Callmanager
waldemararaujo
I have a CallManager cluster 7.0, of which one CallManager fails, how do I phones that are registered with the CallManager failed to pass the register with other CallManager
Gordon Ross
Level 9
Level 9
You need to put the phones in a Device Pool that has a Call Manager group that has more than one CallManager in it.
(Oh - and make sure the CallManager process is running on both servers too)
GTG
Please rate all helpful posts.
If CCM process is not running on a server, it won't even be listed in the CUCM group options.
java
if this helps, please rate
