CallManager communication with VoiceGateway
kanwalpreet.s
I am trying to route calls from my internalk VOIP phones to PSTN, my route-pattern is working fine, as whenever i try dial 9 and 7 digit number, it automatically strips 9 but call doesnt go through to Gateway. there is no led initiated on FXO port on Voice Gateway ,
Second issue is When i try to dial in from my Cell Phone, led initiates on FXO port, but after one ring call gets disconnected , because VG is not forwarding call back to callmanager to proceed it to Voip extensions. Though i have configured Hunt list and list groups as well.
6 Replies 6
gogasca
Level 10
Level 10
Which Protocol you are using MGCP or H323.
Could you please upload detailed CCM trace.?
I am using MGCP. VG200 which contains both FXS and FXO ports. VG200 is acting as MGCP gateway . The commands which i configured on VG200 are :
mgcp
mgcp call-agent 192.168.2.4 service mgcp ver 0.1
mgcp dtmf-relay voip codec all out-of-band
ccm-manager mgcp
ccm-manager config
ccm-manager config server 192.168.2.4
dial-peer voice 1 pots
port 1/0/1 (FXO)
application MGCPAPP. Rest my router is full of most of MGCP commands which io downloaded from CallManager
VG#sh voice port 1/0/1
Foreign Exchange Office 1/0/1 Slot is 1, Sub-unit is 0, Port is 1
Type of VoicePort is FXO
Operation State is DORMANT
Administrative State is UP
The Last Interface Down Failure Cause is Administrative Shutdown
Description is not set
Noise Regeneration is enabled
Non Linear Processing is enabled
Non Linear Mute is disabled
Non Linear Threshold is -21 dB
Music On Hold Threshold is Set to -38 dBm
In Gain is Set to 0 dB
Out Attenuation is Set to 3 dB
Echo Cancellation is enabled
Echo Cancellation NLP mute is disabled
Echo Cancellation NLP threshold is -21 dB
Echo Cancel Coverage is set to 8 ms
Playout-delay Mode is set to default
Playout-delay Nominal is set to 60 ms
Playout-delay Maximum is set to 200 ms
Playout-delay Minimum mode is set to default, value 40 ms
Playout-delay Fax is set to 300 ms
Connection Mode is normal
Connection Number is not set
Initial Time Out is set to 10 s
Interdigit Time Out is set to 10 s
Call Disconnect Time Out is set to 60 s
Ringing Time Out is set to 180 s
Wait Release Time Out is set to 30 s
Companding Type is u-law
Region Tone is set for US
Analog Info Follows:
Currently processing none
Maintenance Mode Set to None (not in mtc mode)
Number of signaling protocol errors are 0
Impedance is set to 600r Ohm
Station name None, Station number None
Voice card specific Info Follows:
Signal Type is loopStart
Number Of Rings is set to 1
Supervisory Disconnect is inactive
Answer Supervision is inactive
Hook Status is On Hook
Ring Detect Status is inactive
Ring Ground Status is inactive
Tip Ground Status is inactive
Dial Type is dtmf
Digit Duration Timing is set to 100 ms
InterDigit Duration Timing is set to 100 ms
Pulse Rate Timing is set to 10 pulses/second
InterDigit Pulse Duration Timing is set to 750 ms
Percent Break of Pulse is 60 percent
GuardOut timer is 2000 ms
espereir
Level 5
Level 5
Also, is possible to have the show run? did you check the codecs for the GW region? is CCM stripping the digits or the GW (if it is H323)?
Also, put this command on the GW
> debug ISDN Q931
> term mon
And make a test call; that way we will see if CCM is sending the call to the GW, if it does, you just need to check the disconnect code.
If possible, please upload the debug outputs.
By the way, those commands are for H.323 GWs.
Yes digit 9 is stripping which is before DOT. IP phone shows me remaining 7 characters. Once i dial the number it shows me RING OUT , but i dont hear anything . Second time when i dial, i continuously get busy tone afterwards. No initiation on Voice port(no led) on FXO port.
My point of view is something wrong with the gatyeway because route-pattern is working fine.
I cannot run debug isdn q931, because there is no command like this in my VG200. And second thing, yes CCM is stripping predot digit . I am sure CCM is not sending the call to GW , because there is no led initiattion on VG200 when i try to place the call from IP phone. Though CCM also gives me second Dial Tone. when i press the numbers after 9.
If your outbound dial-peer contains:
destination-pattern 9T
then you don't want to strip that 9 on your route-pattern. The call could be hitting the gateway, however, if destination-pattern is 9T it won't match and hit the voice port.
