Calling number not displayed
Youssef BETTAR
We have a H323 gateway and a CUCM 9.1.2 version, when we receive a call from our E1 line we can see the calling number on the gateway but the calling number is unknown on th phone
11 Replies 11
Ayodeji Okanlawon
Can you share your debug isdn q931..(include calling and called number)
What phone model are you using? Has this worked before or is this a new deployment?
Can you also attach your sh run here
Please rate all useful posts
thank you for your reply.
we have a 7965 whith SCCP45.9-4-2-1S firmware
you can find in attachement the sh run and the debug
Youssef,
Is this your full configuration. I don't see any dial-peers on your gateway. How is the call sent to cucm?
Sorry
dial-peer voice 1123 voip
 destination-pattern 877....
 progress_ind alert enable 8
 progress_ind progress enable 8
 session target ipv4:10.x.x.x
 dtmf-relay h245-alphanumeric
 ip qos dscp cs3 signaling
 no vad
OK..please do another test call and send the ff:
debug voip ccapi inout
debug isdn q931
NB: its important to provide detailed information so we can help as quickly as possible..
ok
Hi Youssef.
On your config do you have an incoming diapeer with incoming calling-number command?
Let us know
Carlo
Please rate all helpful posts "The more you help the more you learn"
Hi Carlo
i have already tested that by adding a incoming calling-number . command but i have the same issue and i have removed it after
Hi.
Can you please send us a full config of your gateway?
A screenshot of H323 gateway configuration page on CUCM would be useful.
Carlo
ok thanks
Hi Youssef
Try this:
dial-peer voice 10 pots
incoming called-number 877T
port 0/0/0:15
direct-inward-dial
Let us now
Carlo
