Call Handler in CUC
I have configured a call handler into unity and i have one issue
If i dial directly the number for the call handler everything its ok.Its going to the call hanlder , its play teh recording prompt that i have etc
But if i forward my extension to the call handler number then its not hearing the call hanlder prompt but the default greeting like **Hello cisco unity connection messages etc**
Sure i am missing something
Please rate all useful posts
Chrysostomos
""The Most Successful People Are Those Who Are Good At Plan B""
Please rate all useful posts Regards Chrysostomos ""The Most Successful People Are Those Who Are Good At Plan B""
2 Accepted Solutions
You can either change unity connection to use the last redirecting number or configure a routing rule, and configure it such that when the forwarding station is the extension of the call handler, send the call to the call handler
Rob Huffman
Hi Chrysostomos,
Hope all is well my friend
Here's another alternative to the great tips from my buddy Deji (+5 "D")
If  you look in CUCM Admin there is an area called Voicemail Profile. Use  this in conjunction with a Call Handler (we'll use 1111 for the Call Handler) created in  Unity Connection that has the greeting that you desire.
Feature  > Voicemail > Voicemail Profile. This area allows you to  configure a Profile that points to a specific DN/Voicemail Box. When you  apply this Profile to DN's any call that forwards to the Voicemail  System from these DN's will be directed to the specified 1111 Call  Handler.
For  example: you want all calls that go to DN 2222 (user without Voicemail)  and then forwards to VM to go to the new 1111 Call Handler greeting info.
You  would create a Profile in CUCM called "1111 Transfer or whatever" which  points to DN 1111 (**Voicemail Box Mask = 1111). Apply this new profile  to 2222 (under DN config page VM-Profile) and when calls route through  2222 and forward to voicemail they will recieve the 1111 Transfer  Greeting etc.
This profile can be applied to as many phones as needed
Hope this makes sense!
Cheers!
Rob
"Your life is worth much more than gold."
- Bob Marley
6 Replies 6
Hi To all
Update:
When i dial the call handler number everything looks ok
When i go to one directory line anf forward all the calls to the call handler number then i hear the name of the user
Examle : Chrysostomos is not available pls leave your message after the tone
Its not play the prompt of call handler etc
Do you have any idea?
Chrysostomos
Great Aok
Thank you
Rob Huffman
Hi Chrysostomos,
Cheers!
Rob
- Bob Marley
Hi Rob
Long time to speak
i am very well and i hope and you
Thank you for the infos.Are very useful
Five points also to you
Chrysostomos
Rob (+5)! Nice one..Like they say there are many ways to skin a cat
"opportunity is a haughty goddess who waste no time with those who are unprepared"
