Can a Route Pattern be assigned to a Gateway that ISN'T in a Route Group?
lowfell
Level 3
Level 3
Can a Route Pattern be assigned to a Gateway that ISN'T in a Route Group or is it essential that the gateway is part of a Route group before the route pattern is assigned?
Jaime Valencia
You can assign a GW/trunk directly to a route pattern, but you cannot use that GW/trunk in any other route group or route pattern.
java
if this helps, please rate
Jaime Valencia
java
Ok, would that ever happen, what type of scenario?
