11-17-2021 12:02 PM
Hello Experts,
A caller calls into our organization. A menu offers 2 options:
1) When the caller choose option 1, the call is sent to a number outside of our organization
2) Talk to an agent
The incoming call takes a DS0 of our PRI and reaches the menu where we provide option 1 and option 2 as mentioned above.
When option 1 is selected, a second DS0 is taken to send the call to the number outside of our organization. The call stays in our gateway and consumes 2 DS0s for the entire duration of the call. Is this the normal behavior? I always was under impression that after the call is transferred, the RTP traffic goes between the endpoints but in our case the gateway shows 2 call legs until the conversation ends.
Is there a way that we can free our DS0s after the call is transferred?
We are using MGCP with CUMC 11.5.
MK
Solved! Go to Solution.
11-17-2021 12:12 PM
Yes, that has always been the way this works, some telcos have TBCT and only in that scenario, your DS0s would free from that call flow.
11-17-2021 12:12 PM
11-18-2021 07:43 AM
Thanks Jaime,
If the telco supports this technolgy, do we need to do anything in our gateway? Any configurations?
MK
11-17-2021 10:25 PM
As JAVA mentioned, its the way it works.
11-18-2021 03:04 AM
As it is TDM calls there are no RTP stream as such as that is a VoIP thing.
