09-09-2011 01:05 PM - edited 03-16-2019 06:55 AM
HI,
I have CUCM 6.1.5 and the 2821 router as a H323 gateway.
My problem is that Call Transfer, Call Hold and Conference not working.
Regardless of whether I call or receive calls, when I want to do a call Transfer, or even call Hold, and Conference, that options are disabled.
Options are displayed on the phone display but can not be used. When I try to do one of these features nothing happens...
Is anybody had similar problems and whether you can give me guidelines on how to solve this problem?
Solved! Go to Solution.
09-09-2011 02:03 PM
HI,
Do you have any MTP resource configured? Sounds like you are missing MTP and that's why the supplementary services such as hold, transfer or conference are not working. Please refer to:
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/admin/7_0_1/ccmsys/a05dsp.html
Remember to include the MTP on a MRG and this group on a MRGL.
Tere.
If you find this post helpful, please rate! :
09-09-2011 01:38 PM
hello,
what kinds of phones are having this issue?
can you reset one of the phone and check if the issue still happen!!
thanks,
Vipul Jindal
09-09-2011 02:01 PM
Can you please check switching the "Media Termination Point Required" box? Either try it on or off.
09-09-2011 02:03 PM
HI,
Tere.
09-09-2011 05:31 PM
Thanks ,
This was helpful. am restaring the media resource group.
Now is OK.
