CallManager call duration limitation
grushetskyj
Hello, all!
I'm just wondering, is it possible to limit call duration? I know
about an option in Service parameters, but there you can limit call
duration only globally for all calls. But I'm searching for more
flexible way to do that, at least I want to be able limit all calls
for certain users. And also, is it possible to limit calls duration at
cisco ios gateway, let's say for pri calls? All your suggestions and
ideas will be appreciated!
hadbou
Level 5
Level 5
You can set a maximum time limit for all the calls on the call manager but not for any specific extension. For doing this go to the CCM Admin page go to Service--->Service Parameters Select the Cisco Callmanager service.There search for the "Maximum Call Duration Timer".We can set the time duration here.
Mahmoud Belhaj
Hello
you can do just max duration for all calls by Service Parameters  or using third-party to do that
