Can i connect my home Land Line (RJ11) to FXO port on Cisco router and test some voice stuff
Ibrahim Jamil
Level 6
Level 6
11 Replies 11
balaji.bandi
yes FXO support incoming and out going calls
BB
Yes You can connect and do the testing.
Response Signature
Yes
Response Signature
Ibrahim Jamil
Level 6
Level 6
Hi all
Pls a decent configuration example to follow it up
thanks all
Below example is one which i use in my region.
voice class custom-cptone 1
dualtone disconnect
frequency 427
cadence 300 300
voice-port 0/1/0
supervisory custom-cptone 1
ring number 3
cptone OM
connection plar opx 1000
caller-id enable
voice hunt-group 4 parallel
list 8414,8428,8413,8418
pilot 1000
Response Signature
Hi nithin
thanks
i need to understand the syntax how it looks like  , i never dealt with FXO/FXS , we are using CUBE
thanks
Look at @Nithin Eluvathingal example and modify it to fit the area of the world where your located. Otherwise there are plenty of configuration documentation and examples available if you put a couple of minutes in on any search engine of your choice.
Response Signature
Hi Balaji
Thanks for Helping , mate , do u have decent video config example?
In what sense do you mean video in combination with FXO?
Response Signature
