I believe you are referring to Audio Tuning wizard. Ideally it should not appear every time just once when you set up CIPC.
Can you try to launch CIPC in "Run As Administrator" mode and then if it comes, follow all the steps right till you do not get the Finish option and then check.
If this also does not resolve, then probably try uninstalling and reinstalling the CIPC again.
Deepak
