11-20-2013 02:32 AM - edited 03-18-2019 11:18 AM
i have configured a CCM 9.1 System but calls can come in , Cannot dial out what could be the cause
Solved! Go to Solution.
11-20-2013 06:54 AM
I'm not sure that's CUCM, does the call actually hit the GW??
My guess is you're not sending the call setup to telco's liking.
What does a debug says about the call?
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
11-24-2013 11:20 PM
As you are using SIP GW, you can expand the number using translation rule in GW.
also, you can do Called & Calling party transformations (discard digits, prefix & mask) in Route Pattern & Route List level in CUCM
HTH.
Please rate all the useful posts
11-20-2013 02:36 AM
Is internal call working? (inside the local network)
If everthing is fine, do a close look on CSS
Selvarathnam Nadar
11-20-2013 02:49 AM
the internal calls are working its the calling out
11-20-2013 02:55 AM
Arnold, is you using PSTN for calling out, are you created route pattern, etc.
And what you hear when you try to make a outgoing calls
11-20-2013 03:03 AM
am using PSTN Calling out i have Router 2921 with a SIP Trunk to the CCM and a ISDN PRI E1 to PSTN .WHEN I TRY TO DIAL AN OUTSIDE number i do get the message " your call canot be precessed consult your operator"
11-20-2013 03:18 AM
It seems that there are not matching route patterns defined in the CUCM.
Can you please check whether any route patterns are created.
11-20-2013 03:24 AM
Hi Arnold,
As suggested by Mahmood and Nadar, also check for PArtiton and CSS on IPphone from which u are making calls.
Also, check in Route Pattern for Partiton.
Just to simplify, make Route Pattern, CSS,Partiton as None and check.
regds,
aman
11-20-2013 03:20 AM
based on the error message, it seems issue with CSS/Partition. Please check the partition of the RP is included in device/line css of the phone
11-20-2013 03:46 AM
Is the CSS and partition are configured properly?
is this a MGCP or H323 gateway?
is MGCP-GW registered with CUCM?
11-20-2013 06:54 AM
java
11-21-2013 12:25 AM
iam using a Sip trunk betwwen the CUCM and Cisco Router do i need to create a gatway or the trunk will do the job
11-21-2013 12:44 AM
iam using the SIP Trunk between the CUCM and Router
11-21-2013 01:05 AM
Hi, Please make a test call and collect detailed CCM traces from CUCM and debug ccsip message, debug voice ccapi inout & debug isdn q931 from GW with calling number, called number
11-24-2013 10:17 PM
i have discovered that the callmanager was sending only 4 digits to our Telco instead of 7 am working on it . any procedure to correct this
11-24-2013 11:20 PM
HTH.
