Call to PSTN rejected disconnect cause 21
Even .
Hi all,
I got some problem here.
I have two call manager cluster (version 6.1.4 and 8.6.2 SU3), both of them connected to a H323 gateway (router 3845 iOS version 12.4.22). When I call to PSTN from 6.1.4 cluster, it works fine, but when I call to PSTN from 8.6.2 cluster, the call is rejected. then I debug the router and got disconnect cause 21.
disconnect cause 21 :
Call Rejected.
Indicates that the equipment sending this cause  does not wish to accept this call, alth9ough it could have accepted the  call because the equipment sending this cause is neither busy nor  incompatible. May also be generated by the network, indicating that the  call was cleared due to a supplementary service constraint.
The route pattern and other configuration at both cluster are the same.
Do you guys have any idea about this problem?
Even
2 Accepted Solutions
Hi Even,
Looking at the the symptoms (call not hitting the gateway and restart of the CM service resolves the issue), you might be hitting the following defect.
CSCtq10477 : Route Group Members being skipped and reporting as device down
In order to confirm, please provide the call manager traces for a failed call.
Alternatively, you can also check if you recieve alerts for "RouteListExhausted" with "Reason=41" in RTMT.
Jagpreet Singh Barmi
Hi Even,
I checked the working set of logs after the service  restart and could see the call to route out from the first member in the  route list using route group (4f333393-6e79-b477-c09a-b7351fa1bc95)  which was considered DOWN earlier.
Digit analysis.
16:26:47.775  |Digit analysis: match(pi="2", fqcn="02129946319", cn="53319",plv="5",  pss="PT_CTN:PT_Internal_JVO:PT_Internal_KLO:PT_Internal_SMO:PT_Internal_SMO_DRI_PBX:PT_Internal_SMO_RBI_PBX:PT_Internal_SMO_DMI_PBX:PT_PSTN_JVO_JAK:PT_TEHO_DRJ_PB:PT_TEHO_SLK_PB:PT_TEHO_BPN_PB:PT_TEHO_DRI_PB:PT_TEHO_RBI_PB:PT_TEHO_STN_PB:PT_TEHO_MNS_PB:PT_TEHO_DMI_PB:PT_TEHO_DRJ_CB:PT_TEHO_SLK_CB:PT_TEHO_BPN_CB:PT_TEHO_DRI_CB:PT_TEHO_RBI_CB:PT_TEHO_STN_CB:PT_TEHO_MNS_CB:PT_TEHO_DMI_CB:PT_Service_IBU:PT_Service_JVO:PT_Service_JVO_JAK:PT_Emergency_JVO_JAK:PT_Service_MWI:PT_Block_TollPremium:PT_Dummy",   TodFilteredPss="PT_CTN:PT_Internal_JVO:PT_Internal_KLO:PT_Internal_SMO:PT_Internal_SMO_DRI_PBX:PT_Internal_SMO_RBI_PBX:PT_Internal_SMO_DMI_PBX:PT_PSTN_JVO_JAK:PT_TEHO_DRJ_PB:PT_TEHO_SLK_PB:PT_TEHO_BPN_PB:PT_TEHO_DRI_PB:PT_TEHO_RBI_PB:PT_TEHO_STN_PB:PT_TEHO_MNS_PB:PT_TEHO_DMI_PB:PT_TEHO_DRJ_CB:PT_TEHO_SLK_CB:PT_TEHO_BPN_CB:PT_TEHO_DRI_CB:PT_TEHO_RBI_CB:PT_TEHO_STN_CB:PT_TEHO_MNS_CB:PT_TEHO_DMI_CB:PT_Service_IBU:PT_Service_JVO:PT_Service_JVO_JAK:PT_Emergency_JVO_JAK:PT_Service_MWI:PT_Block_TollPremium:PT_Dummy",   dd="7088808781851",dac="0")|2,100,13,1222.808^146.44.223.202^SEP001EBE918FD1
16:26:47.775 ||PretransformCallingPartyNumber=53319
|DialingPartition=PT_PSTN_JVO_JAK
|DialingPattern=7.!
|FullyQualifiedCalledPartyNumber=7088808781851
Route list selected is RL_CB_nonlocal_PSTN_JAK
16:26:47.776  |RouteListControl::idle_CcSetupReq -   RouteList(RL_CB_nonlocal_PSTN_JAK), RouteListCdrc::create  CI =  36027531  BRANCH = 0  mIsEmccHunt=0|2,100,13,1222.808^146.44.223.202^SEP001EBE918FD1
16:26:47.777 |RoutePlanServer::updateStartingIndex - RouteGroupName(4f333393-6e79-b477-c09a-b7351fa1bc95)|*^*^*
16:26:47.777 |RouteListCdrc::null0_CcSetupReq - Selecting a device.|2,100,13,1222.808^146.44.223.202^SEP001EBE918FD1
16:26:47.777  |SMDMSharedData::findLocalDevice - Name=146.44.254.68  Key=18b5c56f-8251-dd93-6816-49d2d6128fdb isActvie=1 Pid=(2,183,12)  found|2,100,13,1222.808^146.44.223.202^SEP001EBE918FD1
16:26:47.777 |RouteListCdrc::select_facility_DmPidRes: Execute a route action.|2,100,13,1222.808^146.44.223.202^SEP001EBE918FD1
16:26:47.777  |RouteListCdrc::routeAction -- current device  name=18b5c56f-8251-dd93-6816-49d2d6128fdb, idle or available  |2,100,13,1222.808^146.44.223.202^SEP001EBE918FD1
Also, I could see a TCP session being established and the H323 messages were exchanged.
16:26:47.779  |H225Cdpc::requestConnect_TcpStartSessionRes(691, 36027531):  TcpStartSessionRes from H225Handler=13|2,100,13,1295.2^*^*
16:26:47.779  |H225Cdpc::handleCcSetupReq(691, 36027531): H225Setup sent to  IP=146.44.254.68|2,100,13,1222.808^146.44.223.202^SEP001EBE918FD1
16:26:47.780 |value H323-UserInformation ::= |*^*^*
16:26:47.780 |SPROCRas - {
  h323-uu-pdu
    h323-message-body setup :
        protocolIdentifier { 0 0 8 2250 0 5 },
        sourceAddress
          h323-ID : {"Helmi Muzammil - 53319", ...}
        sourceInfo
Looking  at the symptoms, I believe that we are hitting the defect. However, the  reason code doesn't match. You can open a TAC case to get a  confirmation.
NOTE: As you pointed out earlier that we are  dealing with multiple issues, the TCP session not establishing even  with the other end point status as available could be because of  something else and analysis of the SDL Traces may provide additional  inputs about it.
HTH,
40 Replies 40
Ayodeji Okanlawon
This is likely because you dont have the ip address of CUCM8.6 defined in the destination-pattern of your dial-peer..
To solve this please configure this on your gateway and add the ip address of the cucm in your trust list
example below..
conf t
voice service voip
 ip address trusted list
  ipv4 203.0.113.100 255.255.255.255
  ipv4 192.0.2.0 255.255.255.0
Please rate all useful posts
"opportunity is a haughty goddess who waste no time with those who are unprepared"
Hi Aokanlawon,
Thanks for reply.
The command is not available in the iOS version 12.4.(22)T5.
As i know, that command available in iOS version 15.1(2)T and later
Even
Can you please send the ff:
debug voip ccapi inout
sh run
please include calling and called number
Please find debug and sh run file in the attachment
calling number 53319
called number 7088808781851
Even
Hi Even,
it seems the call is rejected at out leg by provider. please check with them why they are not accepting the call.
also, it would be good if you provide the debugs for a working call originating from cucm 6.
debug isdn q931 & debug voip ccapi inout for both working & nonworking calls would be helpful.
//Suresh Please rate all the useful posts.
The call is been disconnected from your Telco. The call is routed using dial-peer 11...and call id 11778 indicates that is the far end that is disconnecting the call...
Sep 27 15:44:36.668 WIB: //11778/80F77D080200/CCAPI/cc_api_call_disconnected:
   Cause Value=21, Interface=0x699200BC, Call Id=11778
   Call Entry(Responsed=TRUE, Cause Value=21, Retry Count=0)
I suggest you turn on debug isdn q931 to see the isdn negotiation and check why your telco is rejecting the call..
Hi Suresh and Aokanlawon,
Thanks for the responses.
But why is it working fine if the call to PSTN come out from cucm 6, and not from cucm 8?
Please find debug voice ccapi inout and isdn q931 for both working & nonworking calls from both cluster.
Even
Hi Even.
I saw in the log that in worknig case you send a 02129946319 and in non working case you are sending only the extension number 53319
Maybe that's the reason why your provider is rejecting the call
In the CUCM Route patter set a calling party trnasform mask as 02129946XXX
Carlo
Please rate all helpful posts
"The more you help the more you learn"
Please rate all helpful posts "The more you help the more you learn"
Yes Carlo, you are right.
Non Working Call
Sep 27 19:18:18.842 WIB: ISDN Se0/0/0:15 Q931: TX -> SETUP pd = 8  callref = 0x012D
Bearer Capability i = 0x8090A3
Standard = CCITT
Transfer Capability = Speech
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0xA98381
Exclusive, Channel 1
Progress Ind i = 0x8183 - Origination address is non-ISDN
Calling Party Number i = 0x2181, '53319'
Plan:ISDN, Type:National
Called Party Number i = 0x80, '088808781851'
Plan:Unknown, Type:Unknown
Working Call
Sep 27 19:25:06.324 WIB: ISDN Se0/0/0:15 Q931: TX -> SETUP pd = 8  callref = 0x012E
Standard = CCITT
Calling Party Number i = 0x2181, '02129946319'
>> the only difference is calling number.
As everyone has suggested, looks like your telco is rejecting the call due to wron caller ID..
Hi all,
Thanks for the response.
In my cucm configuration, my directory number has external phone mask, and in the route pattern -> route list, i had set "use calling party external phone number mask" to "On", so it will use mask from my directory number.
but why the calling number that sent to router still my internal directory number (in this case 53319)?
Is there anything wrong with my configuration above?
Even
Check Use Calling Party's External Phone Number Mask on the route pattern.
Please rate helpful answers!
Please check this box.
Hi Amine and Suresh,
sorry for late reply.
I don't think "Use Calling Party's External Phone Number Mask" on the route pattern need to be checked, because i have turn it on in the route list detail configuration (Route Group) in the fourth pic above.
i don't set "Use Calling Party's External Phone Number Mask" on the route pattern, because on that pattern, i assigned a route list that contains two route group, one route group's "Use Calling Party's External Phone Number Mask" i set to on, and the others i set it to off, because on the second route group, i using "calling party transform mask" field, so i can't turn it on in the route pattern section.
by the way, i haven't change any configuration but now it working well with existing configuration, i just try to restart the call manager service, i don't know how this can happen? because before this issue, the call to PSTN working well, then suddenly this problem occur without modification in the configuration before, but then again, now  it suddenly working well. is there anyone who ever experience this problem before? and what is the cause of this problem?
Even
