05-14-2019 08:55 AM
Can a Route Pattern be assigned to a Gateway that ISN'T in a Route Group or is it essential that the gateway is part of a Route group before the route pattern is assigned?
Solved! Go to Solution.
05-14-2019 09:29 AM
You can assign a GW/trunk directly to a route pattern, but you cannot use that GW/trunk in any other route group or route pattern.
05-14-2019 09:29 AM
05-14-2019 09:35 AM
Ok, would that ever happen, what type of scenario?
