Call Manager express SIP trunk to ISP
carl_townshend
Hi All
We have a Call Manager express with a SIP trunk to the provider, currently the SIP flows through the Firewall and is Natted.
Can anyone tell me if it is best practice when using SIP to plug the ISP connection straight into the Call Manager and run an access list or Firewall, this way we are not doing NAT etc.
Also as it is a CME, it is not a CUBE so can anyone tell me how the calls will flow to the provider?
cheers
Here is a snippet of the config for the SIP
voice service voip
 ip address trusted list
  ipv4 0.0.0.0 0.0.0.0
 allow-connections h323 to sip
 allow-connections sip to h323
 allow-connections sip to sip
 no supplementary-service sip moved-temporarily
 no supplementary-service sip refer
 fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
 sip
  bind control source-interface GigabitEthernet0/0/0
  bind media source-interface GigabitEthernet0/0/0
  registrar server
voice class codec 1
 codec preference 1 g711alaw
 codec preference 2 g711ulaw
 codec preference 3 g729r8
 codec preference 4 g729br8
voice register dn  3
 number 1202
 name 1202
 no-reg
 label 1202
voice register pool  3
 busy-trigger-per-button 2
 id mac 0072.7827.900D
 type 7821
 number 1 dn 3
 no digit collect kpml
 presence call-list
 dtmf-relay rtp-nte
 username 1202 password 1202
 codec g711alaw
dial-peer voice 103 voip
 description -= Incoming to 1202 =-
 translation-profile incoming 1
 destination-pattern 1203
 session protocol sipv2
 session target sip-server
 incoming called-number XXXXXXXX
 dtmf-relay rtp-nte sip-notify
 codec g711alaw
 no vad
 credentials username XXXXXX password 7 XXXXXX realm XXX.TEST.COM
no remote-party-id
 registrar dns:mpbx.XXX.TEST.COM expires 180
 sip-server dns:mpbx.TEST.COM
6 Replies 6
Dennis Mink
run a sip trunk into your ISP from your cme then from cme into your cucm, that is best practise
Please remember to rate useful posts, by clicking on the stars below.
we do not have a CUCM, it is a standalone CME
Nuno Melo
Level 4
Level 4
Both the Firewall or Connecting directly the ISP public interface to the CME Box are valid options.
Using a firewall you can create a DMZ network between the CME and the Firewall and nat 1:1 the IP ISP assigns to your voip trunk towards to the WAN IP assigend to the CUBE.
  • Disable Sip Inspection on the firewall, some firewall vendors say the contrary but the fact is Voice is Delay Sensitive and therfore inspecing the traffic may impact voice quality
  • do NAT 1:1 not PAT
You can also assign the ISP Public Interface to on of the CME Routers interfaces, since by this you are exposing the Router directly to the internet you could do the following.
  • Create 2 VRFs, 1 for LAN and one For WAN to completely segregate the data/signalling traffic
  • Create an ACL to allow only inbound traffic on the WAN interface from the ISP voip SBC
  • Make sure the ISP outbound Dial-peer would be sourced via the wan interface using the sip bind command on the outbound dial-peer
  • Make sure the CME ip source address is the ip address of the LAN interface
Even if you are using the Route as CME, if the traffic is sourced on the LAN IP address and has a WAN ip address as target  on a outbound call and vice-versa on an inbound call the Router will use cube feature to terminate the data traffic on the IP addresses and bridge the 2 call legs using a voice-channel thereby terminating the data streams on each of the IPs,
Its not advisable to have the binding command at the voice service VoIP level since this will make all traffic to and from the router to be sourced allways from GigabitEthernet0/0/0 (this is ok on the direction Router->Internet but not ok from the direction Internet->to Router), it would be preferable as stated above to have a LAN and WAN interface and use the sip binding commands on the dial-peer level.
Can you give example how you would do it on dial peer level?
cheers
Dial-peer voice xx voip
 voice-class sip bind control source-interface   [interface]
 voice-class sip bind media source-interface   [interface]
 no vad
You already have a SIP binding in place. What is the Gig0/0/0 interface ? LAN where your phones reside ? If yes, then you need to add the same to the VoIP dial-peer but the bind will be for the WAN/ISP facing interface. Another pointer looking at your config, I would not want the trust list to blindly accept everything (0.0.0.0/0 which what you have). Add the specific hosts that should be able to call to your system which would be your ITSP IP.
