Calling ID modifiaction on CUBE
stevenmccormack
Hi all,
I am having trouble to set up number normalisation on a CUBE. I have a provider, which delivers the caller ID on an inbound call in a typical German format (e.g. 069123456 wold be a number in Frankfurt). I want to modify the number to a full E.164 number before sending the call to CUCM so it would look like this: +4969123456. To do so, I have applied a translation profile on the inbound dial-peer:
voice translation-rule 2
rule 1 /^00/ /+/
rule 2 /^0\([1-9]\)/ /+49\1/
voice translation-profile fromSIPProvider
translate calling 2
translate called 1
This profile seems to work, but CUBE only changes the SIP: part in the from header as I found out by a debug ccsip messages:
Received message from provider:
From: "069123456" <sip:069123456@XXX>;tag=as11ff344a
Contact: <sip:0691234562@XXX:5060>
Call-ID: 08e0b06e124f632658f1930e325efaeb@XXX:5060
CSeq: 102 INVITE
Sent to CUCM:
Remote-Party-ID: "069123456" <sip:+4969123456@ZZZ>;party=calling;screen=no;privacy=off
From: "069123456" <sip:+4969123456@ZZZ>;tag=A55A178-1F77
The voice translation profile does not modify the first part in the Remote-Party-ID: of From: header. Does anybody know if there is a way to strip this part or apply the same translation here as well?
Steven
2 Accepted Solutions
paolo bevilacqua
You can use SIP profiles for that.
Ayodeji Okanlawon
Steven,
You cant use sip profiles in the inbound direction. Sip can onle be applied to outbound direction from CUBE to ITSP, not the other way around. So the only option you have is to use SIP normalization script on cucm if your version supports it. You need CUCM 8.5 and above to use it...
Out of curiosity whaty problems is this creating for you?
This value is just a display name and it is an optional parameter...Is this what is presented on your CLI?
Please rate all useful posts
"opportunity is a haughty goddess who waste no time with those who are unprepared"
paolo bevilacqua
Ayodeji Okanlawon
Steven,
stevenmccormack
Hi all,
thanks for the info. You are both correct. I added the following to my config to solve the issue:
voice class sip-profiles 100
request INVITE sip-header Remote-Party-ID remove
request INVITE sip-header From modify "From: (.*<)(.*>)" "From: <\2"
Then I applied this to the outbound dial-peer pointing to CUCM
Steven
Steven,
Thanks for the update and nice rating. I have infact gotten some clarification to the direction of application of the sip profiles
According to Cisco DOC
The SIP profiles feature affects only outgoing SIP messages. The rules are applied as the last step before the message leaves the CUBE router; that is, after destination dial-peer matching has taken place. Changes to the SIP messages are not remembered or acted on by the CUBE application.
This means that it can apply to outbound messages to CUCM or to ITSP. I always thought it was to the ITSP
