Call Manager Express Vulnerability
connectone
Level 4
Level 4
Hello All.
I have a small UC500 with Call manager Express. Today, I noticed a bunch of calls to Ukraine and Cuba etc, 011 international calls.
I have no idea how this happened, but the show sip-ua calls shows that the originating IP is the IP address of the UC500.
does anyone know of an exploit in CCME that is letting people into the system to dial out.
Any help is greatly appreciated
10 Replies 10
Michael Owuor
Here are a couple of documents that describe possible exploits and help mitigate toll fraud in your CUCME installation.
Unified Communications Manager Express Toll Fraud Prevention
http://www.cisco.com/en/US/products/sw/voicesw/ps4625/products_tech_note09186a00809dc487.shtml
Cisco Unified CallManager Express Security Best Practices
http://www.cisco.com/en/US/partner/docs/voice_ip_comm/cucme/srnd/design/guide/security.html
Hope this helps.
Michael.
I am not able to get this to block outgoing 011 calls. I think I followed the instructions right in the toll fraud document but I am not so sure now. Seems as though it never reached the call-block statement for outbound calls and the first translation profile that matches the 9 for the secondary dialtone is matched and the call is allowed out.
I attached my rules.
dial-peer voice 1001 voip
description ** Outgoing call to SIP trunk (Generic SIP Trunk Provider) **
translation-profile outgoing PSTN_Outgoing
call-block translation-profile incoming BLOCK
destination-pattern 9T
voice-class codec 1
voice-class sip dtmf-relay force rtp-nte
session protocol sipv2
session target sip-server
dtmf-relay rtp-nte
ip qos dscp cs5 media
ip qos dscp cs4 signaling
no vad
voice translation-rule 999
rule 1 reject /^9011/
rule 2 reject /^91900.$/
rule 3 reject /^91976.$/
voice translation-rule 1112
rule 2 reject /^91900/
rule 3 reject /^91976/
rule 4 reject /^9976/
rule 10 /^9/ //
voice translation-profile BLOCK
translate called 999
voice translation-profile PSTN_Outgoing
translate calling 1111
translate called 1112
translate redirect-target 410
translate redirect-called 410
When I do a test of the translation rule 1112, it seems to block the call. In action though, the debug statments show it is going to skip the first rule and use the last rule and does not block the call.
Jul 24 15:25:51.162: //-1/164E617A8914/RXRULE/regxrule_profile_translate_internal: number=90115342210926 type=unknown plan=unknown numbertype=called
Jul 24 15:25:51.162: //-1/164E617A8914/RXRULE/regxrule_match: Skipping a call block rule; number=90115342210926 rule precedence=1
Jul 24 15:25:51.162: //-1/164E617A8914/RXRULE/regxrule_profile_match_internal: Matched with rule 10 in ruleset 1112
Jul 24 15:25:51.162: //-1/164E617A8914/RXRULE/sed_subst: Successful substitution; pattern=90115342210926 matchPattern=^9 replacePattern= replaced pattern=0115342210926
What would you suggest. I do not want to do International calls. What would be the preferrable solution is to block all international calls (011) unless you put in a code or it prompts for international code before letting the call out.
FRank Auciello
Hi, the most effective measure, put an ACL on the internet inteface that allows SIP only for trusted addresses.
The reason why the voice translation-rules are not blocking the test calls is because the only option for call blocking is in the incoming direction from the perspective of the voice gateway. In this configuration dial-peer 1001 is handling outbound calls. It would be effective in blocking those calls if they were originating from outside your network and coming in via the SIP trunk.
While recognizing that threats may be both internal or external, Paolo gives good advice (+5 Paolo) about using ACLs to restrict the traffic that is allowed to communicate with your router. Leverage the IOS firewall feature as described here:
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/srnd/design/guide/security.html#wp1077429
The dial-peer in use also has 9T as its destination pattern, effectively allowing any and all calls to be dialed through this one dial-peer, including international calls. You can get some control and granularity by creating separate dial-peers to handle calls to different destinations such as local, long distance, emergency and international, then leveraging features such as Class of Restriction (COR) to restrict which phones can place calls through the different dial-peers.
COR is the capability to deny certain call attempts based on the incoming and outgoing class of restrictions provisioned on the dial peers. COR specifies which incoming dial peer can use which outgoing dial peer to make a call. Each dial peer can be provisioned with an incoming and an outgoing COR list. COR functionality provides flexibility in network design by allowing users to block calls (for example, calls to international or 900 numbers) and allowing different restrictions to call attempts from different originators
Class of Restriction - CME Admin Guide
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/admin/configuration/guide/cmeblock.html#wp1014179
Configuring Class of Restrictions (COR)
http://www.cisco.com/en/US/tech/tk652/tk90/technologies_configuration_example09186a008019d649.shtml
If prompting the caller for a code before allowing the call to be placed is also a desired solution, the option does exists as described in the following link:
https://www.myciscocommunity.com/docs/DOC-1400#Can_UC500CME_be_configured_to_prompt_a_caller_for_a_PIN_before_placing_a_call
Hope this helps.
Michael.
Adrian Saavedra
Level 7
Level 7
Read about this, should help if you don't have some kind of security in your UC500.
Hope it helps, please rate if it does.
Best regards,
- Adrián.
pcameron
There are several 'port scanning' tools that probe IP address ranges with SIP invites messages and build up a list of 200 OK responses. This way they determine SIP capable devices and can then concentrate on determining dial plans. .
To prevent the unauthorised SIP and H323 calls, the simplest fix is to add an access list that blocks access via UDP port 5060 and TCP port 1720/5060 on any public facing interface.
In terms of basic security for a VOIP router, there are some well known security holes that can be easily exploited -
    Connection of an ethernet interface to the public internet without any form of firewalling or access blocking
    Basic passwords (do you know how many people use 'cisco'!) used for login access
Using Telnet for access instead of SSH - password as sent in the clear with telnet
    Using a destination pattern of '.T' for outgoing POTS dial peers
There are three simple way of blocking SIP or H323 unauthorised traffic. Some of these recommendations include blocking MGCP port numbers as well, but this is generally less of of a risk because of the complex external call processing required for MGCP control -
1) Using standard access lists and applying them to the interface
access-list 128 deny tcp any eq 5060 any
access-list 128 deny tcp any any eq 5060
access-list 128 deny udp any eq 5060 any
access-list 128 deny udp any any eq 5060
access-list 128 deny tcp any eq 1720 any
access-list 128 deny tcp any any eq 1720
access-list 128 permit ip any any
interface FastEthernet 0/0
 ip access-group 128 in
2) Turning off SIP transport.
sip-ua
 no transport upd
 no transport tcp
(When applying this workaround to devices that are processing MGCP or H.323 calls, the device will not allow SIP processing to stop while active calls are being processed. As a result, the workaround should be implemented during a maintenance period when active calls can be stopped)
3) Using control plane policing and policy maps
access-list 111 deny tcp any any eq 5060
access-list 111 deny tcp any any eq 5061
access-list 111 deny udp any any eq 5060
access-list 111 deny udp any any eq 5061
access-list 111 deny udp any any eq 2427
access-list 111 deny tcp any any eq 1720
access-list 111 deny tcp any any eq 11720
access-list 111 deny udp any any range 16384 32767
access-list 111 permit ip any any
class-map match-all drop-voice-class
  match access-group 111
policy-map drop-voice-traffic
  class drop-voice-class
  drop
control-plane
  service-policy input drop-voice-traffic
You can also use some of the other CME call blocking features described in the other posts. The best solution is to prevent the unauthorised trafffic from reaching the gateway in the first place.
I'm also have some quite same scenario in my network. I've 2821 router with old IOS. (c2800nm-entservicesk9-mz.123-14.T.bin). I've turn off SIP transport. so when i issue "show ip sockets" the port is not showing. But when i scan using nmap or telnet to 1720 its opening. I applied the control place policy map the router got struck. Any help on this.
Hi pcameron,
I think the access-list should be other way around otherwise it will drop all the packets...
access-list 111 permit tcp any any eq 5060
access-list 111 permit tcp any any eq 5061
access-list 111 permit udp any any eq 5060
access-list 111 permit udp any any eq 5061
access-list 111 permit udp any any eq 2427
access-list 111 permit tcp any any eq 1720
access-list 111 permit tcp any any eq 11720
access-list 111 permit udp any any range 16384 32767
access-list 111 deny ip any any
You are right - it has been a while since I played with CPP and it seems my notes are a bit messed up.
Following is a note on CCO that explains more about CPP. It highlights how you need to 'deny' traffic you want to permit and 'permit' the traffic you want to deny -
http://www.cisco.com/en/US/docs/ios/qos/configuration/guide/ctrl_plane_policng_ps6350_TSD_Products_Configuration_Guide_Chapter.html
Thanks for the link.
