Call Manager Alert Description and Default Configuration
Abhishek Singh
Hi All,
Is there any specific pre-hand cisco documentation which can be handy to check alerts -- if you encounter them on the ccm . I currently have the following documentation, is it the only specific documentation or are there more of the same type. Appreciate some help on this. Thanks.
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/service/7_0_1/rtmt_master/rtalcm.pdf
Whatever level you reach getting better never stops -- Sachin Tendulkar
8 Replies 8
Aman Soi
Hi Abhishek,
I was trying to find out but all findings point to same URL.
The URL which u have shared is the best which is available on Cisco site for finding description on ALerts.
Let others share if they can find out.
regds,
aman
@ Aman ::  This document explains the Alerts and the reason for the same -- need to know if there is something which provides -- solution or configuration settings which helps in resolving or changing the alert settings to a permissible value.
Appreciate response on this.
-Abhishek Singh
I was checking the documentation on how can we remove these alerts -- as in what steps in Rtmt can be implemented -- if there is something of that sort to help out -- that would be great.
Abhishek,
Allow me to share with you another document which explains most of the RTMT alerts, see below:
System Error Messages for Cisco Unified Communications Manager 8.6(1)
You will be able to see on the application logs most of the following alerts:
http://www.cisco.com/en/US/partner/docs/voice_ip_comm/cucm/err_msgs/8_x/ccmalarms861.html
Also please check the documentation for RTMT which will answer most of your questions,
Cisco Unified Real-Time Monitoring Tool Administration Guide Version 8.6(1)
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/service/8_6_1/rtmt/rtmt.html
I hope this helps.
Daniel Amador
CCIE# 38898  (Voice)
Cisco TAC Support Engineer, UCIS Team
E-mail: daamador@cisco.com
Regards, Daniel Amador CCIE# 38898 (Voice) Cisco TAC Support Engineer
Hi Daniel,
Thanks for the help -- but currently I am not able to open the document through my current CCOID ( which is to be re-converted into a Cisco - features accessible ID.
Would appreciate if you can help me to access the document for now -- through my current account -- if it is possible.
Abhishek,
Please try accessing the following url and let me know if you still have problems:
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/err_msgs/8_x/ccmalarms861.html
Daniel Amador
CCIE# 38898  (Voice)
Hi Daniel,
Thanks a ton for this important documentation -- would go a long way in helping me out with these alerts.
I'm glad to hear that Abhishek.
Have a good one!
Daniel Amador
CCIE# 38898  (Voice)
