10-17-2022 06:33 AM
Good day,
Trying to get a outbound call working through a single line connected to fxo port. first call always works, ( have tested with international, national and mobile ). i hang up and try calling again, it gives a busy tone till i reload the router. Anything to check or try to get that sorted out. Given below is the debug logs that showed up on the router when dialing out. Voice ports are showing on hook . sh run attached.
Router#sh voice port su
Router#sh voice port summary
IN OUT
PORT CH SIG-TYPE ADMIN OPER STATUS STATUS EC
0/1/0 -- fxo-ls up dorm idle on-hook y
0/1/1 -- fxo-ls up dorm idle on-hook y
0/2/0 -- fxo-ls up dorm idle on-hook y
0/2/1 -- fxo-ls up dorm idle on-hook y
0/2/2 -- fxo-ls up dorm idle on-hook y
0/2/3 -- fxo-ls up dorm idle on-hook y
PWR FAILOVER PORT PSTN FAILOVER PORT
Router#
445: *Oct 17 13:23:48.853: //50/C47E15DC8068/
------------------ Cover Buffer ---------------
Search-key = 801:0508363235:50
Timestamp = *Oct 17 13:23:48.251
CallID = 50
Peer-CallID = NA
Correlator = NA
Called-Number = 0508363235
Calling-Number = 801
SIP CallID = 00df1d88-6a200007-40dbbd29-2451d9cc@10.90.80.3
SIP SessionID =
GUID = C47E15DC8068
416: *Oct 17 13:23:48.251: //50/C47E15DC8068/CUBE_VT/SIP/Msg/ccsipDisplayMsg:
Received:
INVITE sip:0508363235@10.90.80.1;user=phone SIP/2.0
Via: SIP/2.0/UDP 10.90.80.3:5060;branch=z9hG4bK47f93dda
From: "Basel Thaher " <sip:801@10.90.80.1>;tag=00df1d886a20001c31ce4143-3531f195
To: <sip:0508363235@10.90.80.1>
Call-ID: 00df1d88-6a200007-40dbbd29-2451d9cc@10.90.80.3
Max-Forwards: 70
Session-ID: 4dfbd3e200105000a00000df1d886a20;remote=0000000000000000000000000000 0000
Date: Mon, 17 Oct 2022 13:23:47 GMT
CSeq: 101 INVITE
User-Agent: Cisco-CP7811/14.1.1
Contact: <sip:1A694-BD@10.90.80.3:5060;transport=udp>;+u.sip!devicename.ccm.cisc o.com="SEP00DF1D886A20"
Expires: 180
Accept: application/sdp
Allow: ACK,BYE,CANCEL,INVITE,NOTIFY,OPTIONS,REFER,REGISTER,UPDATE,SUBSCRIBE,INFO
Remote-Party-ID: "Basel Thaher " <sip:801@10.90.80.1>;party=calling;id-type=subs criber;privacy=off;screen=yes
Supported: replaces,join,sdp-anat,norefersub,resource-priority,extended-refer,X- cisco-callinfo,X-cisco-serviceuri,X-cisco-escapecodes,X-cisco-service-control,X- cisco-srtp-fallback,X-cisco-monrec,X-cisco-config,X-cisco-sis-7.0.0,X-cisco-xsi- 8.5.1
Allow-Events: kpml,dialog
Recv-Info: conference
Recv-Info: x-cisco-conference
Authorization: Digest username="801",realm="",uri="sip:0508363235@10.90.80.1;use r=phone",response="d3cc0a64befe157d795b079ad6492ec0",nonce="17175C020025C2A1",cn once="23389a8e",qop=auth,nc=00000002,algorithm=MD5
Content-Length: 345
Content-Type: application/sdp
Content-Disposition: session;handling=optional
v=0
o=Cisco-SIPUA 28297 0 IN IP4 10.90.80.3
s=SIP Call
b=AS:4064
t=0 0
m=audio 24366 RTP/AVP 0 8 116 18 101
c=IN IP4 10.90.80.3
b=TIAS:64000
a=rtpmap:0 PCMU/8000
a=rtpmap:8 PCMA/8000
a=rtpmap:116 iLBC/8000
a=fmtp:116 mode=20
a=rtpmap:18 G729/8000
a=fmtp:18 annexb=no
a=rtpmap:101 telephone-event/8000
a=fmtp:101 0-15
a=sendrecv
420: *Oct 17 13:23:48.251: //50/C47E15DC8068/CUBE_VT/SIP/FSM/SPI-State-Change: C urrent State = STATE_NONE, Next State = STATE_IDLE, Current Sub-State = STATE_NO NE, Next Sub-State = STATE_NONE
421: *Oct 17 13:23:48.252: //50/C47E15DC8068/CUBE_VT/SIP/MISC/Matched Dialpeer: Dir:Inbound, Peer-Tag: 40001
422: *Oct 17 13:23:48.252: //50/C47E15DC8068/CUBE_VT/SIP/FSM/Offer-Answer: Event = E_SIP_INVITE_SDP_RCVD, Current State = S_SIP_EARLY_DIALOG_IDLE, Next State = S_SIP_EARLY_DIALOG_OFFER_RCVD
423: *Oct 17 13:23:48.253: //50/C47E15DC8068/CUBE_VT/SIP/FSM/IWF: Event = E_SIP_ IWF_EV_RCVD_SDP, Current State = S_SIP_IWF_SDP_IDLE, Next State = S_SIP_IWF_SDP_ RCVD_AWAIT_PEER_EVENT
424: *Oct 17 13:23:48.253: //50/C47E15DC8068/CUBE_VT/SIP/MISC/Media Stream Param eters: Stream Type = voice-only, Stream State = STREAM_ADDING Negotiated Codec = g711ulaw, Negotiated DTMF Type = inband-voice, Stream Index = 1
425: *Oct 17 13:23:48.253: //50/C47E15DC8068/CUBE_VT/SIP/API: cc_api_update_inte rface_cac_resource (0)
426: *Oct 17 13:23:48.253: //50/C47E15DC8068/CUBE_VT/SIP/API: voip_rtp_allocate_ port (8024)
427: *Oct 17 13:23:48.253: //50/C47E15DC8068/CUBE_VT/SIP/MISC/Media Stream Param eters: Stream Type = voice-only, Stream State = STREAM_ADDING Negotiated Codec = g711ulaw, Negotiated DTMF Type = inband-voice, Stream Index = 1
428: *Oct 17 13:23:48.253: //50/C47E15DC8068/CUBE_VT/SIP/API: cc_api_call_setup_ ind_with_callID (0)
429: *Oct 17 13:23:48.253: //50/C47E15DC8068/CUBE_VT/SIP/FSM/SPI-State-Change: C urrent State = STATE_IDLE, Next State = STATE_RECD_INVITE, Current Sub-State = S TATE_NONE, Next Sub-State = STATE_NONE
430: *Oct 17 13:23:48.255: //50/C47E15DC8068/CUBE_VT/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
Date: Mon, 17 Oct 2022 13:23:48 GMT
CSeq: 101 INVITE
Allow-Events: telephone-event
Server: Cisco-SIPGateway/IOS-17.3.5
Session-ID: 00000000000000000000000000000000;remote=4dfbd3e200105000a00000df1d88 6a20
Content-Length: 0
431: *Oct 17 13:23:48.255: //50/C47E15DC8068/CUBE_VT/SIP/MISC/Call Disconnect: I nitiated at: 0x260070A, Originated at:0x260070B, Cause Code = 28
432: *Oct 17 13:23:48.255: //50/C47E15DC8068/CUBE_VT/SIP/API: cc_api_update_inte rface_cac_resource (0)
433: *Oct 17 13:23:48.255: //50/C47E15DC8068/CUBE_VT/SIP/FSM/Event-Action: Event = SIPSPI_EV_CC_CALL_DISCONNECT, Current State = STATE_RECD_INVITE
434: *Oct 17 13:23:48.255: //50/C47E15DC8068/CUBE_VT/SIP/FSM/SPI-State-Change: C urrent State = STATE_RECD_INVITE, Next State = STATE_DISCONNECTING, Current Sub- State = STATE_NONE, Next Sub-State = STATE_NONE
435: *Oct 17 13:23:48.256: //50/C47E15DC8068/CUBE_VT/SIP/FSM/SPI-State-Change: C urrent State = STATE_DISCONNECTING, Next State = STATE_DISCONNECTING, Current Su b-State = STATE_NONE, Next Sub-State = STATE_NONE
436: *Oct 17 13:23:48.256: //50/C47E15DC8068/CUBE_VT/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 484 Address Incomplete
To: <sip:0508363235@10.90.80.1>;tag=18523C8-EEF
CSeq: 101 INVITE
Reason: Q.850;cause=28
Session-ID: 4dfbd3e200105000a00000df1d886a20;remote=0cb9ec974c0e5853b09e6ceb62c6 3c7c
Content-Length: 0
438: *Oct 17 13:23:48.356: //50/C47E15DC8068/CUBE_VT/SIP/Msg/ccsipDisplayMsg:
Received:
ACK sip:0508363235@10.90.80.1;user=phone SIP/2.0
Session-ID: 4dfbd3e200105000a00000df1d886a20;remote=4dfbd3e200105000a00000df1d88 6a20
Max-Forwards: 70
CSeq: 101 ACK
Content-Length: 0
439: *Oct 17 13:23:48.356: //50/C47E15DC8068/CUBE_VT/SIP/FSM/Event-Action: Event = SIPSPI_EV_NEW_MESSAGE, Current State = STATE_DISCONNECTING
440: *Oct 17 13:23:48.357: //50/C47E15DC8068/CUBE_VT/SIP/API: voip_rtp_release_p ort (8024)
441: *Oct 17 13:23:48.357: //50/C47E15DC8068/CUBE_VT/SIP/API: cc_api_call_discon nect_done (0)
442: *Oct 17 13:23:48.357: //50/C47E15DC8068/CUBE_VT/SIP/FSM/SPI-State-Change: C urrent State = STATE_DISCONNECTING, Next State = STATE_DEAD, Current Sub-State = STATE_NONE, Next Sub-State = STATE_NONE
443: *Oct 17 13:23:48.357: //50/C47E15DC8068/CUBE_VT/SIP/MISC/Error: sipSPIFlush DeferredQueue: Invalid deferredQueue
444: *Oct 17 13:23:48.357: //50/C47E15DC8068/CUBE_VT/SIP/API: voip_rtp_release_p ort (8024)
Router#
Router#sh voice
Router#sh voice po
IN OUT
Solved! Go to Solution.
10-17-2022 10:09 PM - edited 10-17-2022 10:16 PM
With a single line there is really no point in having a trunk group, especially not with multiple FXO ports added to it. If you do want to keep the trunk group you should remove the other FXO ports from it, leaving only the operational FXO port in the trunk group. That would in essence be the same as having one single FXO port on the dial peers.
10-17-2022 10:43 PM
With the trunk group configuration you have the call would flip between your FXO ports depending on how long they have been idle. Meaning that the call would not go to the operational FXO port on the second call as that then is the least idle as it just handled a call. As I and @TechLvr stated start by using a single port, easiest would be to use the port command on your dial peers or if you do not want to be easy remote all, but the one port, from your trunk group.
10-17-2022 11:04 PM
that worked. been under the impression that since they are not being utilized, it doesn't matter. just added single port to the trunkgroup and calls are flowing through without any issues.
Thanks again.
10-17-2022 11:19 PM
Glad to hear that.
