calls work with g711 and some calls dont with g729
adavila03
I´ve been having this issue, we have a reserved BW of 128k with the carrier for calls(512k total) , when we make calls (8 calls)using codec g711 and going through the E&M ports (calls coming from the cloud and passing through router 2800 to PBX avaya) they work well , good quality,etc.. but when we setup an ip trunk  between the cisco 2800 and avaya  only 6 out of 8 calls work well , the 7th and 8th call get poor quality.. QoS is setup, codecs are setup...
the picture is  --> PBX avaya-- Router Cisco-- MPLS- Router Cisco 2800 -- E&M-- PBX avaya   --> 8 calls work well
                              PBX avaya-- Router Cisco-- MPLS- Router Cisco 2800 -- IP trunk-- PBX avaya  ---> only 6 calls work well, 7th and 8th not.
G711 consumes 64k or more per call and g729 around 30k , I guess we could get more calls passing through because they are compressing? ... any suggestions why this can be occurring ?
11 Replies 11
paolo bevilacqua
If it was a BW problem, all calls would equally suffer in quality.
But you say that only the 7th and 8th call do, that points to a device issue.
You have not said if the issue is in both directions or one only.
And have not incuded any trace or trobleshoot here, so it's impossible to say what's causing it.
Anyway, have you considered it can be a problem on the PBX and not with routers or the network ?
Hi Paolo,
This happens in both directions and this could be as yo say the PBX but havent found the root issue. I got some debugs using debug debug voip ccapi inout , do you use any other command than might be helpful?
*Jun 20 11:17:52.435: //16462/007AA4B8AC12/CCAPI/cc_api_call_disconnected:
   Cause Value=16, Interface=0x64F3FAB4, Call Id=16462
   Call Entry(Responsed=TRUE, Cause Value=16, Retry Count=0)
*Jun 20 11:17:52.435: //16462/007AA4B8AC12/CCAPI/cc_api_get_transfer_info:
   Transfer Number Is Null
*Jun 20 11:17:52.435: //16461/007AA4B8AC12/CCAPI/ccConferenceDestroy:
   Conference Id=0x1D1B, Tag=0x0
*Jun 20 11:17:52.439: //16461/xxxxxxxxxxxx/CCAPI/cc_api_bridge_drop_done:
   Conference Id=0x1D1B, Source Interface=0x63FBC750, Source Call Id=16461,
   Destination Call Id=16462, Disposition=0x0, Tag=0x0
*Jun 20 11:17:52.439: //16462/xxxxxxxxxxxx/CCAPI/cc_api_bridge_drop_done:
   Conference Id=0x1D1B, Source Interface=0x63FBC750, Source Call Id=16462,
   Destination Call Id=16461, Disposition=0x0, Tag=0x0
*Jun 20 11:17:52.439: //16461/007AA4B8AC12/CCAPI/cc_generic_bridge_done:
*Jun 20 11:17:52.439: //16461/007AA4B8AC12/CCAPI/ccCallDisconnect:
   Cause Value=16, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=0)
   Cause Value=16, Call Entry(Responsed=TRUE, Cause Value=16)
*Jun 20 11:17:52.439: //16461/007AA4B8AC12/CCAPI/cc_api_get_transfer_info:
*Jun 20 11:17:52.439: //16462/007AA4B8AC12/CCAPI/ccCallDisconnect:
   Cause Value=16, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=16)
*Jun 20 11:17:52.439: //16462/007AA4B8AC12/CCAPI/cc_api_get_transfer_info:
*Jun 20 11:17:52.443: //16462/007AA4B8AC12/CCAPI/cc_api_call_disconnect_done:
   term monitorDisposition=0, Interface=0x64F3FAB4, Tag=0x0, Call Id=16462,
   Call Entry(Disconnect Cause=16, Voice Class Cause Code=0, Retry Count=0)
   Call Disconnect Event Sent
*Jun 20 11:17:52.447: //16461/007AA4B8AC12/CCAPI/ccSaveDialpeerTag:
   Outgoing Dial-peer=0
*Jun 20 11:17:52.651: //16472/E58839038209/CCAPI/cc_api_call_connected:
   Interface=0x64F131E4, Data Bitmask=0x1, Progress Indication=DESTINATION IS NON ISDN(2),
   Connection Handle=0
   Call Entry(Connected=TRUE, Responsed=TRUE, Retry Count=0)
*Jun 20 11:17:52.651: //16471/E58839038209/CCAPI/ccCallConnect:
   Progress Indication=DESTINATION IS NON ISDN(2), Data Bitmask=0x1
   Call Entry(Connected=TRUE, Responsed=TRUE)
*Jun 20 11:17:52.651: //16472/E58839038209/CCAPI/ccSaveDialpeerTag:
   Incoming Dial-peer=0
*Jun 20 11:17:52.651: //16471/E58839038209/CCAPI/ccSaveDialpeerTag:
   Incoming Dial-peer=100
   Outgoing Dial-peer=3800
*Jun 20 11:17:52.655: //16471/E58839038209/CCAPI/ccCallFeature:
   Feature Type=24, Call Id=16471
*Jun 20 11:17:52.655: //16472/E58839038209/CCAPI/ccCallFeature:
   Feature Type=24, Call Id=16472
*Jun 20 11:17:53.847: //-1/ECA27C81820C/CCAPI/cc_api_display_ie_subfields:
   cc_api_call_setup_ind_common:
   cisco-username=200.79.114.190
   ----- ccCallInfo IE subfields -----
   cisco-ani=
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=0
   dest=3878
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdn=
   cisco-rdntype=-1
   cisco-rdnplan=-1
   cisco-rdnpi=-1
   cisco-rdnsi=-1
   cisco-redirectreason=-1
*Jun 20 11:17:53.847: //-1/ECA27C81820C/CCAPI/cc_api_call_setup_ind_common:
   Interface=0x63FBC750, Call Info(
   Calling Number=(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
   Called Number=3878(TON=Unknown, NPI=Unknown),
   Calling Translated=FALSE, Subsriber Type Str=Unknown, FinalDestinationFlag=TRUE,
   Incoming Dial-peer=100, Progress Indication=ORIGINATING SIDE IS NON ISDN(3), Calling IE Present=FALSE,
   Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=16473
*Jun 20 11:17:53.847: //-1/ECA27C81820C/CCAPI/ccCheckClipClir:
   In: Calling Number=(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
   Out: Calling Number=(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
*Jun 20 11:17:53.847: //16473/ECA27C81820C/CCAPI/cc_api_call_setup_ind_common:
   Set Up Event Sent;
   Call Info(Calling Number=(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
   Called Number=3878(TON=Unknown, NPI=Unknown))
*Jun 20 11:17:53.851: //16473/ECA27C81820C/CCAPI/cc_process_call_setup_ind:
   Event=0x6425D020
*Jun 20 11:17:53.851: //16473/ECA27C81820C/CCAPI/ccCallSetContext:
   Context=0x635B0A10
   >>>>CCAPI handed cid 16473 with tag 100 to app "Default"
*Jun 20 11:17:53.851: //16473/ECA27C81820C/CCAPI/ccCallProceeding:
   Progress Indication=NULL(0)
*Jun 20 11:17:53.851: //16473/ECA27C81820C/CCAPI/ccCallSetupRequest:
   Destination=, Calling IE Present=FALSE, Mode=0,
   Outgoing Dial-peer=3800, Params=0x635B5F78, Progress Indication=ORIGINATING SIDE IS NON ISDN(3)
*Jun 20 11:17:53.851: //16473/ECA27C81820C/CCAPI/ccCheckClipClir:
   Destination Pattern=38.., Called Number=3878, Digit Strip=FALSE
   Redirect Number=, Display Info=
   Account Number=200.79.114.190, Final Destination Flag=TRUE,
   Guid=ECA27C81-9A95-11E0-820C-C79234C48D73, Outgoing Dial-peer=3800
*Jun 20 11:17:53.851: //16473/ECA27C81820C/CCAPI/cc_api_display_ie_subfields:
   ccCallSetupRequest:
   cisco-ani=
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=0
   dest=3878
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdn=
   cisco-rdntype=-1
   cisco-rdnplan=-1
   cisco-rdnpi=-1
   cisco-rdnsi=-1
*Jun 20 11:17:53.851: //16473/ECA27C81820C/CCAPI/ccIFCallSetupRequestPrivate:
   Interface=0x63FBC750, Interface Type=1, Destination=, Mode=0x0,
   Call Params(Calling Number=(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
   Called Number=3878(TON=Unknown, NPI=Unknown), Calling Translated=FALSE,
   Subsriber Type Str=Unknown, FinalDestinationFlag=TRUE, Outgoing Dial-peer=3800, Call Count On=FALSE,
   Source Trkgrp Route Label=, Target Trkgrp Route Label=, tg_label_flag=0, Application Call Id=)
*Jun 20 11:17:53.855: //16474/ECA27C81820C/CCAPI/ccIFCallSetupRequestPrivate:
   SPI Call Setup Request Is Success; Interface Type=1, FlowMode=1
*Jun 20 11:17:53.855: //16474/ECA27C81820C/CCAPI/ccCallSetContext:
   Context=0x635B5F28
*Jun 20 11:17:53.855: //16473/ECA27C81820C/CCAPI/ccSaveDialpeerTag:
*Jun 20 11:17:53.951: //16474/ECA27C81820C/CCAPI/cc_api_call_proceeding:
   Interface=0x63B05898, Progress Indication=NULL(0)
*Jun 20 11:17:53.951: //16474/ECA27C81820C/CCAPI/ccSaveDialpeerTag:
*Jun 20 11:17:53.951: //16473/ECA27C81820C/CCAPI/ccSaveDialpeerTag:
*Jun 20 11:17:54.147: //16474/ECA27C81820C/CCAPI/cc_api_event_indication:
   Event=79, Call Id=16474
   Event Is Sent To Conferenced SPI(s) Directly
*Jun 20 11:17:54.151: //16474/ECA27C81820C/CCAPI/cc_api_call_cut_progress:
   Interface=0x63B05898, Progress Indication=NOT END TO END ISDN(1), Signal Indication=SIGNAL RINGBACK(1),
   Cause Value=0
   Call Entry(Responsed=TRUE)
*Jun 20 11:17:54.151: //16473/ECA27C81820C/CCAPI/ccCallCutProgress:
   Progress Indication=NOT END TO END ISDN(1), Signal Indication=SIGNAL RINGBACK(1), Cause Value=0
   Voice Call Send Alert=FALSE, Call Entry(AlertSent=FALSE)
*Jun 20 11:17:54.151: //16474/ECA27C81820C/CCAPI/ccSaveDialpeerTag:
*Jun 20 11:17:54.151: //16473/ECA27C81820C/CCAPI/ccSaveDialpeerTag:
*Jun 20 11:17:54.151: //16473/ECA27C81820C/CCAPI/ccGenerateToneInfo:
   Stop Tone On Digit=FALSE, Tone=Null,
   Tone Direction=Network, Params=0x0, Call Id=16473
*Jun 20 11:17:54.151: //16473/ECA27C81820C/CCAPI/ccConferenceCreate:
   Conference Id=0x64ED1CEC, Call Id1=16473, Call Id2=16474, Tag=0x0
*Jun 20 11:17:54.151: //16473/xxxxxxxxxxxx/CCAPI/cc_api_bridge_done:
   Conference Id=0x1D21, Source Interface=0x63FBC750, Source Call Id=16473,
   Destination Call Id=16474, Disposition=0x0, Tag=0x0
*Jun 20 11:17:54.151: //16474/xxxxxxxxxxxx/CCAPI/cc_api_bridge_done:
   Conference Id=0x1D21, Source Interface=0x63FBC750, Source Call Id=16474,
   Destination Call Id=16473, Disposition=0x0, Tag=0x0
*Jun 20 11:17:54.151: //16473/ECA27C81820C/CCAPI/cc_generic_bridge_done:
   Call Entry(Conference Id=0x1D21, Destination Call Id=16474)
*Jun 20 11:17:54.151: //16474/ECA27C81820C/CCAPI/ccConferenceCreate:
   Call Entry(Conference Id=0x1D21, Destination Call Id=16473)
*Jun 20 11:17:54.151: //16473/ECA27C81820C/CCAPI/cc_process_notify_bridge_done:
   Conference Id=0x1D21, Call Id1=16473, Call Id2=16474
*Jun 20 11:17:54.443: //16461/007AA4B8AC12/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x64D8AEA0, Tag=0x0, Call Id=16461,
*Jun 20 11:18:13.939: //16474/ECA27C81820C/CCAPI/cc_api_call_connected:
   Interface=0x63B05898, Data Bitmask=0x0, Progress Indication=NULL(0),
   Connection Handle=0
*Jun 20 11:18:13.939: //16473/ECA27C81820C/CCAPI/ccCallConnect:
   Progress Indication=NULL(0), Data Bitmask=0x0
*Jun 20 11:18:13.943: //16473/ECA27C81820C/CCAPI/ccCallConnect:
*Jun 20 11:18:13.943: //16474/ECA27C81820C/CCAPI/ccSaveDialpeerTag:
*Jun 20 11:18:13.943: //16473/ECA27C81820C/CCAPI/ccSaveDialpeerTag:
*Jun 20 11:18:13.943: //16473/ECA27C81820C/CCAPI/ccCallFeature:
   Feature Type=24, Call Id=16473
*Jun 20 11:18:13.943: //16474/ECA27C81820C/CCAPI/ccCallFeature:
   Feature Type=24, Call Id=16474 *Jun 20 11:17:52.435: //16462/007AA4B8AC12/CCAPI/cc_api_call_disconnected:
   Connection Handle=0
   cisco-ani=
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=0
   dest=3878
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdn=
   cisco-rdntype=-1
   cisco-rdnplan=-1
   cisco-rdnpi=-1
   cisco-rdnsi=-1
   Set Up Event Sent;
   Event=0x6425D020
   Context=0x635B0A10
   ccCallSetupRequest:
   cisco-ani=
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=0
   dest=3878
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdn=
   cisco-rdntype=-1
   cisco-rdnplan=-1
   cisco-rdnpi=-1
   cisco-rdnsi=-1
   Context=0x635B5F28
   Cause Value=0
   Connection Handle=0
No unfortunately that debug doesn't help.
Are you the end user? If yes, do you work with a cisco partner on this ?
I´m working with a cisco partner but the voice guys are out of the office for now and I´m new with the voice thing so I´ve been reading stuff about it..  which commands could get me the most info possible to troubleshoot this? so I want to get info about why the calls through E&M work well and the calls(6 out of 8) passing through the ip trunk dont.. even though the G729 consumes less BW...
thanks again!
That can be not so easy to diagnose, you really want to work with an experienced person on this.
thanks any way !
As Paolo mentioned, I think this problem would make a lot more sense if it was all 8 calls that were suffering, as that would probably indicate a bandwidth issue once you add overhead to your 64k calls. If that's not the case then as mentioned by Paolo you should consult your voice guys or partners
HTH,
Chris
Thanks Chris, but I just want to know this .. it´s another scenario...... I have 4 calls going through the E&M ports like this
PBX-->Router-->MPLS-->Router--E&M-- PBX . The QoS hired to the provider is 64k and the BW link is 256k using frame-relay connection... the 4 calls work well in both directions and being in use at the same time .. but they supossed to be around 256k or more , dont they? how come they work well if I only have 64k QoS hired and each call consumes more than 64k??  this is a real scenario ....
I appreciate your comments !
The fact you paid for a certain guaranted bandwidth doesn't mean you can't use more.
ok, now in other location I have 8 calls going through the E&M ports like this
PBX-->Router-->MPLS-->Router--E&M-- PBX . The QoS hired to the provider is 128k and the BW link is 512k using frame-relay connection... the 8 calls work well in both directions and being in use at the same time then I change to this
PBX-->Router-->MPLS-->Router--H323 trunk-- PBX using codec G729r8 and only 6 calls work well in both directions the other two do not....
Have you had anything similar to this before?
As mentioned before already to you, need to work with a person of expertise on this.
