Calls from ALCATEL to CUCM
kingstdz
Hello
we have sip trunk E1 between CUMC 7.x and ALCATEL PBX, calls from cisco to PBX work fine, but from alcatel to cucm not work (before worked fine).
What i should do to fix this problem, no change is made in cucm.
thanks
2 Accepted Solutions
If you don’t even see the call hit the gateway the problem is on the Alcatel side and you’ll need to look at that end.
Response Signature
Best is to run debug isdn q931 and then terminal monitor. If you’d want to see ongoing calls you can do so with show voice call status.
Response Signature
10 Replies 10
b.winter
any more information on the connection would be helpful^^ Which router are you using? How is the router connected with CUCM (via MGCP?)
Which troubleshootings steps have you already done?
Have you checked the logs in the router or CUCM?
And: Why do you still use CUCM 7.x? That's end of everything and not supported anymore since years and years ...
thanks for your reply
SIP trunk is used
i dont know from what to start, just i have checked link E1 is up and green and calls from cucm to alcatel get done
where i can found log cucun , from cucm report?
CUCM 7.x no issue but we are planning to migrate to 12.x, but at this time i must fix the problem.
please give me steps to check why calls from alcatl to cucum no get done.
thanks
Hello waht sh E1 controllers
E1 0/2/0 is up.
Applique type is Channelized E1 - balanced
Cablelength is Unknown
No alarms detected.
alarm-trigger is not set
Version info Firmware: 20100222, FPGA: 13, spm_count = 0
Framing is NO-CRC4, Line Code is HDB3, Clock Source is Line.
Data in current interval (688 seconds elapsed):
0 Line Code Violations, 324 Path Code Violations
0 Slip Secs, 1 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins
0 Errored Secs, 0 Bursty Err Secs, 1 Severely Err Secs, 0 Unavail Secs
Total Data (last 74 15 minute intervals):
1 Line Code Violations, 74868 Path Code Violations,
3 Slip Secs, 4 Fr Loss Secs, 1 Line Err Secs, 0 Degraded Mins,
3 Errored Secs, 0 Bursty Err Secs, 4 Severely Err Secs, 5 Unavail Secs
Correct me if I'm wrong, your setup looks like this:
Alcatel <--> E1 <--> Cisco Router <--> SIP Trunk <--> CUCM
Are you seeing the incoming calls from Alcatel hitting the Cisco router?
Also, collect the logs of the Cisco router of the debugs:
debug isdn q931
debug ccsip messages
debug voice ccapi ind 1
debug voice ccapi ind 2
debug voice ccapi ind 74
hello
yes the schema is right as you had make it.
no i cant see the incoming and nothing is showing
dl-gw3845#debug isdn q931
debug isdn q931 is ON.
dl-gw3845#debug ccsip messages
SIP Call messages tracing is enabled
dl-gw3845#debug voice ccapi ind 1
voip ccapi individual debugging is on
dl-gw3845#debug voice ccapi ind 2
dl-gw3845#debug voice ccapi ind 74
dl-gw3845#sh debug
Collect:
The following ISDN debugs are enabled on all DSLs:
debug isdn error is ON.
debug isdn q931 is ON. (filter is OFF)
CCAPI:
debug voip ccapi individual is ON (filter is OFF)
1 2 74
CCSIP SPI: SIP Call Message tracing is enabled (filter is OFF)
thanks for your help
Response Signature
My colleagues at alcatel say to me everthinhg are ok but i ll request them to reset pri alcatel.
Please can you show how to see incoming  calls in gateway cisco.
Because with debug i see nothing.
Response Signature
Hi and thanks
here are what i see
Mar 24 05:32:22.862: %OIR-3-SEATED: Insert/removal failed for slot 2, check card sesh voice c
Mar 24 05:32:28.230: %OIR-3-SEATED: Insert/removal failed for slot 2, check card seatingall st
dl-gw3845#sh voice call status
CallID CID ccVdb Port Slot/DSP:Ch Called # Codec MLPP Dial-peers
No active calls found
and
#sh inventory
NAME: "3845 chassis", DESCR: "3845 chassis"
PID: CISCO3845 , VID: V05 , SN: FHK1418F006
NAME: "c3845 Motherboard with Gigabit Ethernet on Slot 0", DESCR: "c3845 Motherboard with Gigabit Ethernet"
PID: CISCO3845-MB , VID: V08 , SN: FOC14152RBD
NAME: "9 Port FE Switch on Slot 0 SubSlot 1", DESCR: "9 Port FE Switch"
PID: HWIC-D-9ESW , VID: V01 , SN: FOC14174JEM
NAME: "VWIC2-2MFT-T1/E1 - 2-Port RJ-48 Multiflex Trunk - T1/E1 on Slot 0 SubSlot 2", DESCR: "VWIC2-2MFT-T1/E1 - 2-Port RJ-48 Multiflex Trunk - T1/E1"
PID: VWIC2-2MFT-T1/E1 , VID: V01 , SN: FOC14011269
NAME: "2nd generation four port FXO voice interface daughtercard on Slot 0 SubSlot 3", DESCR: "2nd generation four port FXO voice interface daughtercard"
PID: VIC2-4FXO , VID: V03 , SN: FOC14090F0R
NAME: "PVDMII DSP SIMM with four DSPs on Slot 0 SubSlot 4", DESCR: "PVDMII DSP SIMM with four DSPs"
PID: PVDM2-64 , VID: V01 , SN: FOC14106DT0
NAME: "Virtual Private Network (VPN) Module on Slot 0", DESCR: "Encryption AIM Element"
PID: AIM-VPN/SSL-3 , VID: V01, SN: FOC14043WSQ
NAME: "High Density Analog Voice Module on Slot 1", DESCR: "High Density Analog Voice Module"
PID: NM-HDA-4FXS , VID: V01 , SN: FOC13442LWY
NAME: "EM2-HDA-4FXO Expansion Module (4 port) on Slot 1 SubSlot 0", DESCR: "EM2-HDA-4FXO Expansion Module (4 port)"
PID: EM2-HDA-4FXO , VID: V02 , SN: FOC13264FJZ
NAME: "EM2-HDA-4FXO Expansion Module (4 port) on Slot 1 SubSlot 1", DESCR: "EM2-HDA-4FXO Expansion Module (4 port)"
PID: EM2-HDA-4FXO , VID: V02 , SN: FOC13205A08
what i can do to fix it.
thanks
hi
after have rebooted gateway
and make sh voice calls status
CallID CID ccVdb Port Slot/DSP:Ch Called # Codec MLPP Dia l-peers
0x13 1C23 0x696743A8 0/2/0:15.31 0/1:1 *27013061 g711ulaw 20 /2
1 active call found
called *27013061 i can understand it and i dont found it , i make call for 21057002 (alcatel)
thanks
