Call setup delay
m.elmaaroufi
Hi all,
I'm wondering a strange problem i have a CUCM v7.1 with 8961 SIP phones and Skinny phones, when i call a 8961 with extension 100 i get a call setup delay instead that is an internal call, i checked all the configuration informations all the phones are in the same Partition and device pool
Thanks in advance
Med
5 Replies 5
Jaime Valencia
Check for overlapping in your dial plan.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
and thank you for  ur answer, i'll check it in the cucm
regards
Med
Check for overlap in the toute plan report or runaa Dialed number analyser(DNA) for the dialed number. That should pretty much give you a fair idea of the way CUCM is routing your call.
Hope that helps
Nitesh
PS:pl rate helpful posts
Do you get the delay when dialing from SIP Phone?
If that is the case, are you using dial rule for SIP Phone? If no, then you need to use KPML. Otherwise you'll get delay because Phone will wait to finish the dialing.
Here is how you can configure dialplan
http://www.cisco.com/en/US/partner/docs/voice_ip_comm/cucmbe/admin/6_1_1/ccmcfg/b03sdial.html
thanks
- abu
Faheem Ansari
I think you are using NANP (North American Numbering Plan) in your Route Patterns so, if any dialed number start with “1”, CUCM will follow the E 164 standards of NANP i.e. (1 706 236 4455).
if yes, recreate your Route Patterns and rate the helpful post
Faheem Ansari
