Call Handler transfer to a greeting?
snared04drummer
I have an existing Call Handler configured for a department in my company.  The head of that department would like to create a temporary greeting message for the holidays that, when a number is dialed from the original call tree (3 in this case), the holiday hours are relayed to the caller in a message.  I know I could set the schedule and do it that way, but he wants the caller to be able to have that information relayed to them via Caller Input.
Thus far I have tried to create a second Call Handler with that message recorded to it, and have it transfer to the new Call Handler when 3 is pressed on the original Call Handler, but it surrounds the greeting with the typical:
"Sorry <Plays greeting> is not available, if you'd like to leave a message... etc"
Obviously that's not desirable.  Can someone point me towards the best way to accomplish what I'm trying to do?
Jaime Valencia
That's because you recorded a recorded name, not a greeting. It should be "Sorry John Doe is not available..." where John Doe is the recorded name.
Delete that call handler, and re-create, BUT this time actually record what you want them to hear under GREETINGS.
java
if this helps, please rate
Chris Deren
So you have the following:
Main_CH - caller input 3 --> Holiday_Message_CH?
On Holiday_Message_CH, is transfer rule set to go to StandardGreeing? How is the Standard Greeting configured, is it set to play personal recording?
Jaime Valencia
java
