09-16-2015 05:02 AM - edited 03-17-2019 04:19 AM
Recently i configured CUCM with MGCP ( CUCM-MGCP-GW-ISDN). But the incoming number ( calling number from pstn to internal) displays only nine digits ( first 0 dosent display, eg : 413428912 instead of 0413428912).
Please advise
Suchira
Solved! Go to Solution.
09-17-2015 05:14 AM
So you have various options in CUCM to add '0' as prefix to CLI. You can do it on Gateway configuration (inside CUCM) on the basis of number type (viz national, subscriber etc) or use calling party transformation.
09-17-2015 05:15 AM
Go to your gateway>incoming calling party settings>Number type
set the ff:
National Number--under the prefix colum remove the default and add 0,
international--uder the prefix column remove the default and add 011
untick use device pool css..
Save,
then do
"conf t
no mgcp
mgcp"
NB: This is service disrupting as active calls will be dropped once you do a no mgcp..do do it at a less busy time
09-16-2015 05:07 AM
What TELCO is sending? Please verify the same using debug isdn q931 and share the output.
09-17-2015 04:20 AM
below is the debug & Telco sends only 9 digits.What is the best way to add aonther digit?
Sep 17 11:17:12.504: ISDN Se0/0/0:15 Q931: RX <- SETUP pd = 8 callref = 0x0073
Sending Complete
Bearer Capability i = 0x8090A3
Standard = CCITT
Transfer Capability = Speech
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0xA18385
Preferred, Channel 5
Calling Party Number i = 0x2183, '413427982'
Plan:ISDN, Type:National
Called Party Number i = 0xC1, '85877576'
Plan:ISDN, Type:Subscriber(local)
Sep 17 11:17:12.520: ISDN Se0/0/0:15 Q931: TX -> CALL_PROC pd = 8 callref = 0x8073
Channel ID i = 0xA98385
Exclusive, Channel 5
Sep 17 11:17:12.520: ISDN Se0/0/0:15 Q931: TX -> ALERTING pd = 8 callref = 0x8073
Progress Ind i = 0x8088 - In-band info or appropriate now available
Sep 17 11:17:20.588: ISDN Se0/0/0:15 Q931: TX -> CONNECT pd = 8 callref = 0x8073
Sep 17 11:17:20.608: ISDN Se0/0/0:15 Q931: RX <- CONNECT_ACK pd = 8 callref = 0x0073
Sep 17 11:17:29.444: ISDN Se0/0/0:15 Q931: TX -> DISCONNECT pd = 8 callref = 0x8073
Cause i = 0x8090 - Normal call clearing
Sep 17 11:17:29.512: ISDN Se0/0/0:15 Q931: RX <- RELEASE pd = 8 callref = 0x0073
Sep 17 11:17:29.536: ISDN Se0/0/0:15 Q931: TX -> RELEASE_COMP pd = 8 callref = 0x8073
09-17-2015 05:14 AM
09-17-2015 05:15 AM
set the ff:
Save,
then do
"conf t
no mgcp
mgcp"
09-16-2015 07:05 AM
this is usual behaviour from some telco's.
therefore if you have something like an inbound dial-peer as below - then you can direct the call as you please:
dial peer voice 10 pots
incomng called number .
direct inward dial
port y/y/y:15
that will be for the incoming call leg
then you can create a dial-peer for the voip call leg which will be outbound towards the cucm server
dial peer voice 20 voip
Destination pattern <pattern>
session target ipv4: <cucm ip address>
voice class codec <number>
09-16-2015 07:21 AM
Imran,
This is mgcp gateway. Calls are not routed via any dial-peers.
Can you please send your debug isdn q931..so we know if the Telco is sending the leading zero..as said earlier most of them don't send the leading zero. You will need to prefix this in cucm
09-16-2015 10:26 AM
Just adding to Ayodeji, Telco at times (atleast in North America) sends digits per our request (either 4 digit or 10 digits).
Please confirm with the Telco what exactly they are sending and reconfirm with them.
However if the PSTN is not able to send the preceding 0, then you may add it using Translation Pattern or Calling Transformation Pattern.
Could you please describe what is the desired effect you wanted to achieve?
09-16-2015 11:48 AM
0 could be prepended in the inbound gateway config or with a calling party transformation applied to the MGCP T1.
09-16-2015 12:53 PM
I am just going to organize the steps which have been mentioned by the team (as they are relevant to my point of view):
1. Check debug isdn q931 and see what the calling number sent by telco. They might not be sending '0'.
2. Check the debug mgcp packets to see if the gateway is sending '0' to CUCM or it is getting stripped in the gateway
3. If '0' is being sent with calling number to CUCM, generate a DNA report from CUCM to see what is happening to the call and where this is getting stripped in CUCM
09-17-2015 05:34 AM
Thanks guys, it works ....
