03-17-2019 10:57 PM
I need to setup a hotline number. Any calls coming in on that number should route to the agents' Cisco phones based on their shift. For ex :
Hotline number : 12345
Agent1(77777) and Agent2(88888) will pick the calls in morning shift
Agent3(11111) and Agent4(22222) will pick the calls in afternoon and so on...
How can this be configured?
03-17-2019 11:52 PM
you can use either of two.
1) Cisco Call manager Time of day routing
2) Cisco Unity Connection using Schedules. (Recommended)
Please go through the questions and see if you have any further questions.
Adarsh Chauhan
Please mark correct or helpful if it helps you in anyway.
03-21-2019 09:16 AM
Thank you everyone. I was thinking of going ahead with the Unity Connection approach too.
The requester now wants the calls should go to one particular person for the entire day. And then the next person the next day. My approach is to create a hunt group and enable hunt login softkey template or line so that whoever has hunt login enabled can pick the calls for thosee days. I have a few questions here :
1. If there are 5 line group members and one of them has enabled the hunt login from the phone. In this case no matter what algorithm is applied the calls should always go to the person with HKey enabled first. Is this statement correct?
2. Is there a dependancy between the algorithm and the person whose HKey is enabled?
All I want is for that particular day whoever has enabled the HKey should get all calls on that hunt pilot number first, if he/she doesnt pick up then the calls can go traverse the algorithm. Can this be achieved?
03-21-2019 08:47 PM
Hi there
If you have UCCX, then this is relatively easy. Just create a simple ACD script
Welcome prompt
Language options
Route calls to CSQ
Hold
End call
You can create a CSQ and add agents as a part of this. You can provide IPPA or FInesse for these agents and they can receive calls as when they sign in based on their shifts
Hope this Helps
Cheers
Rath!
***Please rate helpful posts***
03-18-2019 12:14 AM
