Call into an MGCP controlled FXO port not connecting
my setup is
PSTN --- GW --- CUCM --- 6921 phone
when we call from the PSTN then call rings and shows connected on the PSTN phone after about 10 sec the call disconnects with fast busy but the 4 digit plar does not ring at all, outgoing calls are working fine. Need help in resolving this issue
Shabbar
11 Replies 11
yahsiel2004
Level 7
Level 7
Please post your GW configuration and describe your CUCM setup.
Yosh
HTH Regards, Yosh
Attached the gw config what do you mean by cucm setup
How you have your FXO configured in CUCM. Can you post a "debug isdn q931"?
Yosh
HTH Regards, Yosh
FXO is configured as loop start as below, cannot run the debug isdn
R_SCI_KQ#debug isdn q931
% Invalid input detected at '^' marker.
RegistrationRegistered with Cisco Unified Communications Manager 192.168.0.26
IP Address192.168.100.6
AALN/S0/SU0/0@R_SCI_KQ.sciafrica.net
Required Field
Required Field
Required Field
Required Field
I'm sorry I was thinking about something else when I asked for the "debug isdn q931" you don't have any PRIs.
Yosh
HTH Regards, Yosh
Hi.
Being an FXO it supposed to be connected to an analogue line not ISDN :)
a debug vpm all would be useful.
Please activate it , make an inbound call an please post the result
Carlo
Please rate all helpful posts "The more you help the more you learn"
Output of debug vpm all attached
Think the file did not copy completely
Hi Shabbar.
On the vg remove plar config and fill the attendant dn field on port configuration on CUCM with desired destination.
Carlo
Removed the plar but still the same behaviour
Hi.
Did you configured the attendant DN on port configuration page on CUCM?
If yes, can you check the incoming CSS on the same configuration page?
Let me know
Carlo
