04-04-2011 12:54 AM - edited 03-16-2019 04:18 AM
I have a strange problem related with the function Call PickUp.
First, a few words about the network topology:
- there is a Cisco ISR 2801 with CME 8.0
- there are SCCP and SIP endpoint registered to it
- the same router is a H323 gateway to the ITSP
Now the problem:
When an incoming call is received through the H323 and it is sent to a SIP device, if you try to pickup this call from another SIP endpoint - the pickup fails.
Actually, the first device stops ringing, but the incoming call doesn't connect to the second device.
- there is no problem when the same happens with SCCP endpoints
- there is no problem when the call is local
- there is no problem when the call comes through SIP trunk or FXO
- the call transfer and the others functions works without a problem
I couldn't find a solution for this problem by myself, so any help would be highly apreciated.
If there is something unclear or you need some extra information, please let me know.
Thank you!
04-04-2011 01:18 AM
Can you provide the following debugs
debug voip ccapi inout
debug ccsip messages
Calling and called numbers (Phone 1[SIP] amd Phone 2[SIP])
/divin
PS:rate useful posts!
04-04-2011 01:20 AM
Attach a "show tech" from the CME.
04-04-2011 07:02 AM
04-04-2011 09:34 AM
Try switching to h323 slow start either at the dial-peer with an h323 voice class or globally under voice service voip -> h323-> call start slow
04-05-2011 12:32 AM
Unfortunately, it doesn't help.
04-09-2011 09:28 AM
*Apr 4 13:31:05.222: //7642/8028B7491C00/CCAPI/cc_api_call_disconnected:
Apr 04 16:42:18 172.16.172.110 695: Cause Value=47, Interface=0x67AD68F8, Call Id=7642
Apr 04 16:42:18 172.16.172.110 696: *Apr 4 13:31:05.222: //7642/8028B7491C00/CCAPI/cc_api_call_disconnected:
Apr 04 16:42:18 172.16.172.110 697: Call Entry(Responsed=TRUE, Cause Value=47, Retry Count=0)
Apr 04 16:42:18 172.16.172.110 698: *Apr 4 13:31:05.222: //7642/8028B7491C00/CCAPI/ccConferenceDestroy:
Apr 04 16:42:18 172.16.172.110 699: Conference Id=0x2E, Tag=0x0
I can see Cause Code=47.
Can you enable
debug h225 asn1
debug h245 asn1
debug cssip all
/divin
04-11-2011 12:37 AM
