callmanager slowness
MahgoubS19
We are experiencing slowness with callmanager and High CPU utilization after upgrading from 3.2.1 to 4.2.1. Below are the symptons:
Loading Call Mgr. Admin pages has been unusually slow.
Going from the "Phone Configuration" page to the "Line Configuration" page has taken upwards of 30 seconds to 1 minute
General page movement/switching is taking longer than usual.
WinMgmt.exe and rgsvc.exe processes have the highest CPU utilization, and the "InsertCDR.exe" is using upwards of ~880MB of memory. Note that there is no tracing or debugging that was turned on recently.
5 Replies 5
Chris Deren
The server resource requirements on CCM 4.2 are drastically higher than the 3.2 version, you actaully need at minimum 1 GB of RAM, but recommanded is 2 GB+, I am assuming you have an older hardware that you may need to upgrade or replace.
HTH,
Chris
Thank you Chris. But we are actually using MCS7845. so I don't think that should be the issue.
Please let me know your input. Many thanks.
s
Hello, Did you ever found the reason, we have the same problem after an upgrade to 4.2.1.
Many Thanks
Dirk
Sorry to hijack this thread, i am having the exact same problem on a CCM 4.1(3) with 2GB of RAM.
Wonder if anyone has the solution for this?
Eugene
