Call Managers auto rebooting
Curtis Fuentes
    My call managers have recently started auto rebooting every day around the same time. I am not sure why this is happening, Did I enable something with out knowing.
5 Replies 5
Hi.
Can you please mention info such as cucm version, cluster single or multiple nodes, number of registered phones, hardware type...
Carlo
Please rate all helpful posts "The more you help the more you learn"
The call manager version  System version: 8.6.2.23900-10
We have one Pub with 4 subs. The PUB and 2 subs are located in FL and the other 2 subs are located in NJ. the subs in NJ reboot daily around the same time.
The number of phones register is 7,000 throught the cluster and the cm are sized for 10,000 each.
Thank you for the help
HW???
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
Hi ,
In addition to questions being asked, I do have a question : If u could brief  what all features are working along with any Unity/CCX/Presence/GWs integration?
regds,
aman
      Yes we are using unity connect/ UCCE/ Presence/ TMS for video.
