Call Pickup In between 7821 and 79xx Envirement: cme 10.5
alap84
Dear All
i have a strange behaviour of call pickup in 7821 (SIP) and 7965 (SCCP) enviroment
  • if the call rings on 7821 (SIP), 7965(SCCP) can pickup call via pickup softkey
  • if the call rings on 7965(SCCP), and 7821(SIP) try to pick via Pickup or Gpickup, give busy tone
following config attached for reference
telephony-service
 no auto-reg-ephone
 authentication credential  xxx yyy
 xml user kitadmin password  xxx
 max-ephones 42
 max-dn 200
 ip source-address 10.10.131.1 port 2000
 service phone displayOnTime 08:00
 service phone displayIdleTimeout 00:03
 service phone settingsAccess 1
 service phone handsetWidebandEnable 1
 service phone handsetWidebandUIControl 0
 service phone headsetWidebandUIControl 0
 service phone g722CodecSupport 2
 service phone displayOnWhenIncomingCall 1
 service phone backlightIdleTimeout 00:03
 service phone backlightOnTime 08:00
 service phone displayOnDuration 10:00
 service phone daysDisplayNotActive 6
 service phone daysBacklightNotActive 6
 service phone backlightOnDuration 11:00
 service phone ehookEnable 1
 service phone headsetWidebandEnable 0
 service phone webAccess 0
 service directed-pickup gpickup
 timeouts interdigit 7
 timeouts ringing 60
 timeouts transfer-recall 30
 system message <<< >>>
 url services http://10.10.131.2/voiceview/common/login.do
 url authentication http://10.10.131.1/CCMCIP/authenticate.asp
 cnf-file perphone
 load 7916-24 B016-1-0-4-2.SBN
 load 7945 SCCP45.9-4-2SR1-1S
 load 7965 SCCP45.9-4-2SR1-1S
 time-zone 31
 date-format dd-mm-yy
 voicemail 09
 max-conferences 8 gain -6
 call-park system application
 call-forward pattern .T
 call-forward system redirecting-expanded
 moh enable-g711 "flash:/Phones/music-on-hold.au"
 multicast moh 239.10.16.16 port 2000
 web admin system name xxx secret yyy
 dn-webedit
 time-webedit
 transfer-system full-consult
 transfer-pattern 9.T
 transfer-pattern .T
 secondary-dialtone 9
 login timeout 3
 after-hours block pattern 1 900.T
 after-hours day Sun 00:00 23:59
 after-hours day Mon 00:00 23:59
 after-hours day Tue 00:00 23:59
 after-hours day Wed 00:00 23:59
 after-hours day Thu 00:00 23:59
 after-hours day Fri 00:00 23:59
 after-hours day Sat 00:00 23:59
ephone-dn  10  octo-line
 number 100
 label 100
 description Operator
 name Operator
 allow watch
pickup-group 50
 call-forward noan 09 timeout 20
 corlist outgoing user-international
 ephone-dn-template 1
ephone  10
 device-security-mode none
 mac-address A8B1.D4FA.853A
 username "operator" password 12345
 presence call-list
 type 7965 addon 1 7916-24
 button  1:10
 pin 12345
voice register global
 mode  cme
 source-address 10.10.131.1 port 5060
 max-dn 200
 max-pool 42
 load 7821 sip78xx.10-1-1SR1-4
 authenticate register
 authenticate realm all
 timezone 31
 date-format D/M/Y
 mwi stutter
 mwi reg-e164
 no dst auto-adjust
 voicemail 09
 url directory http://10.10.131.1/localdirectory
 tftp-path flash:
 file text
 create profile sync 0014401022675423
 ntp-server x.x.x.x mode unicast
 camera
 video
voice register dn  3
 number 103
 call-forward b2bua noan 100 timeout 21
 allow watch
 pickup-group 50
 name Khan
 label Khan
 mwi
 mobility
voice register pool  3
 busy-trigger-per-button 2
 id mac 204C.9EB2.E55F
 type 7821
 number 1 dn 3
 dtmf-relay rtp-nte sip-kpml sip-notify
 username 103 password 55103
 codec g711ulaw
any one please let me know if something is wrong or missing
9 Replies 9
alap84
any luck guys ...
Can you post your full config?
Yosh
HTH Regards, Yosh
Hi.
please add  pickup-call any-group to your voice register dn 3 configuration
Carlo
Please rate all helpful posts "The more you help the more you learn"
thank you boss
now pickup is ok, only problem is if someone is picking it is showing Group Number 50 only, not the PSTN or Mob number
Hello Carlo
Pls reply what to do
Looks like its a bug,  please confirm, my current IOS is
Cisco IOS Software, C2900 Software (C2900-UNIVERSALK9-M), Version 15.4(3)M1, RELEASE SOFTWARE (fc1)
Incorrect Caller-id for pick up phone in CME.
CSCuv52050
any one please confirm ...
Debug voip ccapi default
Debug ccsip message
Debug ccsip error
Debug ccsip events
Debug ephone detail mac-address A8B1.D4FA.853A
while pickup, instead of showing PSTN number , showing group number which is 50
saw in logs showing trying to demote the numbers, can anyone help on this
PSTN --- CME --- Autoattended(time check only) Rings to SCCP (#100)--- Pickup SIP (#121)
EPHONE detail debugging is enabled (detail, state, registration, video, error) for phone A8B1.D4FA.853A
MC-Nuwaidrat-CME#
Aug  9 10:21:13.075: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
REGISTER sip:10.10.131.1 SIP/2.0
Via: SIP/2.0/UDP 10.10.131.23:5060;branch=z9hG4bK18222b44
From: <sip:111@10.10.131.1>;tag=204c9eb2bd3304c14413c54e-586d8194
To: <sip:111@10.10.131.1>
Call-ID: 204c9eb2-bd330002-18ad3fc2-76dcc1fa@10.10.131.23
Max-Forwards: 70
Date: Sun, 09 Aug 2015 10:21:08 GMT
CSeq: 1875 REGISTER
User-Agent: Cisco-CP7821/10.1.1
Contact: <sip:AD08-22FB@10.10.131.23:5060;transport=udp>;+sip.instance="<urn:uuid:00000000-0000-0000-0000-204c9eb2bd33>";+u.sip!devicename.ccm.cisco.com="SEP204C9EB2BD33";+u.sip!model.ccm.cisco.com="621"
Supported: replaces,join,sdp-anat,norefersub,resource-priority,extended-refer,X-cisco-callinfo,X-cisco-serviceuri,X-cisco-escapecodes,X-cisco-service-control,X-cisco-srtp-fallback,X-cisco-monrec,X-cisco-config,X-cisco-sis-6.0.2,X-cisco-xsi-8.5.1
Content-Length: 0
Expires: 3600
Aug  9 10:21:13.079: //77951/31EF7369A607/SIP/Event/sact_idle_new_message_register:
 ccsip_api_register_ind return value : SIP_SUCCESS
Aug  9 10:21:13.079: //77951/31EF7369A607/SIP/Error/ccsip_spi_register_incoming_registration:
 CCSIP_REGISTER:: Reregistering 111@10.10.131.23 Authentication Failed
Aug  9 10:21:13.079: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_REGISTER_RESP
Aug  9 10:21:13.079: //77951/31EF7369A607/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 401 Unauthorized
To: <sip:111@10.10.131.1>;tag=1F7DF454-1B0A
Date: Sun, 09 Aug 2015 10:21:13 GMT
Server: Cisco-SIPGateway/IOS-15.4.3.M1
CSeq: 1875 REGISTER
WWW-Authenticate: Digest realm="all",nonce="F044483503263208",algorithm=MD5,qop="auth"
Content-Length: 0
Aug  9 10:21:13.083: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 10.10.131.23:5060;branch=z9hG4bK33f8af7b
Max-Forwards: 70
CSeq: 1876 REGISTER
Authorization: Digest username="111",realm="all",uri="sip:10.10.131.1",response="d9ef020465bfb6eee2dfa22dfaa621f9",nonce="F044483503263208",cnonce="4ec4fc33",qop=auth,nc=00000001,algorithm=MD5
Content-Length: 0
Expires: 3600
Aug  9 10:21:13.083: //77951/31EF7369A607/SIP/Event/sact_idle_new_message_register:
Aug  9 10:21:13.083: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_REGISTER_RESP
Aug  9 10:21:13.087: //77951/31EF7369A607/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
CSeq: 1876 REGISTER
Supported: X-cisco-cme-sis-1.0.0
Supported: X-cisco-srtp-fallback
Contact: <sip:111@10.10.131.23:5060>;expires=600
Expires:  600
Content-Length: 0
Aug  9 10:21:14.707: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 10.10.131.29:5060;branch=z9hG4bK678a64a0
From: <sip:118@10.10.131.1>;tag=204c9eb2e62d04771a8bf202-78537f71
To: <sip:118@10.10.131.1>
Call-ID: 204c9eb2-e62d0002-2ad74aa4-10ee9fb0@10.10.131.29
Max-Forwards: 70
Date: Sun, 09 Aug 2015 10:21:10 GMT
CSeq: 1875 REGISTER
Contact: <sip:AD28-1815@10.10.131.29:5060;transport=udp>;+sip.instance="<urn:uuid:00000000-0000-0000-0000-204c9eb2e62d>";+u.sip!devicename.ccm.cisco.com="SEP204C9EB2E62D";+u.sip!model.ccm.cisco.com="621"
Content-Length: 0
Expires: 3600
Aug  9 10:21:14.711: //77952/32E91509A608/SIP/Event/sact_idle_new_message_register:
Aug  9 10:21:14.711: //77952/32E91509A608/SIP/Error/ccsip_spi_register_incoming_registration:
 CCSIP_REGISTER:: Reregistering 118@10.10.131.29 Authentication Failed
Aug  9 10:21:14.711: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_REGISTER_RESP
Aug  9 10:21:14.711: //77952/32E91509A608/SIP/Msg/ccsipDisplayMsg:
Sent:
To: <sip:118@10.10.131.1>;tag=1F7DFAB8-171E
Date: Sun, 09 Aug 2015 10:21:14 GMT
CSeq: 1875 REGISTER
WWW-Authenticate: Digest realm="all",nonce="9834CD4C032632AC",algorithm=MD5,qop="auth"
Content-Length: 0
Aug  9 10:21:14.715: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 10.10.131.29:5060;branch=z9hG4bK19ec8dbd
Max-Forwards: 70
CSeq: 1876 REGISTER
Authorization: Digest username="118",realm="all",uri="sip:10.10.131.1",response="d8b96bfe23e22a3753432673c8a36ea9",nonce="9834CD4C032632AC",cnonce="6665cbb3",qop=auth,nc=00000001,algorithm=MD5
Content-Length: 0
Expires: 3600
Aug  9 10:21:14.715: //77952/32E91509A608/SIP/Event/sact_idle_new_message_register:
Aug  9 10:21:14.719: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_REGISTER_RESP
Aug  9 10:21:14.719: //77952/32E91509A608/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
CSeq: 1876 REGISTER
Contact: <sip:118@10.10.131.29:5060>;expires=600
Expires:  600
Content-Length: 0
Aug  9 10:21:15.275: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
OPTIONS sip:192.168.131.40 SIP/2.0
Accept: application/sdp
Supported: 100rel
User-Agent: OXO920/041.001 GW_920/038.001
To: sip:192.168.131.40
From: sip:192.168.118.21;tag=6ff58a175e666e444a17b78ee2762b23
Contact: <sip:192.168.118.21;transport=UDP>
Call-ID: b7679429ab46cdd01a5a2875f96f0784@192.168.118.21
CSeq: 2066351824 OPTIONS
Via: SIP/2.0/UDP 192.168.118.21;rport;branch=z9hG4bK52c3f960efc0a7af0a4c2e184c7d903e
Max-Forwards: 70
Content-Length: 0
Aug  9 10:21:15.275: //-1/xxxxxxxxxxxx/SIP/Error/httpish_msg_free:
 Freeing NULL pointer!
Aug  9 10:21:15.275: //77953/333F2595A609/SIP/Error/sipSPIGetPeerByCalledPartyId:
 input arg error
Aug  9 10:21:15.275: //77953/333F2595A609/SIP/Error/sipSPIUpdateCallInfo:
 input argument error
Aug  9 10:21:15.275: //77953/333F2595A609/SIP/Error/ccsip_ipip_media_forking_anchor_leg_config:
 MF: Dial-peer is absent..
Aug  9 10:21:15.275: //77953/333F2595A609/SIP/Error/ccsip_ipip_media_forking_intra_frame_request_config:
 MF:video profile Dial-peer is absent..
Aug  9 10:21:15.275: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_CC_OPTIONS_RESP
Aug  9 10:21:15.275: //77953/333F2595A609/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
To: sip:192.168.131.40;tag=1F7DFCEC-1098
Date: Sun, 09 Aug 2015 10:21:15 GMT
Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, INFO, REGISTER
Allow-Events: telephone-event
Supported: 100rel,timer,resource-priority,replaces,sdp-anat
Content-Type: application/sdp
Content-Length: 367
v=0
o=CiscoSystemsSIP-GW-UserAgent 5627 8806 IN IP4 10.10.131.1
s=SIP Call
c=IN IP4 10.10.131.1
t=0 0
m=audio 0 RTP/AVP 18 0 8 9 4 2 15
m=image 0 udptl t38
a=T38FaxVersion:0
a=T38MaxBitRate:9600
a=T38FaxRateManagement:transferredTCF
a=T38FaxMaxBuffer:200
a=T38FaxMaxDatagram:320
a=T38FaxUdpEC:t38UDPRedundancy
Aug  9 10:21:18.359: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Supported: 100rel
User-Agent: OxO_GW_710/129.001
From: sip:192.168.230.20;tag=031ecbb2614acc892a44bcb01d63d7eb
Contact: <sip:192.168.230.20;transport=UDP>
Call-ID: 042aabe3a5c519a04d213575916727f1@192.168.230.20
CSeq: 1329545277 OPTIONS
Via: SIP/2.0/UDP 192.168.230.20;rport;branch=z9hG4bK4ec099debab6aed2edb0d2d1d55f0fa8
Max-Forwards: 70
Content-Length: 0
Aug  9 10:21:18.359: //-1/xxxxxxxxxxxx/SIP/Error/httpish_msg_free:
Aug  9 10:21:18.359: //77954/3515BB57A60A/SIP/Error/sipSPIGetPeerByCalledPartyId:
 input arg error
Aug  9 10:21:18.359: //77954/3515BB57A60A/SIP/Error/sipSPIUpdateCallInfo:
Aug  9 10:21:18.359: //77954/3515BB57A60A/SIP/Error/ccsip_ipip_media_forking_anchor_leg_config:
Aug  9 10:21:18.359: //77954/3515BB57A60A/SIP/Error/ccsip_ipip_media_forking_intra_frame_request_config:
Aug  9 10:21:18.359: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_CC_OPTIONS_RESP
Aug  9 10:21:18.363: //77954/3515BB57A60A/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
To: sip:192.168.131.40;tag=1F7E08F8-E9A
Date: Sun, 09 Aug 2015 10:21:18 GMT
Content-Length: 366
v=0
o=CiscoSystemsSIP-GW-UserAgent 846 4970 IN IP4 10.10.131.1
s=SIP Call
t=0 0
m=image 0 udptl t38
a=T38FaxVersion:0
Aug  9 10:21:21.539: //-1/36F9BEEA8093/CCAPI/cc_api_display_ie_subfields:
   cc_api_call_setup_ind_common:
   cisco-username=
   ----- ccCallInfo IE subfields -----
   cisco-ani=917711722
   cisco-anitype=2
   cisco-aniplan=1
   cisco-anipi=0
   cisco-anisi=3
   dest=04
   cisco-desttype=4
   cisco-destplan=1
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=-1
   cisco-rdnplan=-1
   cisco-rdnpi=-1
   cisco-rdnsi=-1
   cisco-redirectreason=-1   fwd_final_type =0
   final_redirectNumber =
   hunt_group_timeout =0
Aug  9 10:21:21.539: //-1/36F9BEEA8093/CCAPI/cc_api_call_setup_ind_common:
   Interface=0x3FA92340, Call Info(
   Calling Number=917711722,(Calling Name=)(TON=National, NPI=ISDN, Screening=Network, Presentation=Allowed),
   Called Number=04(TON=Subscriber, NPI=ISDN),
   Calling Translated=FALSE, Subscriber Type Str=RegularLine, FinalDestinationFlag=TRUE,
   Incoming Dial-peer=5560, Progress Indication=ORIGINATING SIDE IS NON ISDN(3), Calling IE Present=TRUE,
   Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=-1
Aug  9 10:21:21.539: //-1/36F9BEEA8093/CCAPI/ccCheckClipClir:
   In: Calling Number=917711722(TON=National, NPI=ISDN, Screening=Network, Presentation=Allowed)
   Out: Calling Number=917711722(TON=National, NPI=ISDN, Screening=Network, Presentation=Allowed)
Aug  9 10:21:21.539: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Aug  9 10:21:21.539: :cc_get_feature_vsa malloc success
Aug  9 10:21:21.539:  cc_get_feature_vsa count is 1
Aug  9 10:21:21.539: :FEATURE_VSA attributes are: feature_name:0,feature_time:1028894216,feature_id:8462
Aug  9 10:21:21.539: //77955/36F9BEEA8093/CCAPI/cc_api_call_setup_ind_common:
   Set Up Event Sent;
   Call Info(Calling Number=917711722(TON=National, NPI=ISDN, Screening=Network, Presentation=Allowed),
   Called Number=04(TON=Subscriber, NPI=ISDN))
Aug  9 10:21:21.539: //77955/36F9BEEA8093/CCAPI/cc_process_call_setup_ind:
   Event=0x22DFE210
Aug  9 10:21:21.539: //-1/xxxxxxxxxxxx/CCAPI/cc_setupind_match_search:
   Try with the demoted called number 04
Aug  9 10:21:21.539: //77955/36F9BEEA8093/CCAPI/ccCallSetContext:
   Context=0x3E084900
   >>>>CCAPI handed cid 77955 with tag 5560 to app "_ManagedAppProcess_Default"
Aug  9 10:21:21.539: //77955/36F9BEEA8093/CCAPI/ccCallProceeding:
   Progress Indication=NULL(0)
Aug  9 10:21:21.543: //77955/36F9BEEA8093/CCAPI/ccCallSetupRequest:
   Destination=, Calling IE Present=TRUE, Mode=0,
   Outgoing Dial-peer=500, Params=0x3E079C10, Progress Indication=ORIGINATING SIDE IS NON ISDN(3)
Aug  9 10:21:21.543: //77955/36F9BEEA8093/CCAPI/cc_set_post_tagdata:
   CALL_ERROR; Avlist Removal Is Failed
Aug  9 10:21:21.543: //77955/36F9BEEA8093/CCAPI/ccCheckClipClir:
   Destination Pattern=0., Called Number=04, Digit Strip=FALSE
   Redirect Number=, Display Info=
   Account Number=, Final Destination Flag=TRUE,
   Guid=36F9BEEA-3DB7-11E5-8093-A0ECF9684C80, Outgoing Dial-peer=500
Aug  9 10:21:21.543: //77955/36F9BEEA8093/CCAPI/cc_api_display_ie_subfields:
   ccCallSetupRequest:
   cisco-username=
   cisco-ani=917711722
   cisco-anitype=2
   cisco-aniplan=1
   cisco-anipi=0
   cisco-anisi=3
   dest=04
   cisco-desttype=4
   cisco-destplan=1
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=-1
   cisco-rdnplan=-1
   cisco-rdnpi=-1
   cisco-rdnsi=-1
Aug  9 10:21:21.543: //77955/36F9BEEA8093/CCAPI/ccIFCallSetupRequestPrivate:
   Interface=0x3ECB7210, Interface Type=3, Destination=, Mode=0x0,
   Call Params(Calling Number=917711722,(Calling Name=)(TON=National, NPI=ISDN, Screening=Network, Presentation=Allowed),
   Called Number=04(TON=Subscriber, NPI=ISDN), Calling Translated=FALSE,
   Subscriber Type Str=RegularLine, FinalDestinationFlag=TRUE, Outgoing Dial-peer=500, Call Count On=FALSE,
   Source Trkgrp Route Label=, Target Trkgrp Route Label=, tg_label_flag=0, Application Call Id=)
Aug  9 10:21:21.543: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Aug  9 10:21:21.543: :cc_get_feature_vsa malloc success
Aug  9 10:21:21.543:  cc_get_feature_vsa count is 2
Aug  9 10:21:21.543: :FEATURE_VSA attributes are: feature_name:0,feature_time:1028888840,feature_id:8463
Aug  9 10:21:21.543: //77956/36F9BEEA8093/SIP/Error/sipSPIGetCallServerGroupTargets:
 No server group configured
Aug  9 10:21:21.543: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_CC_CALL_SETUP
Aug  9 10:21:21.543: //77956/36F9BEEA8093/CCAPI/ccIFCallSetupRequestPrivate:
   SPI Call Setup Request Is Success; Interface Type=3, FlowMode=1
Aug  9 10:21:21.543: //77956/36F9BEEA8093/CCAPI/ccCallSetContext:
   Context=0x3E079BC0
Aug  9 10:21:21.543: //77955/36F9BEEA8093/CCAPI/ccSaveDialpeerTag:
SIP: (77956) Group (a= group line) attribute, level 65535 instance 1 not found.
Aug  9 10:21:21.543: //77956/36F9BEEA8093/CCAPI/cc_api_call_proceeding:
   Interface=0x3ECB7210, Progress Indication=NULL(0)
Aug  9 10:21:21.547: //77956/36F9BEEA8093/SIP/Event/Session-Timer/sipSTSLMain: Event: E_STSL_SESSION_REFRESH_REQ
Aug  9 10:21:21.547: //77956/36F9BEEA8093/SIP/Event/Session-Timer/sipSTSLMain: dir:1, method:102, resp_code:0, container:3DFB76E4
Aug  9 10:21:21.547: //77956/36F9BEEA8093/SIP/Event/sipSPICreateRpid: Received Octet3A=0x83 -> Setting ;screen=yes ;privacy=off
Aug  9 10:21:21.547: //77956/36F9BEEA8093/SIP/Msg/ccsipDisplayMsg:
Sent:
INVITE sip:04@10.10.131.2:5060 SIP/2.0
Via: SIP/2.0/UDP 10.10.131.1:5060;branch=z9hG4bK1CC7DAB
Remote-Party-ID: <sip:917711722@10.10.131.1>;party=calling;screen=yes;privacy=off
From: <sip:917711722@10.10.131.1>;tag=1F7E156C-11F2
To: <sip:04@10.10.131.2>
Date: Sun, 09 Aug 2015 10:21:21 GMT
Call-ID: 36FB9362-3DB711E5-A6108116-89D35DC4@10.10.131.1
Min-SE:  1800
Cisco-Guid: 0922337002-1035407845-2157158636-4184362112
User-Agent: Cisco-SIPGateway/IOS-15.4.3.M1
CSeq: 101 INVITE
Max-Forwards: 70
Timestamp: 1439115681
Contact: <sip:917711722@10.10.131.1:5060>
Call-Info: <sip:10.10.131.1:5060>;method="NOTIFY;Event=telephone-event;Duration=2000"
Expires: 180
Content-Disposition: session;handling=required
Content-Length: 244
v=0
o=CiscoSystemsSIP-GW-UserAgent 7474 1036 IN IP4 10.10.131.1
s=SIP Call
t=0 0
m=audio 23962 RTP/AVP 0 101
a=rtpmap:0 PCMU/8000
a=rtpmap:101 telephone-event/8000
a=fmtp:101 0-16
a=ptime:20
Aug  9 10:21:21.551: //77956/36F9BEEA8093/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 100 Trying
CSeq: 101 INVITE
Content-Length: 0
Aug  9 10:21:21.567: //77956/36F9BEEA8093/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 180 Ringing
To: <sip:04@10.10.131.2>;tag=ds8af9b262
CSeq: 101 INVITE
Content-Length: 0
Contact: <sip:04@10.10.131.2:5060;transport=udp>
Allow: INVITE, BYE, CANCEL, ACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, INFO
Cisco-Gcid: 36FB9362-3DB711E5-A6108116-89D35DC4@10.10.131.1
Aug  9 10:21:21.567: //77956/36F9BEEA8093/CCAPI/cc_api_call_alert:
   Interface=0x3ECB7210, Progress Indication=NULL(0), Signal Indication=SIGNAL RINGBACK(1)
   Call Entry(Retry Count=0, Responsed=TRUE)
Aug  9 10:21:21.567: //77955/36F9BEEA8093/CCAPI/ccCallAlert:
   Call Entry(Responsed=TRUE, Alert Sent=TRUE)
Aug  9 10:21:21.587: //77956/36F9BEEA8093/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 Ok
CSeq: 101 INVITE
Content-Length: 130
Call-Info: <sip:10.10.131.2:5060>;method="NOTIFY;Event=telephone-event;Duration=2000"
v=0
o=CUE 16424716 2 IN IP4 10.10.131.2
s=SIP Call
c=IN IP4 10.10.131.2
t=0 0
m=audio 21406 RTP/AVP 0
Aug  9 10:21:21.587: //77956/36F9BEEA8093/SIP/Event/Session-Timer/sipSTSLMain: Event: E_STSL_SESSION_REFRESH_RESP
Aug  9 10:21:21.587: //77956/36F9BEEA8093/SIP/Event/Session-Timer/sipSTSLMain: dir:2, method:102, resp_code:200, container:3DFBA3EC
SIP: Attribute mid, level 1 instance 1 not found.
Aug  9 10:21:21.587: //77956/36F9BEEA8093/CCAPI/cc_api_call_connected:
   Interface=0x3ECB7210, Data Bitmask=0x1, Progress Indication=NULL(0),
   Connection Handle=0
   Call Entry(Connected=TRUE, Responsed=TRUE, Retry Count=0)
Aug  9 10:21:21.591: //77955/36F9BEEA8093/CCAPI/ccGenerateToneInfo:
   Stop Tone On Digit=FALSE, Tone=Null,
   Tone Direction=Network, Params=0x0, Call Id=77955
Aug  9 10:21:21.591: //77955/36F9BEEA8093/CCAPI/ccConferenceCreate:
   (confID=0xFFFFFFFF, callID1=0x13083, gcid=36F9BEEA-3DB711E5-8093A0EC-F9684C80, tag=0x0)
Aug  9 10:21:21.591: //77956/36F9BEEA8093/CCAPI/ccConferenceCreate:
   (confID=0xFFFFFFFF, callID2=0x13084, gcid=36F9BEEA-3DB711E5-8093A0EC-F9684C80, tag=0x0)
   Conference Id=0xFFFFFFFF, Call Id1=77955, Call Id2=77956, Tag=0x0
Aug  9 10:21:21.591: //77955/36F9BEEA8093/CCAPI/cc_api_bridge_done:
   Conference Id=0x8C9, Source Interface=0x3FA92340, Source Call Id=77955,
   Destination Call Id=77956, Disposition=0x0, Tag=0xFFFFFFFF
Aug  9 10:21:21.591: //77956/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
Aug  9 10:21:21.591: cc_api_get_xcode_stream : 4982
Aug  9 10:21:21.591: //77956/36F9BEEA8093/CCAPI/cc_api_bridge_done:
   Conference Id=0x8C9, Source Interface=0x3ECB7210, Source Call Id=77956,
   Destination Call Id=77955, Disposition=0x0, Tag=0x0
Aug  9 10:21:21.591: //77955/36F9BEEA8093/CCAPI/cc_generic_bridge_done:
   Call Entry(Conference Id=0x8C9, Destination Call Id=77956)
   Call Entry(Conference Id=0x8C9, Destination Call Id=77955)
Aug  9 10:21:21.591: confID:0x8C9; callEntry1 callID1:0x13083, type:6; callEntry2 callID2:0x13084, type:3
Aug  9 10:21:21.591: //77955/36F9BEEA8093/CCAPI/cc_api_caps_ind:
   Destination Interface=0x3ECB7210, Destination Call Id=77956, Source Call Id=77955,
   Caps(Codec=0x1, Fax Rate=0x1, Fax Version:=0, Vad=0x1,
   Modem=0x2, Codec Bytes=20, Signal Type=3)
   Caps(Playout Mode=1, Playout Initial=60(ms), Playout Min=40(ms),
   Playout Max=1000(ms), Fax Nom=300(ms))
Aug  9 10:21:21.591: //77956/36F9BEEA8093/CCAPI/cc_api_caps_ind:
   Destination Interface=0x3FA92340, Destination Call Id=77955, Source Call Id=77956,
   Caps(Codec=0x1, Fax Rate=0x2, Fax Version:=0, Vad=0x1,
   Modem=0x0, Codec Bytes=160, Signal Type=2)
Aug  9 10:21:21.591: //77956/36F9BEEA8093/CCAPI/cc_api_caps_ack:
   Caps(Codec=g711ulaw(0x1), Fax Rate=FAX_RATE_VOICE(0x2), Fax Version:=0, Vad=OFF(0x1),
   Modem=OFF(0x0), Codec Bytes=160, Signal Type=2, Seq Num Start=3549)
Aug  9 10:21:21.591: //77955/36F9BEEA8093/CCAPI/cc_api_caps_ack:
Aug  9 10:21:21.591: //77955/36F9BEEA8093/CCAPI/ccCallConnect:
   Progress Indication=NULL(0), Data Bitmask=0x1
   Call Entry(Connected=TRUE, Responsed=TRUE)
Aug  9 10:21:21.595: //77955/36F9BEEA8093/CCAPI/cc_api_voice_mode_event:
   Call Id=77955
   Call Entry(Context=0x3E084900)
Aug  9 10:21:21.595: //77955/36F9BEEA8093/CCAPI/cc_process_notify_bridge_done:
   Conference Id=0x8C9, Call Id1=77955, Call Id2=77956
Aug  9 10:21:21.595: //77956/36F9BEEA8093/SIP/Msg/ccsipDisplayMsg:
Sent:
ACK sip:04@10.10.131.2:5060;transport=udp SIP/2.0
Via: SIP/2.0/UDP 10.10.131.1:5060;branch=z9hG4bK1CC81FB7
Max-Forwards: 70
CSeq: 101 ACK
Content-Length: 0
Aug  9 10:21:21.875: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
BYE sip:917711722@10.10.131.1:5060 SIP/2.0
Via: SIP/2.0/UDP 10.10.131.2:5060;branch=z9hG4bKSDsWYvtW6vbnsGZL.WIJ4Q~~27138
Max-Forwards: 70
To: <sip:917711722@10.10.131.1>;tag=1F7E156C-11F2
CSeq: 2 BYE
Content-Length: 0
Also: <sip:100@10.10.131.1:5060;user=phone>
Aug  9 10:21:21.875: //77955/36F9BEEA8093/CCAPI/ccGenerateToneInfo:
   Tone Direction=Sum Network, Params=0x0, Call Id=77955
Aug  9 10:21:21.875: //77956/36F9BEEA8093/CCAPI/cc_api_call_facility:
   Interface=0x3ECB7210, Call Id=77956
Aug  9 10:21:21.875: //77956/36F9BEEA8093/CCAPI/cc_api_get_ssCTreRoutingNotSupported:
   CallInfo(ssCTreRoutingNotSupported=FALSE)
Aug  9 10:21:21.875: //77955/36F9BEEA8093/CCAPI/ccConferenceDestroy:
   Conference Id=0x8C9, Tag=0x0
Aug  9 10:21:21.875: confID:0x8C9; callEntry1 callID1:0x13083, type:6; callEntry2 callID2:0x13084, type:3
Aug  9 10:21:21.875: //77955/36F9BEEA8093/CCAPI/cc_api_bridge_drop_done:
   Destination Call Id=77956, Disposition=0x0, Tag=0x0
Aug  9 10:21:21.875: //77956/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
Aug  9 10:21:21.875: cc_api_get_xcode_stream : 4982
Aug  9 10:21:21.875: //77955/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
Aug  9 10:21:21.875: //77956/36F9BEEA8093/CCAPI/cc_set_post_tagdata:
Aug  9 10:21:21.875: //77956/36F9BEEA8093/CCAPI/cc_api_bridge_drop_done:
Aug  9 10:21:21.875: //77955/36F9BEEA8093/CCAPI/cc_generic_bridge_done:
Aug  9 10:21:21.875: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Aug  9 10:21:21.875: :cc_get_feature_vsa malloc success
Aug  9 10:21:21.875:  cc_get_feature_vsa count is 3
Aug  9 10:21:21.879: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Aug  9 10:21:21.879: :FEATURE_VSA attributes are: feature_name:0,feature_time:1028889960,feature_id:8464
Aug  9 10:21:21.879: //-1/xxxxxxxxxxxx/CCAPI/cc_update_feature_vsa:
Aug  9 10:21:21.879:  feature_vsa is 3D539900,featname is 0
Aug  9 10:21:21.879: :cc_get_feature_vsa malloc success
Aug  9 10:21:21.879:  cc_get_feature_vsa count is 4
Aug  9 10:21:21.879: :FEATURE_VSA attributes are: feature_name:0,feature_time:1028894440,feature_id:8465
Aug  9 10:21:21.879: : Generating new feature vsa,inserting it
Aug  9 10:21:21.879:  feature call forward featname is 4
Aug  9 10:21:21.879:  feature_vsa is 3D53AE00,featname is 0
Aug  9 10:21:21.879:  cc_get_feature_vsa count is 5
Aug  9 10:21:21.879: :FEATURE_VSA attributes are: feature_name:0,feature_time:1028895112,feature_id:8466
Aug  9 10:21:21.879: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Aug  9 10:21:21.879: :cc_free_feature_vsa freeing 3D539D60
Aug  9 10:21:21.879:  vsacount in free is 4
Aug  9 10:21:21.879: //77956/36F9BEEA8093/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
CSeq: 2 BYE
P-RTP-Stat: PS=13,OS=2080,PR=13,OR=2080,PL=0,JI=0,LA=0,DU=0
Content-Length: 0
Aug  9 10:21:21.879: //77955/36F9BEEA8093/CCAPI/ccSaveDialpeerTag:
   Outgoing Dial-peer=0
Aug  9 10:21:21.879: //77955/36F9BEEA8093/CCAPI/ccGetTBCTCap:
   TGRM TBCT Enabled; TBCT Capability=0
Aug  9 10:21:21.879: :FEATURE_VSA attributes are: feature_name:0,feature_time:1028889960,feature_id:8467
Aug  9 10:21:21.879: : updating existing feature vsa
Aug  9 10:21:21.883: //77955/36F9BEEA8093/CCAPI/ccCallSetupRequest:
   Outgoing Dial-peer=20003, Params=0x39F2C850, Progress Indication=ORIGINATING SIDE IS NON ISDN(3)
Aug  9 10:21:21.883: //77955/36F9BEEA8093/CCAPI/cc_set_post_tagdata:
Aug  9 10:21:21.883: //77955/36F9BEEA8093/CCAPI/ccCheckClipClir:
   Destination Pattern=100$, Called Number=100, Digit Strip=TRUE
   Called Number=100(TON=Subscriber, NPI=ISDN),
   Guid=36F9BEEA-3DB7-11E5-8093-A0ECF9684C80, Outgoing Dial-peer=20003
Aug  9 10:21:21.883: //77955/36F9BEEA8093/CCAPI/cc_api_display_ie_subfields:
   ccCallSetupRequest:
   cisco-username=
   cisco-ani=917711722
   cisco-anitype=2
   cisco-aniplan=1
   cisco-anipi=0
   cisco-anisi=3
   dest=100
   cisco-desttype=4
   cisco-destplan=1
   cisco-rdie=FFFFFFFF
   cisco-rdn=04
   cisco-rdntype=0
   cisco-rdnplan=0
   cisco-rdnpi=0
   cisco-rdnsi=0
   cisco-redirectreason=0   fwd_final_type =0
Aug  9 10:21:21.883: //77955/36F9BEEA8093/CCAPI/ccIFCallSetupRequestPrivate:
   Interface=0x23E8F138, Interface Type=6, Destination=, Mode=0x0,
   Called Number=100(TON=Subscriber, NPI=ISDN), Calling Translated=FALSE,
   Subscriber Type Str=RegularLine, FinalDestinationFlag=TRUE, Outgoing Dial-peer=20003, Call Count On=FALSE,
Aug  9 10:21:21.883: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Aug  9 10:21:21.883: :cc_get_feature_vsa malloc success
Aug  9 10:21:21.883:  cc_get_feature_vsa count is 5
Aug  9 10:21:21.883: :FEATURE_VSA attributes are: feature_name:0,feature_time:1028889960,feature_id:8468
Aug  9 10:21:21.883:  ephone_hunt_channel: Selected dn[10] chan[9] htsp[0x23E8B548] is_inuse[0] is_reserved[0]
Aug  9 10:21:21.883: //77958/36F9BEEA8093/CCAPI/ccIFCallSetupRequestPrivate:
   SPI Call Setup Request Is Success; Interface Type=6, FlowMode=1
Aug  9 10:21:21.883: //77958/36F9BEEA8093/CCAPI/ccCallSetContext:
   Context=0x39F2C800
Aug  9 10:21:21.883: //77955/36F9BEEA8093/CCAPI/ccSaveDialpeerTag:
Aug  9 10:21:21.887: //77958/36F9BEEA8093/CCAPI/cc_api_update_call_info:
   Interface=0x23E8F138, Call Id=0x13086
Aug  9 10:21:21.887: SkinnyGetMultiMediaCapabilities: dn: 10, chan: 1
Aug  9 10:21:21.887: ephone-10[9/1][SEPA8B1D4FA853A]:SkinnyGetMultiMediaCapabilities: dn: 10, chan: 1
Aug  9 10:21:21.887: SkinnySetCallInfoName calling dn -1 chan 1 dn 10 chan 1,calling [917711722] called [100]
Aug  9 10:21:21.887: SetCallInfo DN 10 chan 1 is not skinny-to-skinny
Aug  9 10:21:21.887: SkinnyGetCallState for DN 10 chan 1 IDLE
Aug  9 10:21:21.887: called DN -1 chan 1, calling DN -1 chan 1 phone -1 s2s:0
Aug  9 10:21:21.887: SkinnyUpdateDnState by EFXS_RING_GENERATE
  for DN 10 chan 1 to state RINGING
Aug  9 10:21:21.887: ephone-10[9/1]:UpdateCallState DN 10 chan 1 state 7 calleddn -1 chan 1
Aug  9 10:21:21.887: ephone-10[9/1]:Binding ephone-10 to DN 10 chan 1 s2s:0
Aug  9 10:21:21.887: Assign Call Ref 955 to DN 10 chan 1
Aug  9 10:21:21.887: Skinny Call State change for DN 10 chan 1 RINGING from IDLE
Aug  9 10:21:21.887: ephone-(10) DN 10 chan 1 calledDn -1 chan 1 callingDn -1 chan 1 :: port=0 incoming
Aug  9 10:21:21.887: SkinnyUpdateCstate DN 10 chan 1 cstate 4
Aug  9 10:21:21.887: SkinnyGetCallState for DN 10 chan 1 RINGING
Aug  9 10:21:21.887: called DN -1 chan 1, calling DN -1 chan 1 phone -1 incoming s2s:0
Aug  9 10:21:21.887: ephone-10[9/1][SEPA8B1D4FA853A]:SkinnyUpdateCstate first phone for DN 10 chan 1 ref 955
Aug  9 10:21:21.887: ephone-10[9/1][SEPA8B1D4FA853A]:UpdateCState found DN 10 on line 1
Aug  9 10:21:21.887: ephone-10[9/1]:SkinnyUpdateCState process cstate 4 for inactive DN 10 chan 1 line 1 (activeLine=0 whisperLine=0)
Aug  9 10:21:21.887: ephone-10[9/1]:SkinnyUpdateCstate inactive (overlay) line 1 for DN 10 ref 955 combo=0
Aug  9 10:21:21.887: DN 10 chan 1 ephone-10 state set to 4
Aug  9 10:21:21.887: SkinnyGetCallState for DN 10 chan 2 IDLE
Aug  9 10:21:21.887: called DN -1 chan 1, calling DN -1 chan 1 phone 10 s2s:0
Aug  9 10:21:21.887: SkinnyGetCallState for DN 10 chan 3 IDLE
Aug  9 10:21:21.887: SkinnyGetCallState for DN 10 chan 4 IDLE
Aug  9 10:21:21.891: SkinnyGetCallState for DN 10 chan 5 IDLE
Aug  9 10:21:21.891: called DN -1 chan 1, calling DN -1 chan 1 phone -1 s2s:0
Aug  9 10:21:21.891: SkinnyGetCallState for DN 10 chan 6 IDLE
Aug  9 10:21:21.891: SkinnyGetCallState for DN 10 chan 7 IDLE
Aug  9 10:21:21.891: SkinnyGetCallState for DN 10 chan 8 IDLE
Aug  9 10:21:21.891: ephone-10[1]:SetCallState line 1 DN 10(10) chan 1 ref 955 TsRingIn
Aug  9 10:21:21.891: ephone-10[9/1]:SkinnyTrackActiveCall add line 1 ref 955 state 4 (slot 0)
Aug  9 10:21:21.891: SkinnyGetCallState for DN 10 chan 1 RINGING
Aug  9 10:21:21.891: called DN -1 chan 1, calling DN -1 chan 1 phone -1 incoming s2s:0
Aug  9 10:21:21.891: ephone-10[9/1][SEPA8B1D4FA853A]:SkinnyDisplayCallInfo incoming call line 1 ref 955
Aug  9 10:21:21.891: ephone-10[9/1][SEPA8B1D4FA853A]:SkinnyDisplayCallInfo callingNumber=917711722
Aug  9 10:21:21.891: ephone-10[9/1][SEPA8B1D4FA853A]:SkinnyDisplayCallInfo calledNumber=100
Aug  9 10:21:21.891: ephone-10[1]::callingNumber 917711722
Aug  9 10:21:21.891: ephone-10[1]::callingParty 917711722
Aug  9 10:21:21.891: ephone-10[9/1]:Call Info DN 10 line 1 ref 955 call state 7 called 100 calling 917711722 origcalled
Aug  9 10:21:21.891: bulk_speeddial_update_callinfo: 9
Aug  9 10:21:21.891: ephone-10[9/1]:Call Info DN 10 line 1 ref 955 called 100 calling 917711722 alternateCalling 917711722 origcalled 100 calltype 1
Aug  9 10:21:21.891: ephone-10[9/1][SEPA8B1D4FA853A]:Call Info for chan 1
Aug  9 10:21:21.891: ephone-10[9/1][SEPA8B1D4FA853A]:Original Called Name Operator
Aug  9 10:21:21.891: ephone-10[9/1]:SkinnyDisplayCallInfo No-callingName
Aug  9 10:21:21.891: ephone-10[9/1][SEPA8B1D4FA853A]:SkinnyDisplayCallInfo calledName=Operator
Aug  9 10:21:21.891: peer_vdb is NULL for DN 10, chan 1 at SkinnyIsPeerNonSCCP
Aug  9 10:21:21.891: ephone-10[9/1][SEPA8B1D4FA853A]:DisplayPriNotifyMessage: From : 917711722 (13/16)
Aug  9 10:21:21.891: ephone-10[9/1]:SelectPhoneSoftKeys set 3 mask FFFF for line 1 ref 955
Aug  9 10:21:21.891: SkinnyGetCallState for DN 10 chan 2 IDLE
Aug  9 10:21:21.891: called DN -1 chan 1, calling DN -1 chan 1 phone 10 s2s:0
Aug  9 10:21:21.891: SkinnyGetCallState for DN 10 chan 3 IDLE
Aug  9 10:21:21.891: SkinnyGetCallState for DN 10 chan 4 IDLE
Aug  9 10:21:21.891: called DN -1 chan 1, calling DN -1 chan 1 phone -1 s2s:0Try with the demoted called number 100
Aug  9 10:21:21.899: //-1/xxxxxxxxxxxx/CCAPI/cc_setupind_match_search:
   Try with the demoted called number 50
Aug  9 10:21:22.395: ephone-10[9/1][SEPA8B1D4FA853A]:SkinnyCheckPendingCallBackPhone scan 30 lines
Aug  9 10:21:25.303: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
INVITE sip:service-uri-pickup@10.10.131.1 SIP/2.0
Via: SIP/2.0/UDP 10.10.131.26:5060;branch=z9hG4bK19206fd9
From: "Hussain Ali" <sip:121@10.10.131.1>;tag=204c9eb2e64d066e4f00f950-69c94766
To: <sip:service-uri-pickup@10.10.131.1>
Call-ID: 204c9eb2-e64d01b2-7cff4d11-321443cc@10.10.131.26
Max-Forwards: 70
Date: Sun, 09 Aug 2015 10:21:19 GMT
CSeq: 101 INVITE
Contact: <sip:AD34-1379@10.10.131.26:5060;transport=udp>
Expires: 180
Allow: ACK,BYE,CANCEL,INVITE,NOTIFY,OPTIONS,REFER,REGISTER,UPDATE,SUBSCRIBE,INFO
Remote-Party-ID: "Hussain Ali" <sip:121@10.10.131.1>;party=calling;id-type=subscriber;privacy=off;screen=yes
Allow-Events: kpml,dialog
Authorization: Digest username="121",realm="all",uri="sip:service-uri-pickup@10.10.131.1",response="144d1e4fd26ba424e6db7182d626adff",nonce="D9D588E603254F88",cnonce="19640a02",qop=auth,nc=00000001,algorithm=MD5
Content-Length: 375
Content-Disposition: session;handling=optional
v=0
o=Cisco-SIPUA 3911 0 IN IP4 10.10.131.26
s=SIP Call
t=0 0
m=audio 30150 RTP/AVP 0 8 18 102 9 116 101
c=IN IP4 10.10.131.26
a=rtpmap:8 PCMA/8000
a=rtpmap:18 G729/8000
a=fmtp:18 annexb=no
a=rtpmap:102 L16/16000
a=rtpmap:9 G722/8000
a=rtpmap:116 iLBC/8000
a=fmtp:116 mode=20
a=fmtp:101 0-15
a=sendrecv
Aug  9 10:21:25.303: //-1/xxxxxxxxxxxx/SIP/Error/httpish_msg_free:
Aug  9 10:21:25.307: //77959/39395071A612/SIP/Event/Session-Timer/sipSTSLMain: Event: E_STSL_SESSION_REFRESH_REQ
Aug  9 10:21:25.307: //77959/39395071A612/SIP/Event/Session-Timer/sipSTSLMain: dir:2, method:102, resp_code:0, container:3DFB3174
Aug  9 10:21:25.307: //77959/39395071A612/SIP/Event/Session-Timer/sipSTSLPrintTDContainer: Peer-Event: E_STSL_LEG_BY_LEG, SE Value:0, SE Refresher:none, Min-SE Value:1800, flags:2000
SIP: (77959) Attribute mid, level 1 instance 1 not found.
SIP: (77959) setup attribute, level 1 instance 1 not found.
SIP: (77959) connection attribute, level 1 instance 1 not found.
SIP: (77959) Attribute label, level 1 instance 1 not found.
SIP: (77959) a=framerate attribute, level 1 instance 1 not found.
Aug  9 10:21:25.307: //-1/xxxxxxxxxxxx/SIP/Error/voipCodec_to_rtpAvpCodec:
 Unexpected VoIPCodec Type :
Aug  9 10:21:25.307: //-1/39395071A612/CCAPI/cc_api_display_ie_subfields:
   cisco-username=121
   cisco-ani=121
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=1
   dest=50
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=0
   cisco-rdnplan=0
   cisco-rdnpi=-1
   cisco-rdnsi=-1
Aug  9 10:21:25.307: //-1/39395071A612/CCAPI/cc_api_call_setup_ind_common:
   Interface=0x3ECB7210, Call Info(
   Calling Number=121,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed),
   Called Number=50(TON=Unknown, NPI=Unknown),
   Calling Translated=FALSE, Subscriber Type Str=Unknown, FinalDestinationFlag=FALSE,
   Incoming Dial-peer=40004, Progress Indication=NULL(0), Calling IE Present=TRUE,
   Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=77959
Aug  9 10:21:25.307: //-1/39395071A612/CCAPI/ccCheckClipClir:
   In: Calling Number=121(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed)
   Out: Calling Number=121(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed)
Aug  9 10:21:25.307: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Aug  9 10:21:25.307: :cc_get_feature_vsa malloc success
Aug  9 10:21:25.311: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Aug  9 10:21:25.311:  cc_get_feature_vsa count is 6
Aug  9 10:21:25.311: :FEATURE_VSA attributes are: feature_name:0,feature_time:1028893768,feature_id:8470
Aug  9 10:21:25.311: //77959/39395071A612/CCAPI/cc_api_call_setup_ind_common:
   Set Up Event Sent;
   Call Info(Calling Number=121(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed),
   Called Number=50(TON=Unknown, NPI=Unknown))
Aug  9 10:21:25.311: //77959/39395071A612/SIP/Event/Session-Timer/sipSTSLMain: Event: E_STSL_SESSION_REFRESH_RESP
Aug  9 10:21:25.311: //77959/39395071A612/SIP/Event/Session-Timer/sipSTSLMain: dir:1, method:102, resp_code:100, container:3DFB1544
Aug  9 10:21:25.311: //77959/39395071A612/CCAPI/cc_process_call_setup_ind:
   Event=0x22DFD708
Aug  9 10:21:25.311: //-1/xxxxxxxxxxxx/CCAPI/cc_setupind_match_search:
Aug  9 10:21:25.311: //77959/39395071A612/CCAPI/ccCallSetContext:
   Context=0x39F198D0
   >>>>CCAPI handed cid 77959 with tag 40004 to app "_ManagedAppProcess_Default"
Aug  9 10:21:25.311: //77959/39395071A612/CCAPI/ccCallSetupAck:
   Call Id=77959
Aug  9 10:21:25.311: //77959/39395071A612/CCAPI/cc_api_set_transfer_info:
   Transfer Number=, Transfer Reason=0x0
Aug  9 10:21:25.311: //77959/39395071A612/CCAPI/ccCallReportDigits:
   (callID=0x13087, digit_event=0x0, enable=FALSE, consume=FALSE)
   Enabled=TRUE, Call Id=77959
Aug  9 10:21:25.311: //77959/39395071A612/CCAPI/cc_api_call_report_digits_done:
   (vdbPtr=0x3ECB7210, callID=0x13087, disp=0, digit_event=0x0, enable=FALSE, consume=FALSE)
   Enabled=TRUE, Disposition=0x0, Interface=0x3ECB7210, Call Id=77959
   Call Entry(Initial Digit Timeout=10000(ms), Inter Digit Timeout=10000(ms))
Aug  9 10:21:25.351: //77959/39395071A612/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
Date: Sun, 09 Aug 2015 10:21:25 GMT
CSeq: 101 INVITE
Allow-Events: kpml, telephone-event
Content-Length: 0
Aug  9 10:21:25.351: //77959/39395071A612/CCAPI/ccCallProceeding:
Aug  9 10:21:25.351: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_CC_CALL_PROCEEDING
Aug  9 10:21:25.355: //77959/39395071A612/CCAPI/ccCallHandoff:
   Silent=FALSE, Application=0x3DFAB00C, Conference Id=0xFFFFFFFF
Aug  9 10:21:25.355: //-1/xxxxxxxxxxxx/CCAPI/cc_update_guid_called:
   copy called number 50
   Silent=FALSE, Application=0x3D54BA60, Conference Id=0xFFFFFFFF
Aug  9 10:21:25.355: //77955/36F9BEEA8093/CCAPI/ccConferenceCreate:
Aug  9 10:21:25.355: //77959/39395071A612/CCAPI/ccConferenceCreate:
   (confID=0xFFFFFFFF, callID2=0x13087, gcid=3939EC99-3DB711E5-A6158116-89D35DC4, tag=0x0)
   Conference Id=0xFFFFFFFF, Call Id1=77955, Call Id2=77959, Tag=0x0
Aug  9 10:21:25.355: //77955/36F9BEEA8093/CCAPI/cc_api_bridge_done:
   Conference Id=0x8CA, Source Interface=0x3FA92340, Source Call Id=77955,
   Destination Call Id=77959, Disposition=0x0, Tag=0xFFFFFFFF
Aug  9 10:21:25.355: //77959/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
Aug  9 10:21:25.355: cc_api_get_xcode_stream : 4982
Aug  9 10:21:25.355: //77959/39395071A612/CCAPI/cc_api_bridge_done:
   Conference Id=0x8CA, Source Interface=0x3ECB7210, Source Call Id=77959,
Aug  9 10:21:25.355: //77955/36F9BEEA8093/CCAPI/cc_generic_bridge_done:
   Call Entry(Conference Id=0x8CA, Destination Call Id=77959)
   Call Entry(Conference Id=0x8CA, Destination Call Id=77955)
Aug  9 10:21:25.355: confID:0x8CA; callEntry1 callID1:0x13083, type:6; callEntry2 callID2:0x13087, type:3
Aug  9 10:21:25.355: //77959/39395071A612/CCAPI/ccSetCallGCID:
   Update GCID [3939EC99-3DB711E5-A6158116-89D35DC4] with [36F9BEEA-3DB711E5-8093A0EC-F9684C80]
Aug  9 10:21:25.355: //77958/36F9BEEA8093/CCAPI/ccCallDisconnect:
   Cause Value=16, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=0)
   Cause Value=16, Call Entry(Responsed=TRUE, Cause Value=16)
Aug  9 10:21:25.355: //77958/36F9BEEA8093/CCAPI/cc_api_get_transfer_info:
   Transfer Number=NULL
Aug  9 10:21:25.355: //77959/39395071A612/CCAPI/ccCallConnect:
   Progress Indication=NULL(0), Data Bitmask=0x0
Aug  9 10:21:25.355: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_CC_CALL_CONNECT
Aug  9 10:21:25.359: //77959/39395071A612/CCAPI/ccSaveDialpeerTag:
   Outgoing Dial-peer=5560
Aug  9 10:21:25.359: //77955/36F9BEEA8093/CCAPI/ccSaveDialpeerTag:
   Outgoing Dial-peer=40004
Aug  9 10:21:25.359: //77955/36F9BEEA8093/CCAPI/ccCallFeature:
   Feature Type=46, Call Id=77955
Aug  9 10:21:25.359: //77955/36F9BEEA8093/CCAPI/ccGenerateToneInfo:
Aug  9 10:21:25.359: //77955/36F9BEEA8093/CCAPI/cc_api_caps_ind:
   Destination Interface=0x3ECB7210, Destination Call Id=77959, Source Call Id=77955,
Aug  9 10:21:25.359: //77959/39395071A612/CCAPI/cc_api_caps_ind:
   Destination Interface=0x3FA92340, Destination Call Id=77955, Source Call Id=77959,
   Caps(Codec=0x1, Fax Rate=0x2, Fax Version:=0, Vad=0x2,
Aug  9 10:21:25.359: //77959/39395071A612/CCAPI/cc_api_caps_ack:
   Caps(Codec=g711ulaw(0x1), Fax Rate=FAX_RATE_VOICE(0x2), Fax Version:=0, Vad=ON(0x2),
   Modem=OFF(0x0), Codec Bytes=160, Signal Type=2, Seq Num Start=6466)
Aug  9 10:21:25.359: dn_support_g729 true DN 10 chan 1 ephone-10
Aug  9 10:21:25.359: dn_support_g723 false DN 10 chan 1 ephone-10
Aug  9 10:21:25.359: DN: 10, CHAN: 1, voice_hcmask: 0x0
Aug  9 10:21:25.359: dn_support_srtp DN 10 chan 1 with dn_index 10 found phone -1
Aug  9 10:21:25.359: dn_support_srtp DN 10 chan 1 can not find phone support srtp
Aug  9 10:21:25.359: skinnyDeleteDpSessionStatsPending: callId=77958 dn=10 ch=1
Aug  9 10:21:25.359: //77955/36F9BEEA8093/CCAPI/cc_api_caps_ack:
Aug  9 10:21:25.359: //77959/39395071A612/CCAPI/ccCallNotify:
   Data Bitmask=0x7, Call Id=77959
Aug  9 10:21:25.359: //77955/36F9BEEA8093/CCAPI/cc_process_notify_bridge_done:
   Conference Id=0x8CA, Call Id1=77955, Call Id2=77959
Aug  9 10:21:25.359: //77959/39395071A612/SIP/Error/sipSPI_ipip_set_history_info_header:
 Not SIP2SIP mode
Aug  9 10:21:25.359: //77959/39395071A612/SIP/Event/Session-Timer/sipSTSLMain: Event: E_STSL_SESSION_REFRESH_RESP
Aug  9 10:21:25.359: //77959/39395071A612/SIP/Event/Session-Timer/sipSTSLMain: dir:1, method:102, resp_code:200, container:3DFBADE4
Aug  9 10:21:25.363: //77959/39395071A612/SIP/Event/sipSPICreateRpid: Received Octet3A=0x00 -> Setting ;screen=no ;privacy=off
Aug  9 10:21:25.363: SkinnyGetCallState for DN 10 chan 1 RINGING
Aug  9 10:21:25.363: called DN -1 chan 1, calling DN -1 chan 1 phone -1 incoming s2s:0
Aug  9 10:21:25.363: ephone-10[9/1][SEPA8B1D4FA853A]:DN 10 disc reason 16 normal state RINGING
Aug  9 10:21:25.363: SkinnyUpdateDnState by EFXS_NOT_RINGING
  for DN 10 chan 1 to state IDLE
Aug  9 10:21:25.363: ephone-10[9/1]:UpdateCallState DN 10 chan 1 state 0 calleddn -1 chan 1
Aug  9 10:21:25.363: ephone-10[9/1]:Binding ephone-10 to DN 10 chan 1 s2s:0
Aug  9 10:21:25.363: ephone-10[9/1][SEPA8B1D4FA853A]:Set FAC enabled (1) and dial mode (0)
Aug  9 10:21:25.363: SkinnySetDnInvokeId DN 10 chan 1 id 0 set=0
Aug  9 10:21:25.363: SkinnyStopDnRecallTimer: dn 10 chan 1
Aug  9 10:21:25.363: SkinnyGetCallState for DN 10 chan 1 IDLE
Aug  9 10:21:25.363: called DN -1 chan 1, calling DN -1 chan 1 phone -1 s2s:0
Aug  9 10:21:25.363: SkinnyGetCallState for DN 10 chan 2 IDLE
Aug  9 10:21:25.363: called DN -1 chan 1, calling DN -1 chan 1 phone 10 s2s:0
Aug  9 10:21:25.363: SkinnyGetCallState for DN 10 chan 3 IDLE
Aug  9 10:21:25.363: SkinnyGetCallState for DN 10 chan 4 IDLE
Aug  9 10:21:25.363: SkinnyGetCallState for DN 10 chan 5 IDLE
Aug  9 10:21:25.363: SkinnyGetCallState for DN 10 chan 6 IDLE
Aug  9 10:21:25.363: SkinnyGetCallState for DN 10 chan 7 IDLE
Aug  9 10:21:25.363: SkinnyGetCallState for DN 10 chan 8 IDLE
Aug  9 10:21:25.363: SkinnySetCallInfoName calling dn -1 chan 1 dn 10 chan 1,calling [] called []
Aug  9 10:21:25.363: SetCallInfo DN 10 chan 1 is not skinny-to-skinny
Aug  9 10:21:25.363: Skinny Call State change for DN 10 chan 1 IDLE from RINGING
Aug  9 10:21:25.363: ephone-(10) DN 10 chan 1 calledDn -1 chan 1 callingDn -1 chan 1 :: port=0
Aug  9 10:21:25.363: SkinnyUpdateCstate DN 10 chan 1 cstate 2
Aug  9 10:21:25.363: ephone-10[9/1][SEPA8B1D4FA853A]:SkinnyUpdateCstate first phone for DN 10 chan 1 ref 955
Aug  9 10:21:25.363: ephone-10[9/1][SEPA8B1D4FA853A]:UpdateCState found DN 10 on line 1
Aug  9 10:21:25.363: ephone-10[9/1]:SkinnyUpdateCState process cstate 2 for inactive DN 10 chan 1 line 1 (activeLine=0 whisperLine=0)
Aug  9 10:21:25.363: ephone-10[9/1]:SkinnyUpdateCstate inactive (overlay) line 1 for DN 10 ref 955 combo=0
Aug  9 10:21:25.363: DN 10 chan 1 ephone-10 state set to 2
Aug  9 10:21:25.363: ephone-10[9/1][SEPA8B1D4FA853A]:skip suppress missed calls for line 1 chan 1
Aug  9 10:21:25.363: ephone-10[1]:SetCallState line 1 DN 10(10) chan 1 ref 955 TsOnHook
Aug  9 10:21:25.363: ephone-10[9/1]:SkinnyTrackActiveCall for line 1 ref 955 state 2 (slot 0)
Aug  9 10:21:25.363: ephone-10[9/1]:SelectPhoneSoftKeys set 0 mask FFFF for line 1 ref 955
Aug  9 10:21:25.367: called DN -1 chan 1, calling DN -1 chan 1 phone -1 s2s:0
Aug  9 10:21:25.367: SkinnyGetCallState for DN 10 chan 7 IDLE
Aug  9 10:21:25.367: SkinnyGetCallState for DN 10 chan 8 IDLE
Aug  9 10:21:25.367: SkinnyGetCallState for DN 10 chan 2 IDLE
Aug  9 10:21:25.367: called DN -1 chan 1, calling DN -1 chan 1 phone 10 s2s:0
Aug  9 10:21:25.367: SkinnyGetCallState for DN 10 chan 3 IDLE
Aug  9 10:21:25.367: SkinnyGetCallState for DN 10 chan 4 IDLE
Aug  9 10:21:25.367: SkinnyGetCallState for DN 10 chan 5 IDLE
Aug  9 10:21:25.367: SkinnyGetCallState for DN 10 chan 6 IDLE
Aug  9 10:21:25.367: ephone-10[9/1]:STOP RINGING
Aug  9 10:21:25.367:  ephone_get_callid_from_dn_chan: dn[10] chan[1] callID[77958]
Aug  9 10:21:25.367: ephone-10[9/1]:Ringer Off
Aug  9 10:21:25.367: SkinnyGetCallState for DN 10 chan 1 IDLE
Aug  9 10:21:25.367: ephone-10[9/1]:Clean Up Speakerphone state
Aug  9 10:21:25.367: ephone-10[9/1]:SpeakerPhoneOnHook
Aug  9 10:21:25.367: ephone-10[9/1]:Speaker is not on, SpeakerPhoneOnHook suppressed
Aug  9 10:21:25.367: ephone-10[9/1][SEPA8B1D4FA853A]:SkinnyGetToneRef toneRef 0x0 callRef 0x3BB
Aug  9 10:21:25.367: ephone-10[9/1]:SkinnyPhoneToneDirect: StopTone sent: normal line=1 ref=955 tone=0x0
Aug  9 10:21:25.367: Skinny StopTone sent on ephone socket [1]
Aug  9 10:21:25.367: ephone-10[9/1]:SelectPhoneSoftKeys set 0 mask FFFF for line 0 ref 0
Aug  9 10:21:25.367: ephone-10[1]:SetLineLamp 1 to OFF
Aug  9 10:21:25.367: ephone-10[9/1]:SkinnyConfirmOnHookAck: dn 10 chan 1 dn_index 10 phone=9, pickupOnHook=0
Aug  9 10:21:25.367: ephone-10[9/1][SEPA8B1D4FA853A]:SkinnyCheckPendingCallBackPhone scan 30 lines
Aug  9 10:21:25.367: //77955/36F9BEEA8093/CCAPI/cc_api_voice_mode_event:
   Call Id=77955
Aug  9 10:21:25.371: //-1/xxxxxxxxxxxx/CCAPI/cc_build_csv_feature_vsa:
Aug  9 10:21:25.371: :Inside cc_build_feature_vsa
Aug  9 10:21:25.371:  feature call basic
Aug  9 10:21:25.371: cc_build_feature_vsa attr is "TWC","08/09/2015 13:21:21.883","917711722","100",0,8468,36F9BEEA 3DB711E5 8093A0EC F9684C80,13086,"","","",""
Aug  9 10:21:25.371: //77959/39395071A612/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
To: <sip:service-uri-pickup@10.10.131.1>;tag=1F7E2450-1B2D
CSeq: 101 INVITE
Remote-Party-ID: <sip:50@10.10.131.1>;party=called;screen=no;privacy=off
Contact: <sip:service-uri-pickup@10.10.131.1:5060>
Supported: replaces
Supported: timer
Content-Length: 232
v=0
o=CiscoSystemsSIP-GW-UserAgent 9867 7046 IN IP4 10.10.131.1
s=SIP Call
t=0 0
m=audio 23964 RTP/AVP 0 101
a=fmtp:101 0-16
Aug  9 10:21:25.375: //77958/36F9BEEA8093/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x23E8F138, Tag=0x0, Call Id=77958,
   Call Entry(Disconnect Cause=16, Voice Class Cause Code=0, Retry Count=0)
   Call Disconnect Event Sent
Aug  9 10:21:25.375: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Aug  9 10:21:25.375: :cc_free_feature_vsa freeing 3D539D60
Aug  9 10:21:25.375:  vsacount in free is 5
Aug  9 10:21:25.915: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
ACK sip:service-uri-pickup@10.10.131.1:5060 SIP/2.0
Via: SIP/2.0/UDP 10.10.131.26:5060;branch=z9hG4bK693739c5
Max-Forwards: 70
CSeq: 101 ACK
Content-Length: 0
Aug  9 10:21:28.835: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 10.10.131.26:5060;branch=z9hG4bK176d8c1a
From: <sip:121@10.10.131.1>;tag=204c9eb2e64d066f1cf67dc0-7d96aac2
To: <sip:121@10.10.131.1>
Call-ID: 204c9eb2-e64d0002-18ad3fc2-76dcc1fa@10.10.131.26
Max-Forwards: 70
Date: Sun, 09 Aug 2015 10:21:23 GMT
CSeq: 1875 REGISTER
Contact: <sip:AD34-1379@10.10.131.26:5060;transport=udp>;+sip.instance="<urn:uuid:00000000-0000-0000-0000-204c9eb2e64d>";+u.sip!devicename.ccm.cisco.com="SEP204C9EB2E64D";+u.sip!model.ccm.cisco.com="621"
Content-Length: 0
Expires: 3600
Aug  9 10:21:28.835: //77960/3B5441D0A617/SIP/Event/sact_idle_new_message_register:
Aug  9 10:21:28.835: //77960/3B5441D0A617/SIP/Error/ccsip_spi_register_incoming_registration:
 CCSIP_REGISTER:: Reregistering 121@10.10.131.26 Authentication Failed
Aug  9 10:21:28.835: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_REGISTER_RESP
Aug  9 10:21:28.835: //77960/3B5441D0A617/SIP/Msg/ccsipDisplayMsg:
Sent:
To: <sip:121@10.10.131.1>;tag=1F7E31E4-1665
Date: Sun, 09 Aug 2015 10:21:28 GMT
CSeq: 1875 REGISTER
WWW-Authenticate: Digest realm="all",nonce="DB4D850503263830",algorithm=MD5,qop="auth"
Content-Length: 0
Aug  9 10:21:29.479: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 10.10.131.26:5060;branch=z9hG4bK7c5c8e6f
Max-Forwards: 70
CSeq: 1876 REGISTER
Authorization: Digest username="121",realm="all",uri="sip:10.10.131.1",response="fbde9aa90783db49afb02fe25ee247f9",nonce="DB4D850503263830",cnonce="7037c69d",qop=auth,nc=00000001,algorithm=MD5
Content-Length: 0
Expires: 3600
Aug  9 10:21:29.483: //77960/3B5441D0A617/SIP/Event/sact_idle_new_message_register:
Aug  9 10:21:29.483: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_REGISTER_RESP
Aug  9 10:21:29.491: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Max-Forwards: 70
CSeq: 1876 REGISTER
Content-Length: 0
Expires: 3600
Aug  9 10:21:29.495: //77960/3B5441D0A617/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
Date: Sun, 09 Aug 2015 10:21:29 GMT
CSeq: 1876 REGISTER
Contact: <sip:121@10.10.131.26:5060>;expires=600
Expires:  600
Content-Length: 0
Sent:
SIP/2.0 200 OK
CSeq: 1876 REGISTER
Expires:  600
Content-Length: 0
Aug  9 10:21:31.107: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 10.10.131.25:5060;branch=z9hG4bK2c98cca8
From: <sip:106@10.10.131.1>;tag=204c9eb2bc3205ad788820b5-37d6e160
To: <sip:106@10.10.131.1>
Call-ID: 204c9eb2-bc320002-2dc4c642-7631ec37@10.10.131.25
Max-Forwards: 70
Date: Sun, 09 Aug 2015 10:21:30 GMT
CSeq: 1875 REGISTER
Contact: <sip:ACF4-1170@10.10.131.25:5060;transport=udp>;+sip.instance="<urn:uuid:00000000-0000-0000-0000-204c9eb2bc32>";+u.sip!devicename.ccm.cisco.com="SEP204C9EB2BC32";+u.sip!model.ccm.cisco.com="621"
Content-Length: 0
Expires: 3600
Aug  9 10:21:31.107: //77961/3CAEF29AA618/SIP/Event/sact_idle_new_message_register:
Aug  9 10:21:31.107: //77961/3CAEF29AA618/SIP/Error/ccsip_spi_register_incoming_registration:
 CCSIP_REGISTER:: Reregistering 106@10.10.131.25 Authentication Failed
Aug  9 10:21:31.107: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_REGISTER_RESP
Aug  9 10:21:31.107: //77961/3CAEF29AA618/SIP/Msg/ccsipDisplayMsg:
Sent:
To: <sip:106@10.10.131.1>;tag=1F7E3AC4-54A
Date: Sun, 09 Aug 2015 10:21:31 GMT
CSeq: 1875 REGISTER
WWW-Authenticate: Digest realm="all",nonce="5DB6321203263913",algorithm=MD5,qop="auth"
Content-Length: 0
Aug  9 10:21:31.839: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 10.10.131.25:5060;branch=z9hG4bK40c295b5
Max-Forwards: 70
CSeq: 1876 REGISTER
Authorization: Digest username="106",realm="all",uri="sip:10.10.131.1",response="08525e47e55b9c63abcad28cd0d62fe6",nonce="5DB6321203263913",cnonce="1b545e75",qop=auth,nc=00000001,algorithm=MD5
Content-Length: 0
Expires: 3600
Aug  9 10:21:31.843: //77961/3CAEF29AA618/SIP/Event/sact_idle_new_message_register:
Aug  9 10:21:31.843: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_REGISTER_RESP
Aug  9 10:21:31.851: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Max-Forwards: 70
CSeq: 1876 REGISTER
Content-Length: 0
Expires: 3600
Aug  9 10:21:31.855: //77961/3CAEF29AA618/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
CSeq: 1876 REGISTER
Contact: <sip:106@10.10.131.25:5060>;expires=600
Expires:  600
Content-Length: 0
Sent:
SIP/2.0 200 OK
CSeq: 1876 REGISTER
Expires:  600
Content-Length: 0
Aug  9 10:21:36.103: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Supported: 100rel
From: sip:192.168.129.200;tag=35bb2b74f12d9c1bef83d23b386209be
Contact: <sip:192.168.129.200;transport=UDP>
Call-ID: 553d0dd4fd31c527bf8dd04e7a8762c0@192.168.129.200
CSeq: 1372710247 OPTIONS
Via: SIP/2.0/UDP 192.168.129.200;rport;branch=z9hG4bK9d29166ee2acff68ce503247f431e08f
Max-Forwards: 70
Content-Length: 0
Aug  9 10:21:36.103: //-1/xxxxxxxxxxxx/SIP/Error/httpish_msg_free:
Aug  9 10:21:36.103: //77962/3FA948BBA619/SIP/Error/sipSPIGetPeerByCalledPartyId:
 input arg error
Aug  9 10:21:36.107: //77962/3FA948BBA619/SIP/Error/sipSPIUpdateCallInfo:
Aug  9 10:21:36.107: //77962/3FA948BBA619/SIP/Error/ccsip_ipip_media_forking_anchor_leg_config:
Aug  9 10:21:36.107: //77962/3FA948BBA619/SIP/Error/ccsip_ipip_media_forking_intra_frame_request_config:
Aug  9 10:21:36.107: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_CC_OPTIONS_RESP
Aug  9 10:21:36.107: //77962/3FA948BBA619/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
To: sip:192.168.131.40;tag=1F7E4E48-2554
Date: Sun, 09 Aug 2015 10:21:36 GMT
Content-Length: 367
v=0
o=CiscoSystemsSIP-GW-UserAgent 3055 3982 IN IP4 10.10.131.1
s=SIP Call
t=0 0
m=image 0 udptl t38
a=T38FaxVersion:0
Aug  9 10:21:37.083: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Supported: 100rel
From: sip:192.168.115.22;tag=4dd11176bcc3b61e8e791c6e625e2013
Contact: <sip:192.168.115.22;transport=UDP>
Call-ID: 8682fb35910acb1ff49d34a3fe2b2b60@192.168.115.22
CSeq: 1942776614 OPTIONS
Via: SIP/2.0/UDP 192.168.115.22;rport;branch=z9hG4bK1bf6e9169fbec3402206357651b8562f
Max-Forwards: 70
Content-Length: 0
Aug  9 10:21:37.083: //-1/xxxxxxxxxxxx/SIP/Error/httpish_msg_free:
Aug  9 10:21:37.083: //77963/403ED1DBA61A/SIP/Error/sipSPIGetPeerByCalledPartyId:
 input arg error
Aug  9 10:21:37.083: //77963/403ED1DBA61A/SIP/Error/sipSPIUpdateCallInfo:
Aug  9 10:21:37.083: //77963/403ED1DBA61A/SIP/Error/ccsip_ipip_media_forking_anchor_leg_config:
Aug  9 10:21:37.083: //77963/403ED1DBA61A/SIP/Error/ccsip_ipip_media_forking_intra_frame_request_config:
Aug  9 10:21:37.083: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_CC_OPTIONS_RESP
Aug  9 10:21:37.099: //77963/403ED1DBA61A/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
To: sip:192.168.131.40;tag=1F7E521C-10F5
Date: Sun, 09 Aug 2015 10:21:37 GMT
Content-Length: 367
v=0
o=CiscoSystemsSIP-GW-UserAgent 5201 6926 IN IP4 10.10.131.1
s=SIP Call
t=0 0
m=image 0 udptl t38
a=T38FaxVersion:0
Aug  9 10:21:42.291: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
INVITE sip:9@10.10.131.1;user=phone SIP/2.0
Via: SIP/2.0/UDP 10.10.131.25:5060;branch=z9hG4bK7bcab520
From: "Sethuraman" <sip:106@10.10.131.1>;tag=204c9eb2bc3205ae64206e8a-3da2806d
To: <sip:9@10.10.131.1>
Call-ID: 204c9eb2-bc32013f-4a9c956b-337ac0d7@10.10.131.25
Max-Forwards: 70
Date: Sun, 09 Aug 2015 10:21:41 GMT
CSeq: 101 INVITE
Expires: 180
Remote-Party-ID: "Sethuraman" <sip:106@10.10.131.1>;party=calling;id-type=subscriber;privacy=off;screen=yes
Authorization: Digest username="106",realm="all",uri="sip:9@10.10.131.1;user=phone",response="b0aa379b3ddc3e546c44f1815f4841b0",nonce="5DB6321203263913",cnonce="4b1706f4",qop=auth,nc=00000001,algorithm=MD5
Content-Length: 375
v=0
o=Cisco-SIPUA 7969 0 IN IP4 10.10.131.25
s=SIP Call
t=0 0
m=audio 24332 RTP/AVP 0 8 18 102 9 116 101
c=IN IP4 10.10.131.25
a=fmtp:18 annexb=no
a=fmtp:116 mode=20
a=fmtp:101 0-15
a=sendrecv
Aug  9 10:21:42.291: //-1/xxxxxxxxxxxx/SIP/Error/httpish_msg_free:
Aug  9 10:21:42.295: //77964/435981A0A61B/SIP/Event/Session-Timer/sipSTSLMain: Event: E_STSL_SESSION_REFRESH_REQ
Aug  9 10:21:42.295: //77964/435981A0A61B/SIP/Event/Session-Timer/sipSTSLMain: dir:2, method:102, resp_code:0, container:3DFB5D74
Aug  9 10:21:42.295: //77964/435981A0A61B/SIP/Event/Session-Timer/sipSTSLPrintTDContainer: Peer-Event: E_STSL_LEG_BY_LEG, SE Value:0, SE Refresher:none, Min-SE Value:1800, flags:2000
SIP: (77964) Attribute mid, level 1 instance 1 not found.
SIP: (77964) setup attribute, level 1 instance 1 not found.
SIP: (77964) connection attribute, level 1 instance 1 not found.
SIP: (77964) Attribute label, level 1 instance 1 not found.
SIP: (77964) a=framerate attribute, level 1 instance 1 not found.
Aug  9 10:21:42.295: //-1/xxxxxxxxxxxx/SIP/Error/voipCodec_to_rtpAvpCodec:
Aug  9 10:21:42.299: //-1/435981A0A61B/CCAPI/cc_api_display_ie_subfields:
   cisco-username=106
   cisco-ani=106
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=1
   dest=9
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=0
   cisco-rdnplan=0
   cisco-rdnpi=-1
   cisco-rdnsi=-1
Aug  9 10:21:42.299: //-1/435981A0A61B/CCAPI/cc_api_call_setup_ind_common:
   Calling Number=106,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed),
   Called Number=9(TON=Unknown, NPI=Unknown),
   Incoming Dial-peer=40003, Progress Indication=NULL(0), Calling IE Present=TRUE,
   Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=77964
Aug  9 10:21:42.299: //-1/435981A0A61B/CCAPI/ccCheckClipClir:
   In: Calling Number=106(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed)
   Out: Calling Number=106(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed)
Aug  9 10:21:42.299: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Aug  9 10:21:42.299: :cc_get_feature_vsa malloc success
Aug  9 10:21:42.299:  cc_get_feature_vsa count is 6
Aug  9 10:21:42.299: :FEATURE_VSA attributes are: feature_name:0,feature_time:1028889960,feature_id:8471
Aug  9 10:21:42.299: //77964/435981A0A61B/CCAPI/cc_api_call_setup_ind_common:
   Set Up Event Sent;
   Call Info(Calling Number=106(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed),
   Called Number=9(TON=Unknown, NPI=Unknown))
Aug  9 10:21:42.299: //77964/435981A0A61B/SIP/Event/Session-Timer/sipSTSLMain: Event: E_STSL_SESSION_REFRESH_RESP
Aug  9 10:21:42.299: //77964/435981A0A61B/SIP/Event/Session-Timer/sipSTSLMain: dir:1, method:102, resp_code:100, container:3DFB8084
Aug  9 10:21:42.299: //77964/435981A0A61B/CCAPI/cc_process_call_setup_ind:
   Event=0x22DFE210
Aug  9 10:21:42.299: //-1/xxxxxxxxxxxx/CCAPI/cc_setupind_match_search:
   Try with the demoted called number 9
Aug  9 10:21:42.299: //77964/435981A0A61B/CCAPI/ccCallSetContext:
   Context=0x3E07B168
   >>>>CCAPI handed cid 77964 with tag 40003 to app "_ManagedAppProcess_Default"
Aug  9 10:21:42.299: //77964/435981A0A61B/CCAPI/ccCallSetupAck:
   Call Id=77964
Aug  9 10:21:42.299: //77964/435981A0A61B/CCAPI/cc_api_set_transfer_info:
Aug  9 10:21:42.299: //77964/435981A0A61B/CCAPI/ccSetDigitTimeouts:
   Call Entry(Inter Digit Timeout=10000(ms), Initial Digit Timeout=10000(ms))
Aug  9 10:21:42.299: //77964/435981A0A61B/CCAPI/ccCallReportDigits:
   (callID=0x1308C, digit_event=0x1, enable=TRUE, consume=FALSE)
   Enabled=TRUE, Call Id=77964
Aug  9 10:21:42.299: //-1/xxxxxxxxxxxx/SIP/Event/ccsip_spi_subscribe_client: Queued event from SIP SPI : SIPSPI_EV_CC_SUBSCRIBE
Aug  9 10:21:42.303: //-1/xxxxxxxxxxxx/SIP/Error/sipSPIGetDialogParamStr:
 Invalid parameters
Aug  9 10:21:42.303: //77964/435981A0A61B/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
Date: Sun, 09 Aug 2015 10:21:42 GMT
CSeq: 101 INVITE
Content-Length: 0
Aug  9 10:21:42.547: //77964/435981A0A61B/CCAPI/cc_api_call_report_digits_done:
   (vdbPtr=0x3ECB7210, callID=0x1308C, disp=0, digit_event=0x1, enable=TRUE, consume=FALSE)
   Enabled=TRUE, Disposition=0x0, Interface=0x3ECB7210, Call Id=77964
Aug  9 10:21:42.551: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
NOTIFY sip:9@10.10.131.1:5060 SIP/2.0
Via: SIP/2.0/UDP 10.10.131.25:5060;branch=z9hG4bK09ec7efc
To: <sip:9@10.10.131.1>;tag=1F7E6680-1FD5
From: <sip:106@10.10.131.25>;tag=204c9eb2bc3205af4de46957-3c58545e
Call-ID: 435B56B0-3DB711E5-A6208116-89D35DC4@10.10.131.1
CSeq: 1000 NOTIFY
Event: kpml
Subscription-State: active; expires=7200
Max-Forwards: 70
Contact: <sip:ACF4-1170@10.10.131.25:5060;transport=UDP>
Authorization: Digest username="106",realm="all",uri="106",response="f5d12a58b966abe3737b67cbc3c24983",nonce="5DB6321203263913",cnonce="69db34e3",qop=auth,nc=00000001,algorithm=MD5
Content-Length: 0
Aug  9 10:21:42.551: //-1/xxxxxxxxxxxx/SIP/Event/ccsip_call_notify_response: Queued event from SIP SPI : SIPSPI_EV_CC_NOTIFY_RESP
Aug  9 10:21:43.399: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 10.10.131.25:5060;branch=z9hG4bK50cca700
CSeq: 1001 NOTIFY
Event: kpml
Max-Forwards: 70
Authorization: Digest username="106",realm="all",uri="106",response="69b7358a89b82226f2225d9235a60cd5",nonce="5DB6321203263913",cnonce="328df450",qop=auth,nc=00000002,algorithm=MD5
Content-Length: 205
Content-Type: application/kpml-response+xml
<?xml version="1.0" encoding="UTF-8"?>
<kpml-response xmlns="urn:ietf:params:xml:ns:kpml-response" version="1.0" code="200" text="OK" suppressed="false" forced_flush="false" digits="3" tag="Backspace OK"/>
Aug  9 10:21:43.399: //77964/435981A0A61B/CCAPI/cc_api_call_digit_begin:
   Destination Interface=0x0, Destination Mask=0x1, Destination Call Id=-1,
   Source Call Id=77964, Digit=3, DigitBeginFlags=0x0,
   Rtp Timestamp=0x0, Rtp Expiration=0x0
Aug  9 10:21:43.399: //77964/435981A0A61B/CCAPI/cc_api_call_digit_end:
   Source Call Id=77964, Digit=3, Duration=250,
   Xrule Calling Tag=0, Xrule Called Tag=0, Digit Tone Mode=DTMF
   Call Entry(Handoff Depth=0)
Aug  9 10:21:43.399: //-1/xxxxxxxxxxxx/SIP/Event/ccsip_call_notify_response: Queued event from SIP SPI : SIPSPI_EV_CC_NOTIFY_RESP
Aug  9 10:21:43.419: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
CSeq: 1001 NOTIFY
Event: kpml
Max-Forwards: 70
Content-Length: 205
Aug  9 10:21:43.815: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 10.10.131.25:5060;branch=z9hG4bK09ee8f88
CSeq: 1002 NOTIFY
Event: kpml
Max-Forwards: 70
Authorization: Digest username="106",realm="all",uri="106",response="62b239bbf77c227bbdd4c33c8a9e61ff",nonce="5DB6321203263913",cnonce="3001dbd8",qop=auth,nc=00000003,algorithm=MD5
Content-Length: 205
<kpml-response xmlns="urn:ietf:params:xml:ns:kpml-response" version="1.0" code="200" text="OK" suppressed="false" forced_flush="false" digits="9" tag="Backspace OK"/>
Aug  9 10:21:43.815: //-1/xxxxxxxxxxxx/SIP/Event/ccsip_call_notify_response: Queued event from SIP SPI : SIPSPI_EV_CC_NOTIFY_RESP
Aug  9 10:21:43.819: //77964/435981A0A61B/CCAPI/cc_api_call_digit_begin:
   Source Call Id=77964, Digit=9, DigitBeginFlags=0x0,
Aug  9 10:21:43.819: //77964/435981A0A61B/CCAPI/cc_api_call_digit_end:
   Source Call Id=77964, Digit=9, Duration=250,
Aug  9 10:21:44.559: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 10.10.131.25:5060;branch=z9hG4bK2e05be5e
Date: Sun, 09 Aug 2015 10:21:43 GMT
CSeq: 1003 NOTIFY
Event: kpml
Max-Forwards: 70
Authorization: Digest username="106",realm="all",uri="106",response="d4fc6d46e365b4397d5970a6f26fbde1",nonce="5DB6321203263913",cnonce="077d7c74",qop=auth,nc=00000004,algorithm=MD5
Content-Length: 205
<kpml-response xmlns="urn:ietf:params:xml:ns:kpml-response" version="1.0" code="200" text="OK" suppressed="false" forced_flush="false" digits="2" tag="Backspace OK"/>
Aug  9 10:21:44.563: //-1/xxxxxxxxxxxx/SIP/Event/ccsip_call_notify_response: Queued event from SIP SPI : SIPSPI_EV_CC_NOTIFY_RESP
Aug  9 10:21:44.575: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
CSeq: 1003 NOTIFY
Event: kpml
Max-Forwards: 70
Content-Length: 205
Aug  9 10:21:44.575: //77964/435981A0A61B/CCAPI/cc_api_call_digit_begin:
   Source Call Id=77964, Digit=2, DigitBeginFlags=0x0,
Aug  9 10:21:44.575: //77964/435981A0A61B/CCAPI/cc_api_call_digit_end:
   Source Call Id=77964, Digit=2, Duration=250,
Aug  9 10:21:44.967: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 10.10.131.25:5060;branch=z9hG4bK1b8fa982
CSeq: 1004 NOTIFY
Event: kpml
Max-Forwards: 70
Authorization: Digest username="106",realm="all",uri="106",response="aa9be045e001ff4d133e9ffce72f0ed8",nonce="5DB6321203263913",cnonce="27d99064",qop=auth,nc=00000005,algorithm=MD5
Content-Length: 205
<kpml-response xmlns="urn:ietf:params:xml:ns:kpml-response" version="1.0" code="200" text="OK" suppressed="false" forced_flush="false" digits="7" tag="Backspace OK"/>
Aug  9 10:21:44.967: //-1/xxxxxxxxxxxx/SIP/Event/ccsip_call_notify_response: Queued event from SIP SPI : SIPSPI_EV_CC_NOTIFY_RESP
Aug  9 10:21:44.971: //77964/435981A0A61B/CCAPI/cc_api_call_digit_begin:
   Source Call Id=77964, Digit=7, DigitBeginFlags=0x0,
Aug  9 10:21:44.971: //77964/435981A0A61B/CCAPI/cc_api_call_digit_end:
   Source Call Id=77964, Digit=7, Duration=250,
Aug  9 10:21:45.639: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 10.10.131.25:5060;branch=z9hG4bK4fb04375
Date: Sun, 09 Aug 2015 10:21:44 GMT
CSeq: 1005 NOTIFY
Event: kpml
Max-Forwards: 70
Authorization: Digest username="106",realm="all",uri="106",response="a5d07574fca1ac6d6d26b302faad0faf",nonce="5DB6321203263913",cnonce="7ba5a2cc",qop=auth,nc=00000006,algorithm=MD5
Content-Length: 205
Aug  9 10:21:45.639: //-1/xxxxxxxxxxxx/SIP/Event/ccsip_call_notify_response: Queued event from SIP SPI : SIPSPI_EV_CC_NOTIFY_RESP
Aug  9 10:21:45.655: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
REGISTER sip:10.10.131.1 SIP/2.0
Via: SIP/2.0/UDP 10.10.131.22:5060;branch=z9hG4bK39dc5a36
From: <sip:104@10.10.131.1>;tag=204c9eb2bc2e006f4bd0a3ed-62f0ba73
To: <sip:104@10.10.131.1>
Call-ID: 204c9eb2-bc2e0002-4a4d8854-7713ad98@10.10.131.22
Max-Forwards: 70
CSeq: 173 REGISTER
User-Agent: Cisco-CP7821/10.1.1
Contact: <sip:ACE8-C73@10.10.131.22:5060;transport=udp>;+sip.instance="<urn:uuid:00000000-0000-0000-0000-204c9eb2bc2e>";+u.sip!devicename.ccm.cisco.com="SEP204C9EB2BC2E";+u.sip!model.ccm.cisco.com="621"
Supported: replaces,join,sdp-anat,norefersub,resource-priority,extended-refer,X-cisco-callinfo,X-cisco-serviceuri,X-cisco-escapecodes,X-cisco-service-control,X-cisco-srtp-fallback,X-cisco-monrec,X-cisco-config,X-cisco-sis-6.0.2,X-cisco-xsi-8.5.1
Content-Length: 0
Expires: 3600
Aug  9 10:21:45.655: //77965/455AD045A621/SIP/Event/sact_idle_new_message_register:
 ccsip_api_register_ind return value : SIP_SUCCESS
Received:
CSeq: 1005 NOTIFY
Event: kpml
Max-Forwards: 70
Content-Length: 205
Aug  9 10:21:45.659: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Max-Forwards: 70
CSeq: 173 REGISTER
Content-Length: 0
Expires: 3600
Aug  9 10:21:45.659: //77964/435981A0A61B/CCAPI/cc_api_call_digit_begin:
Aug  9 10:21:45.659: //77964/435981A0A61B/CCAPI/cc_api_call_digit_end:
Aug  9 10:21:45.659: //77965/455AD045A621/SIP/Error/ccsip_spi_register_incoming_registration:
 CCSIP_REGISTER:: Reregistering 104@10.10.131.22 Authentication Failed
Aug  9 10:21:45.659: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_REGISTER_RESP
Aug  9 10:21:45.659: //77965/455AD045A621/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 401 Unauthorized
To: <sip:104@10.10.131.1>;tag=1F7E7398-1FF2
Date: Sun, 09 Aug 2015 10:21:45 GMT
Server: Cisco-SIPGateway/IOS-15.4.3.M1
CSeq: 173 REGISTER
WWW-Authenticate: Digest realm="all",nonce="1C5C621603263EC2",algorithm=MD5,qop="auth"
Content-Length: 0
Aug  9 10:21:46.167: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 10.10.131.25:5060;branch=z9hG4bK4625000b
CSeq: 1006 NOTIFY
Event: kpml
Max-Forwards: 70
Authorization: Digest username="106",realm="all",uri="106",response="1ee13d2375e2180d1113521571e8c84a",nonce="5DB6321203263913",cnonce="04f3504e",qop=auth,nc=00000007,algorithm=MD5
Content-Length: 205
Aug  9 10:21:46.171: //-1/xxxxxxxxxxxx/SIP/Event/ccsip_call_notify_response: Queued event from SIP SPI : SIPSPI_EV_CC_NOTIFY_RESP
Aug  9 10:21:46.175: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 10.10.131.22:5060;branch=z9hG4bK75ee0e5e
Max-Forwards: 70
CSeq: 174 REGISTER
Authorization: Digest username="104",realm="all",uri="sip:10.10.131.1",response="75ea79867a7adde3a867a4294f68fc76",nonce="1C5C621603263EC2",cnonce="0367b855",qop=auth,nc=00000001,algorithm=MD5
Content-Length: 0
Expires: 3600
Aug  9 10:21:46.175: //77965/455AD045A621/SIP/Event/sact_idle_new_message_register:
Received:
Max-Forwards: 70
CSeq: 174 REGISTER
Content-Length: 0
Expires: 3600
Aug  9 10:21:46.179: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
CSeq: 1006 NOTIFY
Event: kpml
Max-Forwards: 70
Content-Length: 205
Aug  9 10:21:46.179: //77964/435981A0A61B/CCAPI/cc_api_call_digit_begin:
Aug  9 10:21:46.179: //77964/435981A0A61B/CCAPI/cc_api_call_digit_end:
Aug  9 10:21:46.179: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_REGISTER_RESP
Aug  9 10:21:46.179: //77965/455AD045A621/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
Date: Sun, 09 Aug 2015 10:21:46 GMT
CSeq: 174 REGISTER
Supported: X-cisco-cme-sis-1.0.0
Supported: X-cisco-srtp-fallback
Contact: <sip:104@10.10.131.22:5060>;expires=600
Expires:  600
Content-Length: 0
Aug  9 10:21:46.979: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 10.10.131.25:5060;branch=z9hG4bK712dcf07
CSeq: 1007 NOTIFY
Event: kpml
Max-Forwards: 70
Authorization: Digest username="106",realm="all",uri="106",response="fe134f87e6c19f944bd5810189959094",nonce="5DB6321203263913",cnonce="5bd500d2",qop=auth,nc=00000008,algorithm=MD5
Content-Length: 205
<kpml-response xmlns="urn:ietf:params:xml:ns:kpml-response" version="1.0" code="200" text="OK" suppressed="false" forced_flush="false" digits="1" tag="Backspace OK"/>
Aug  9 10:21:46.983: //-1/xxxxxxxxxxxx/SIP/Event/ccsip_call_notify_response: Queued event from SIP SPI : SIPSPI_EV_CC_NOTIFY_RESP
Aug  9 10:21:47.003: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
CSeq: 1007 NOTIFY
Event: kpml
Max-Forwards: 70
Content-Length: 205
Aug  9 10:21:47.003: //77964/435981A0A61B/CCAPI/cc_api_call_digit_begin:
   Source Call Id=77964, Digit=1, DigitBeginFlags=0x0,
Aug  9 10:21:47.003: //77964/435981A0A61B/CCAPI/cc_api_call_digit_end:
   Source Call Id=77964, Digit=1, Duration=250,
Aug  9 10:21:47.707: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 10.10.131.25:5060;branch=z9hG4bK0d786ea8
CSeq: 1008 NOTIFY
Event: kpml
Max-Forwards: 70
Authorization: Digest username="106",realm="all",uri="106",response="3b34815faf22f71035c3df3007e0fc03",nonce="5DB6321203263913",cnonce="69b5efbc",qop=auth,nc=00000009,algorithm=MD5
Content-Length: 205
<kpml-response xmlns="urn:ietf:params:xml:ns:kpml-response" version="1.0" code="200" text="OK" suppressed="false" forced_flush="false" digits="0" tag="Backspace OK"/>
Aug  9 10:21:47.707: //-1/xxxxxxxxxxxx/SIP/Event/ccsip_call_notify_response: Queued event from SIP SPI : SIPSPI_EV_CC_NOTIFY_RESP
Aug  9 10:21:47.711: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
CSeq: 1008 NOTIFY
Event: kpml
Max-Forwards: 70
Content-Length: 205
Aug  9 10:21:47.711: //77964/435981A0A61B/CCAPI/cc_api_call_digit_begin:
   Source Call Id=77964, Digit=0, DigitBeginFlags=0x0,
Aug  9 10:21:47.711: //77964/435981A0A61B/CCAPI/cc_api_call_digit_end:
   Source Call Id=77964, Digit=0, Duration=250,
Aug  9 10:21:47.711: //77964/435981A0A61B/CCAPI/ccCallReportDigits:
   (callID=0x1308C, digit_event=0x0, enable=FALSE, consume=FALSE)
Aug  9 10:21:47.715: //-1/xxxxxxxxxxxx/SIP/Event/ccsip_spi_subscribe_client: Queued event from SIP SPI : SIPSPI_EV_CC_SUBSCRIBE
Aug  9 10:21:47.715: //77964/435981A0A61B/CCAPI/cc_api_call_report_digits_done:
   (vdbPtr=0x3ECB7210, callID=0x1308C, disp=0, digit_event=0x0, enable=FALSE, consume=FALSE)
Aug  9 10:21:47.715: //-1/xxxxxxxxxxxx/SIP/Error/sipSPIGetDialogParamStr:
 Invalid parameters
Aug  9 10:21:47.715: //77964/435981A0A61B/CCAPI/ccCallProceeding:
Aug  9 10:21:47.715: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_CC_CALL_PROCEEDING
Aug  9 10:21:47.719: //77964/435981A0A61B/CCAPI/ccCallSetupRequest:
   Outgoing Dial-peer=5560, Params=0x39F15828, Progress Indication=NULL(0)
Aug  9 10:21:47.719: //77964/435981A0A61B/CCAPI/cc_set_post_tagdata:
Aug  9 10:21:47.719: //77964/435981A0A61B/CCAPI/ccCheckClipClir:
   In: Calling Number=17702111(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed)
   Out: Calling Number=17702111(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed)
   Destination Pattern=9[13678]......., Called Number=939272710, Digit Strip=TRUE
   Calling Number=17702111(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed),
   Called Number=939272710(TON=Unknown, NPI=Unknown),
   Redirect Number=, Display Info=Sethuraman
   Account Number=106, Final Destination Flag=FALSE,
   Guid=435981A0-3DB7-11E5-A61B-811689D35DC4, Outgoing Dial-peer=5560
Aug  9 10:21:47.719: //77964/435981A0A61B/CCAPI/cc_api_display_ie_subfields:
   ccCallSetupRequest:
   cisco-username=106
   ----- ccCallInfo IE subfields -----
   cisco-ani=17702111
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=1
   dest=939272710
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=0
   cisco-rdnplan=0
   cisco-rdnpi=-1
   cisco-rdnsi=-1
   cisco-redirectreason=-1   fwd_final_type =0
   final_redirectNumber =
   hunt_group_timeout =0
Aug  9 10:21:47.719: //77964/435981A0A61B/CCAPI/ccIFCallSetupRequestPrivate:
   Interface=0x3FA92340, Interface Type=6, Destination=, Mode=0x0,
   Call Params(Calling Number=17702111,(Calling Name=Sethuraman)(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed),
   Called Number=939272710(TON=Unknown, NPI=Unknown), Calling Translated=FALSE,
   Subscriber Type Str=Unknown, FinalDestinationFlag=FALSE, Outgoing Dial-peer=5560, Call Count On=FALSE,
Aug  9 10:21:47.719: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Aug  9 10:21:47.719: :cc_get_feature_vsa malloc success
Aug  9 10:21:47.719:  cc_get_feature_vsa count is 7
Aug  9 10:21:47.719: :FEATURE_VSA attributes are: feature_name:0,feature_time:1028892424,feature_id:8472
Aug  9 10:21:47.719: //77966/435981A0A61B/CCAPI/ccIFCallSetupRequestPrivate:
Aug  9 10:21:47.719: //77966/435981A0A61B/CCAPI/ccCallSetContext:
   Context=0x39F157D8
Aug  9 10:21:47.719: //77964/435981A0A61B/CCAPI/ccSaveDialpeerTag:
Aug  9 10:21:47.727: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 10.10.131.25:5060;branch=z9hG4bK13abe232
Date: Sun, 09 Aug 2015 10:21:47 GMT
CSeq: 1009 NOTIFY
Event: kpml
Subscription-State: terminated; reason=timeout
Max-Forwards: 70
Authorization: Digest username="106",realm="all",uri="106",response="75ba48fa7186b4708992d94c4cb28d99",nonce="5DB6321203263913",cnonce="3a113b51",qop=auth,nc=0000000a,algorithm=MD5
Content-Length: 218
<kpml-response xmlns="urn:ietf:params:xml:ns:kpml-response" version="1.0" code="487" text="Subscription Exp" suppressed="false" forced_flush="false" digits="" tag="Backspace OK"/>
Aug  9 10:21:47.727: //-1/xxxxxxxxxxxx/SIP/Event/ccsip_call_notify_response: Queued event from SIP SPI : SIPSPI_EV_CC_NOTIFY_RESP
Aug  9 10:21:47.727: //-1/xxxxxxxxxxxx/SIP/Event/ccsip_api_initiate_subscription_termination: Queued event from SIP SPI : SIPSPI_EV_SUBSCRIPTION_TERMINATED
Aug  9 10:21:48.199: //77966/435981A0A61B/CCAPI/cc_api_call_proceeding:
   Interface=0x3FA92340, Progress Indication=INBAND(8)
Aug  9 10:21:48.203: //77964/435981A0A61B/CCAPI/ccCallCutProgress:
   Progress Indication=INBAND(8), Signal Indication=INTERCEPT(2), Cause Value=0
   Voice Call Send Alert=FALSE, Call Entry(Alert Sent=FALSE)
   Call Entry(Responsed=TRUE)
Aug  9 10:21:48.203: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_CC_CALL_PROGRESS
Aug  9 10:21:48.203: //77964/435981A0A61B/CCAPI/ccConferenceCreate:
   (confID=0xFFFFFFFF, callID1=0x1308C, gcid=435A1DC8-3DB711E5-A61E8116-89D35DC4, tag=0x0)
Aug  9 10:21:48.203: //77966/435981A0A61B/CCAPI/ccConferenceCreate:
   (confID=0xFFFFFFFF, callID2=0x1308E, gcid=435A1DC8-3DB711E5-A61E8116-89D35DC4, tag=0x0)
   Conference Id=0xFFFFFFFF, Call Id1=77964, Call Id2=77966, Tag=0x0
Aug  9 10:21:48.203: //77964/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
Aug  9 10:21:48.203: cc_api_get_xcode_stream : 4982
Aug  9 10:21:48.203: //77964/435981A0A61B/CCAPI/cc_api_bridge_done:
   Conference Id=0x8CB, Source Interface=0x3ECB7210, Source Call Id=77964,
   Destination Call Id=77966, Disposition=0x0, Tag=0x0
Aug  9 10:21:48.203: //77966/435981A0A61B/CCAPI/cc_api_bridge_done:
   Conference Id=0x8CB, Source Interface=0x3FA92340, Source Call Id=77966,
   Destination Call Id=77964, Disposition=0x0, Tag=0xFFFFFFFF
Aug  9 10:21:48.203: //77964/435981A0A61B/CCAPI/cc_generic_bridge_done:
   Call Entry(Conference Id=0x8CB, Destination Call Id=77966)
   Call Entry(Conference Id=0x8CB, Destination Call Id=77964)
Aug  9 10:21:48.203: confID:0x8CB; callEntry1 callID1:0x1308C, type:3; callEntry2 callID2:0x1308E, type:6
Aug  9 10:21:48.203: //77966/435981A0A61B/CCAPI/cc_api_caps_ind:
   Destination Interface=0x3ECB7210, Destination Call Id=77964, Source Call Id=77966,
Aug  9 10:21:48.203: //77964/435981A0A61B/CCAPI/cc_api_caps_ind:
   Destination Interface=0x3FA92340, Destination Call Id=77966, Source Call Id=77964,
Aug  9 10:21:48.203: //77964/435981A0A61B/CCAPI/cc_api_caps_ack:
   Modem=OFF(0x0), Codec Bytes=160, Signal Type=2, Seq Num Start=6420)
Aug  9 10:21:48.203: //77966/435981A0A61B/CCAPI/cc_api_caps_ack:
Aug  9 10:21:48.203: //77964/435981A0A61B/CCAPI/ccCallNotify:
   Data Bitmask=0x7, Call Id=77964
Aug  9 10:21:48.207: //77964/435981A0A61B/SIP/Error/sipSPI_ipip_set_history_info_header:
 Not SIP2SIP mode
Aug  9 10:21:48.207: //77964/435981A0A61B/SIP/Event/Session-Timer/sipSTSLMain: Event: E_STSL_SESSION_REFRESH_RESP
Aug  9 10:21:48.207: //77964/435981A0A61B/SIP/Event/Session-Timer/sipSTSLMain: dir:1, method:102, resp_code:183, container:3DFB0F14
Aug  9 10:21:48.207: //77964/435981A0A61B/SIP/Event/sipSPICreateRpid: Received Octet3A=0x00 -> Setting ;screen=no ;privacy=off
Aug  9 10:21:48.227: //77964/435981A0A61B/CCAPI/cc_process_notify_bridge_done:
   Conference Id=0x8CB, Call Id1=77964, Call Id2=77966
Aug  9 10:21:48.227: //77966/435981A0A61B/CCAPI/cc_api_voice_mode_event:
   Call Id=77966
Aug  9 10:21:48.231: //77966/435981A0A61B/CCAPI/cc_api_voice_mode_event:
   Call Entry(Context=0x39F157D8)
Aug  9 10:21:48.231: //77964/435981A0A61B/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 183 Session Progress
To: <sip:9@10.10.131.1>;tag=1F7E7D90-20FC
CSeq: 101 INVITE
Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, INFO, REGISTER
Remote-Party-ID: <sip:939272710@10.10.131.1>;party=called;screen=no;privacy=off
Contact: <sip:939272710@10.10.131.1:5060>
Content-Type: application/sdp
Content-Disposition: session;handling=required
Content-Length: 232
v=0
o=CiscoSystemsSIP-GW-UserAgent 4564 2582 IN IP4 10.10.131.1
s=SIP Call
c=IN IP4 10.10.131.1
t=0 0
m=audio 23966 RTP/AVP 0 101
a=rtpmap:0 PCMU/8000
a=rtpmap:101 telephone-event/8000
a=fmtp:101 0-16
Aug  9 10:21:50.755: //77966/435981A0A61B/CCAPI/cc_api_call_alert:
   Interface=0x3FA92340, Progress Indication=INBAND(8), Signal Indication=SIGNAL RINGBACK(1)
Aug  9 10:21:50.755: //77964/435981A0A61B/CCAPI/ccCallAlert:
Aug  9 10:21:50.755: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_CC_CALL_ALERTING
Aug  9 10:21:50.755: //77964/435981A0A61B/CCAPI/ccCallNotify:
Aug  9 10:21:50.755: //77964/435981A0A61B/SIP/Error/sipSPI_ipip_set_history_info_header:
 Not SIP2SIP mode
Aug  9 10:21:50.755: //77964/435981A0A61B/SIP/Event/Session-Timer/sipSTSLMain: Event: E_STSL_SESSION_REFRESH_RESP
Aug  9 10:21:50.755: //77964/435981A0A61B/SIP/Event/Session-Timer/sipSTSLMain: dir:1, method:102, resp_code:183, container:3DFBA1DC
Aug  9 10:21:50.755: //77964/435981A0A61B/SIP/Event/sipSPICreateRpid: Received Octet3A=0x00 -> Setting ;screen=no ;privacy=off
Aug  9 10:21:50.755: //77964/435981A0A61B/SIP/Msg/ccsipDisplayMsg:
Sent:
CSeq: 101 INVITE
Remote-Party-ID: <sip:39272710@10.10.131.1>;party=called;screen=no;privacy=off
Content-Length: 232
v=0
s=SIP Call
t=0 0
a=fmtp:101 0-16
Aug  9 10:21:52.327: ephone-10[9/1][SEPA8B1D4FA853A]:SkinnyCheckPendingCallBackPhone scan 30 lines
Aug  9 10:21:52.871: //77955/36F9BEEA8093/CCAPI/cc_api_call_disconnected:
   Cause Value=16, Interface=0x3FA92340, Call Id=77955
   Call Entry(Responsed=TRUE, Cause Value=16, Retry Count=0)
Aug  9 10:21:52.871: //77955/36F9BEEA8093/CCAPI/ccConferenceDestroy:
   Conference Id=0x8CA, Tag=0x0
Aug  9 10:21:52.871: confID:0x8CA; callEntry1 callID1:0x13083, type:6; callEntry2 callID2:0x13087, type:3
Aug  9 10:21:52.871: //77955/36F9BEEA8093/CCAPI/cc_api_bridge_drop_done:
   Destination Call Id=77959, Disposition=0x0, Tag=0x0
Aug  9 10:21:52.871: //77959/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
Aug  9 10:21:52.871: cc_api_get_xcode_stream : 4982
Aug  9 10:21:52.871: //77955/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
Aug  9 10:21:52.871: //77959/39395071A612/CCAPI/cc_set_post_tagdata:
   CALL_ERROR; Avlist Removal Is Failed
Aug  9 10:21:52.871: //77959/39395071A612/CCAPI/cc_api_bridge_drop_done:
Aug  9 10:21:52.871: //77955/36F9BEEA8093/CCAPI/cc_generic_bridge_done:
Aug  9 10:21:52.871: //77956/36F9BEEA8093/CCAPI/ccCallDisconnect:
Aug  9 10:21:52.871: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_CC_CALL_DISCONNECT
Aug  9 10:21:52.871: //77955/36F9BEEA8093/CCAPI/ccCallDisconnect:
   Cause Value=16, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=16)
Aug  9 10:21:52.871: //77955/36F9BEEA8093/CCAPI/cc_api_get_transfer_info:
Aug  9 10:21:52.875: //77959/39395071A612/CCAPI/ccCallDisconnect:
Aug  9 10:21:52.875: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_CC_CALL_DISCONNECT
Aug  9 10:21:52.875: //77959/39395071A612/SIP/Msg/ccsipDisplayMsg:
Sent:
BYE sip:AD34-1379@10.10.131.26:5060;transport=udp SIP/2.0
Via: SIP/2.0/UDP 10.10.131.1:5060;branch=z9hG4bK1CCB1008
From: <sip:service-uri-pickup@10.10.131.1>;tag=1F7E2450-1B2D
To: "Hussain Ali" <sip:121@10.10.131.1>;tag=204c9eb2e64d066e4f00f950-69c94766
User-Agent: Cisco-SIPGateway/IOS-15.4.3.M1
Max-Forwards: 70
Timestamp: 1439115712
CSeq: 101 BYE
Reason: Q.850;cause=16
P-RTP-Stat: PS=810,OS=129600,PR=898,OR=105043,PL=0,JI=1,LA=1,DU=27
Content-Length: 0
Aug  9 10:21:53.207: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_CC_CALL_DISCONNECT
Aug  9 10:21:53.207: //-1/xxxxxxxxxxxx/CCAPI/cc_build_csv_feature_vsa:
Aug  9 10:21:53.207: :Inside cc_build_feature_vsa
Aug  9 10:21:53.211:  feature call xfer
Aug  9 10:21:53.211: //-1/xxxxxxxxxxxx/CCAPI/cc_build_csv_feature_vsa:
Aug  9 10:21:53.211:  cxfer attr is "BXFER","08/09/2015 13:21:21.879",0,8464,36F9BEEA 3DB711E5 8093A0EC F9684C80,"",13084,0,:5,"04","917711722","100"
Aug  9 10:21:53.211: :Inside cc_build_feature_vsa
Aug  9 10:21:53.211:  feature call basic
Aug  9 10:21:53.211: cc_build_feature_vsa attr is "TWC","08/09/2015 13:21:21.543","917711722","04",0,8463,36F9BEEA 3DB711E5 8093A0EC F9684C80,13084,"","","",""
Aug  9 10:21:53.211: //77956/36F9BEEA8093/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x3ECB7210, Tag=0x0, Call Id=77956,
Aug  9 10:21:53.211: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Aug  9 10:21:53.211: :cc_free_feature_vsa freeing 3D53AEE0
Aug  9 10:21:53.211:  vsacount in free is 6
Aug  9 10:21:53.211:  vsacount in free is 5
Aug  9 10:21:53.219: //77959/39395071A612/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
CSeq: 101 BYE
Server: Cisco-CP7821/10.1.1
Content-Length: 0
Aug  9 10:21:53.219: //-1/xxxxxxxxxxxx/CCAPI/cc_build_csv_feature_vsa:
Aug  9 10:21:53.219: :Inside cc_build_feature_vsa
Aug  9 10:21:53.219:  feature call basic
Aug  9 10:21:53.219: cc_build_feature_vsa attr is "TWC","08/09/2015 13:21:25.311","121","50",0,8470,39395071 3DB711E5 A6128116 89D35DC4,13087,"","","",""
Aug  9 10:21:53.223: //77959/39395071A612/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x3ECB7210, Tag=0x0, Call Id=77959,
Aug  9 10:21:53.223: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Aug  9 10:21:53.223: :cc_free_feature_vsa freeing 3D53AC40
Aug  9 10:21:53.223:  vsacount in free is 4
Aug  9 10:21:54.003: //-1/xxxxxxxxxxxx/CCAPI/cc_build_csv_feature_vsa:
Aug  9 10:21:54.003: :Inside cc_build_feature_vsa
Aug  9 10:21:54.003:  feature call xfer
Aug  9 10:21:54.003:  cxfer attr is "BXFER","08/09/2015 13:21:21.879",0,8467,36F9BEEA 3DB711E5 8093A0EC F9684C80,"",13083,0,:5,"04","917711722","100"
Aug  9 10:21:54.003:  feature call basic
Aug  9 10:21:54.003: cc_build_feature_vsa attr is "TWC","08/09/2015 13:21:21.539","917711722","04",0,8462,36F9BEEA 3DB711E5 8093A0EC F9684C80,13083,"","","",""
Aug  9 10:21:54.007: //77955/36F9BEEA8093/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x3FA92340, Tag=0x0, Call Id=77955,
Aug  9 10:21:54.007: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Aug  9 10:21:54.007: :cc_free_feature_vsa freeing 3D53B180
Aug  9 10:21:54.007:  vsacount in free is 3
Aug  9 10:21:54.007:  vsacount in free is 2u all
All possible debugging has been turned off
Hi muhammadzubair,
I also have the same issue with CME 10.5 and SIP phone 8851.
When it's picked up by the SIP phone, the calling number was shown as the pickup group number.
Have you had a solution to this problem?
Thanks.
