Showing results forĀ
Search instead forĀ
Did you mean:Ā
can not change time in cisco meeting server CMS
Ahmed Tarek
Level 3
Level 3
hi experts,
i need to change time in CMS, but i received below error message
Only use under the direction of Cisco Support
what shall i do?
my command is just access config mode to change.
There is no "config" in CMS. it is not a router ...
And you don't need to set the time manually. You should use NTP for that.
This is the guide with all CLI commands:
https://www.cisco.com/c/dam/en/us/td/docs/conferencing/ciscoMeetingServer/Reference_Guides/Version-3-6/Cisco-Meeting-Server-MMP-Command-Reference-3-6.pdf
9 Replies 9
b.winter
Which version do you use?
What is the command you are trying to enter?
Without that info, nobody will be able to help you. And this is not your first forum question. So you should already know, how that works.
hi b.winter
version 3.6
command i type above
config
but i face above message
you can tell me full command
i don`t know why you are aggressive, if you don`t want to help, pls don`t
Which command? I don't see a command in your first message. Please make clear descriptions of your problem!
Do you enter it via CLI?
The only command via CLI to set the time is "date set <date> <time>" (e.g. date set 2023-08-17 13:04)
ok
i will be more clear
i type config in cli to access configuration mode but i can`t, as i faced below message
even i tried to set time manual with same your commands, but i face same message
do you get what i mean?
There is a whole document under the CMS documentation on cisco.com dedicated to the MMP/CLI commands that outlines each command and what it does, have you reviewed it?
java
if this helps, please rate
Ahmed Tarek
Level 3
Level 3
thanks for you all for support,
can you explain what is message mean
It doesn't matter what this message means, you are entering commands that are not possible in CMS.
About your other question: Have you checked the link I've sent? All the commands you can enter are listed there. Also how to show the current time.
Ahmed Tarek
Level 3
Level 3
i think it really matter
anyway thanks for your help
