06-24-2015 03:08 AM - edited 03-17-2019 03:27 AM
Hi guys,
I have a question to ask. I got to deploy VOIP for my customer. In the architecture I have 3 sites:
- One CME 2951 srst which become the voice gateway and one Cisco BE6000 on a Headquater.
- A srst cme for each of the two remaining sites.
Can we have just one Cisco BE6000 which will manage call processing for the 3 sites?
Aristide
06-24-2015 03:45 AM
Hi Aristide,
As long as you stay within the limits of supported endpoints , users and sites as mentioned in the BE6000 datasheet it should be fine.
http://www.cisco.com/c/en/us/products/collateral/unified-communications/business-edition-6000/data_sheet_c78-717454.html
Do check the bandwidth and latency requirements for remote sites in the SRND for cucm 10.x for additional details.
Manish
06-24-2015 03:54 AM
Hi Manish,
Thanks for your reply. I have just 150 endpoints which is spread over the 3 sites.
So I don't need to have cisco BE6000 in cluster mode?
Aristide
06-24-2015 03:57 AM
That's correct, you don't need an additional server for this setup.
Manish
06-24-2015 07:41 AM
Thank you Manish.
Aristide
06-24-2015 07:49 AM
BE6000 is just a marketing bundle with some limitations built into it about the licensing. You can easily scale the bundle upto 1000 users (although there are some h/w restrictions, please check with your local Cisco AM)
Here is the datasheet for the BE6k
06-24-2015 08:34 AM
Thanks Samuel,
Concerning the licensing, I have a knowledge about it. I have just 150 endpoints, according to information that I have, I can use one BE6000 for the 3 sites. Is it correct?
