
It's possible it is listed as an alternate extension on a user, so when you do the search, hit the "limit search to" dropdown box and change it to partition, and then select your partition, then select the dial that says "Display Primary and Alternate Extensions in Selected Partition"
If this is helpful, please rate this post as helpful.
