Calls going to wrong CSS
we recently configured branch Gateway for the PSTN calls originating from the brach should routed through PSTN line connected on FXO ports
we have call manager cluster at the Head Office, The internal calls to Headoffice have no problem.
but when the brach office dials any PSTN number its asking for FAC and CMC codes,eventhough i didn't configure the route pattern for FAC and CMC(they can call without codes).
The route Pattern is -----9.!
The partition   BR_PT_INTERNATIONAL
css    BR_CSS_INTERNATIONAL
gatway/Route List   LOCAL ROUTE LIST
Route Group   JED_RG
Gateway ip  192.168.21.5  which is H.323 gateway connecting to call manager at Head Office throug HO gateway 192.168.12.5 over MPLS
I thought there is a problem with Route pattern...but after all R&D also i cannot solve this
Please can any one help
12 Accepted Solutions
Abzal
Level 7
Level 7
Route pattern need to point PSTN gateway on the Branch. Assumed that partitions and CSS are correct.
Hope it will help.
Best regards,
Abzal
Best regards,
Abzal
Harmit Singh
Hi Mohammed,
Just in case DNA shows the call should route as described by Aaron, let's get detailed CUCM SDI and SDL traces for one such outbound call. Please collect the detailed CUCM traces from all nodes in the cluster, do mention the calling and called party numbers, timestamp of the call, IP address and hostname of all CUCM nodes in the cluster and IP address of IP phone. Please collect traces 5 minutes before and 5 minutes after the test call made (total of 10 minutes). Here is a link which should help set this up:
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_tech_note09186a0080094e89.shtml#calm
Please also mention the exact version of CUCM you are running.
Harmit.
DNA is easier than traces.
Basically your Route Pattern is probably correct, but your call is matching a different one.
CUCM assembles a list of all diallable patterns, made up of all the numbers/patterns in all the partitions that make up the CSS (or device + line CSSs) that are assigned to the device that is dialling.
DNA will show you what is being matched without having to look through traces.
Aaron
Aaron Please remember to rate helpful posts to identify useful responses, and mark 'Answered' if appropriate!
Hi Mohammed,
Try the DNA first. Traces need to be looked into if DNA reports everything is in order and the call should route.
Harmit.
Hi Mohammed,
The Dialed Number should be the international number you would dial from your IP Phone. You mentioned "11" which is why it is showing unallocated number.
Harmit.
Mohammed - Is the FAC_CSS_mobile correct CSS? The name is  suggesting its used for FAC, Also you are dialing 11? If I understand correctly you want to hit a  route pattern with 9.! in Partition
BR_PT_INTERNATIONAL and route directly without FAC.
If thats the case, does yours phone's CSS or the CSS at Line level has this partition (BR_PT_INTERNATIONAL) assigned in it?  You can attach screenshot of Route Pattern and Your CSS (both if applied  at phone and line level or whichever is applicable) showing the  partitions, if you are not sure.
Even when you try DNA, use the same CSS on your PHONE\LINE and dialed number 90542014824 (you mentioned above) to get correct results.
Terry
Mohammed,
If you can post the DNA results with the correct details will be more helpful. But if you are not able to get results then please post the below:
Can you click on the route pattern 9.! and post the screen shot of this route pattern details?
Can you click on the CSS - BR_CSS_INTERNATION, open the CSS page details and post the screenshoot? I beleive this is the one applied at Line CSS of phone?
Also whats the exact message you are getting when you try to dial this number? Are you getting fast busy?
Terry
Hi Mohammed,
Looking at the DNA output:
  " LineCSS="BR_CSS_INTERNATIONAL" AARGroup=" " AARCSS=" " />
  90542014824
  RouteThisPattern
  0542014824
  No
  No
So it looks like the right CSS and partition is being matched. When you say, the call again got disconnected, did it prompt you for the FAC/CMC code? If yes, are you sure it is coming from the CUCM and not from the Telco? Can you connect an analog phone to the FXO lines and make an international call successfully?
Harmit.
Hi Mohammed,
That's good to know that you dont hear the prompt for FAC/CMC anymore. Based on what you mentioned, only the mobile calls are getting disconnected. Have mobile calls worked successfully on these FXOs before?
Can you run the following debugs for one test call:
debug mgcp packets
debug voip ccapi inout
debug vpm signal
debug voip vtsp default
debug voip vtsp session
Once the call disconnects, capture the following output:
Show voice trace
This would help us to see if the call is hitting the FXO port or terminating before hand.
Harmit.
Hi Mohamed,
Thanks for sharing the resolution (+5), glad we could help! :-)
Harmit.
techguy
Level 4
Level 4
Use unity express (cue) make cti route point and ports. Your calls will goto cucm and greeting message will be heard from cue
Sent from Cisco Technical Support Android App
Hi Mohammed,
No worries :-)
You've correctly identified a few possiblities for implementing an Auto Attendant:
1>     Install a Unity Express at the branch site, where the calls can be sent for the Autoattendant script. This would avoid bandwidth consumption over the WAN.
2>     Utilize the existing Unity / Unity Connection system at the Head Office for calls to be sent to an Autoattendant Greeting. Bandwidth utilization can be reduced by using G729 codec. Once the call is transferred to an IP Phone at the branch site, the bandwidth utilized over the WAN would be released.
3>     I believe you should be able to create a TCL script on the remote gateway itself which would let you route the call to the branch phones.
Please review the design guide for Unity Connection (assuming you have Unity Connection) and SRND for CUCM:
http://www.cisco.com/en/US/docs/voice_ip_comm/connection/8x/design/guide/8xcucdg050.html#wp1085205
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/srnd/8x/vmessage.html#wp1086561
HTH.
Harmit.
23 Replies 23
Abzal
Level 7
Level 7
Hope it will help.
Best regards,
Abzal
Best regards,
Abzal
Aaron Harrison
Go to /dna
If you get a not found, verify in serviceability that you have activated Dialed Number Analyser.
That page will give you a diagnostic tool, you can click Analysis/Analyse and put in the CSS you have assigned, and the number the user is dialling. That will show you where the call actually routes.
Aaron
Harmit Singh
Hi Mohammed,
Harmit.
Hi Abzal,
Thanks for reply
I think the route pattren Pointing to correct Gateway which is 192.168.21.5
Dear Aaron and Harmit,
thankyou..
i collected the traces for a perticular phone that is 2001 and collected the log files using RTMT but from where can i get the traces...the location it showing is
/this/path/is/not/set\2013-01-21_11-24-41\
and the details of the phone and Nodes are
iam using  CUCM 8.6.2.20000-2
Node 1 : 192.168.12.190  hostname CUCM-1
node 2 :  192.168.12.189  hostname CUCM-2
Phone Ip Address  192.168.21.12
Calling Party Number 2001
Called Party NUmber 90542014824  (9 will be stripped)
Aaron
Hi Aaron,
but i am not able see any thing in DNA analyzer.
the Output i am getting is not showing other than calling party partial information.
Hi Mohammed,
Harmit.
Hi  harmit,
the number i am dialing is of 10 digits and i am prefixing 9 before the number for outgoing calls.
shell i include that number 90542014824 as 11 digits or shall dial international number
Hi Mohammed,
Harmit.
Terry
hi terry ,
sorry , that is my mistake...
the phone 2001 has FAC but the other phone(2088 CIPC) i tried using was international...
both the phones giving the same result call disconnection.
i am attaching the Route Pattern and Partition and CSS screen shots for branches
hi all
when i am using the phone number in dialed digits i can see the call
originating from the phone 2002 to 90542014824
the route list is LOCAL ROUTELIST which i configured for the Branches.
i chaned the route pattern to BR_PT_INTERNATIONAL  so it should not prompt for code.
the route group is also ok
but the call againg got disconnected.
Mohammed,
Terry
hi all
