04-11-2013 03:18 AM - edited 03-16-2019 04:44 PM
We have an issue with a customers system where they can't dial local numbers in the same area code as them.
Any 901256xxxxxx numbers come back with a 'Number is not recognised' message.
We have the following config:
voice translation-rule 100
rule 1 /^.*/ /0\0/ type subscriber subscriber plan isdn isdn
rule 2 /^.*/ /00\0/ type national national plan isdn isdn
rule 3 /^.*/ /000\0/ type international international plan isdn isdn
voice translation-rule 101
rule 1 /^3934/ /4/
rule 2 /^7047/ /7/
voice translation-rule 102
rule 1 /^4\(.*\)/ /3934\1/ type any subscriber plan any isdn
rule 2 /^7\(.*\)/ /7047\1/ type any subscriber plan any isdn
voice translation-rule 103
rule 1 /^900\(.*\)/ /\1/ type unknown international plan any isdn
rule 2 /^90\(.*\)/ /\1/ type unknown national plan any isdn
rule 3 /^9\(.*\)/ /\1/ type unknown subscriber plan any isdn
voice translation-profile standard_incoming
translate calling 100
translate called 101
voice translation-profile standard_outgoing
translate calling 102
translate called 103
voice-port 0/0/0:15
translation-profile incoming standard_incoming
translation-profile outgoing standard_outgoing
cptone GB
dial-peer voice 1 pots
description ** Out TDM **
destination-pattern 9T
progress_ind setup enable 3
progress_ind alert enable 8
port 0/0/0:15
dial-peer voice 10 pots
description ** In TDM **
incoming called-number .
direct-inward-dial
dial-peer voice 11 voip
description ** In VoIP **
voice-class codec 1
dtmf-relay h245-alphanumeric
Solved! Go to Solution.
04-11-2013 05:50 AM
Pete,
Yes it is the rule..
The 103 is stripping off 90...
I believe this profile is for prefixing digits for missed calls..You should be applying it on the calling number not called
Please rate all useful posts
"opportunity is a haughty goddess who waste no time with those who are unprepared"
04-11-2013 03:34 AM
Pete can you send a debug isdn q931 and debug voip ccapi inout
04-11-2013 03:56 AM
Apr 11 10:52:36.896: //-1/C1A844A5996F/CCAPI/cc_api_display_ie_subfields:
cc_api_call_setup_ind_common:
cisco-username=
----- ccCallInfo IE subfields -----
cisco-ani=447
cisco-anitype=0
cisco-aniplan=0
cisco-anipi=0
cisco-anisi=0
dest=
cisco-desttype=0
cisco-destplan=0
cisco-rdie=FFFFFFFF
cisco-rdn=
cisco-lastrdn=
cisco-rdntype=0
cisco-rdnplan=0
cisco-rdnpi=0
cisco-rdnsi=0
cisco-redirectreason=0 fwd_final_type =0
final_redirectNumber =
hunt_group_timeout =0
Apr 11 10:52:36.896: //-1/C1A844A5996F/CCAPI/cc_api_call_setup_ind_common:
Interface=0x49DE632C, Call Info(
Calling Number=447,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
Called Number=(TON=Unknown, NPI=Unknown),
Calling Translated=FALSE, Subscriber Type Str=RegularLine, FinalDestinationFlag=FALSE,
Incoming Dial-peer=20018, Progress Indication=ORIGINATING SIDE IS NON ISDN(3), Calling IE Present=TRUE,
Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=-1
Apr 11 10:52:36.900: //-1/C1A844A5996F/CCAPI/ccCheckClipClir:
In: Calling Number=447(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
Out: Calling Number=447(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
Apr 11 10:52:36.900: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Apr 11 10:52:36.900: :cc_get_feature_vsa malloc success
Apr 11 10:52:36.900: cc_get_feature_vsa count is 3
Apr 11 10:52:36.900: :FEATURE_VSA attributes are: feature_name:0,feature_time:1185844616,feature_id:4146
Apr 11 10:52:36.900: //2263/C1A844A5996F/CCAPI/cc_api_call_setup_ind_common:
Set Up Event Sent;
Call Info(Calling Number=447(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
Called Number=(TON=Unknown, NPI=Unknown))
Apr 11 10:52:36.900: //2263/C1A844A5996F/CCAPI/cc_process_call_setup_ind:
Event=0x483BAFE8
Apr 11 10:52:36.900: //2263/C1A844A5996F/CCAPI/ccCallSetContext:
Context=0x4A386F78
>>>>CCAPI handed cid 2263 with tag 20018 to app "_ManagedAppProcess_Default"
Apr 11 10:52:36.904: //2263/C1A844A5996F/CCAPI/ccCallSetupAck:
Call Id=2263
Apr 11 10:52:36.904: //2263/C1A844A5996F/CCAPI/cc_api_set_transfer_info:
Transfer Number=, Transfer Reason=0x0
Apr 11 10:52:36.904: //2263/C1A844A5996F/CCAPI/ccGenerateToneInfo:
Stop Tone On Digit=TRUE, Tone=Dial Tone,
Tone Direction=Network, Params=0x0, Call Id=2263
Apr 11 10:52:36.904: //2263/C1A844A5996F/CCAPI/ccSetDigitTimeouts:
Initial Digit Timeout=-1000(ms), Inter Digit Timeout=-1000(ms)
Call Entry(Inter Digit Timeout=10000(ms), Initial Digit Timeout=10000(ms))
Apr 11 10:52:36.904: //2263/xxxxxxxxxxxx/CCAPI/ccCallReportDigits:
(callID=0x8D7, digit_event=0x1, enable=TRUE, consume=FALSE)
Apr 11 10:52:36.904: //2263/C1A844A5996F/CCAPI/ccCallReportDigits:
Enabled=TRUE, Call Id=2263
Apr 11 10:52:36.904: //2263/xxxxxxxxxxxx/CCAPI/cc_api_call_report_digits_done:
(vdbPtr=0x49DE632C, callID=0x8D7, disp=0, digit_event=0x1, enable=TRUE, consume=FALSE)
Apr 11 10:52:36.904: //2263/C1A844A5996F/CCAPI/cc_api_call_report_digits_done:
Enabled=TRUE, Disposition=0x0, Interface=0x49DE632C, Call Id=2263
Call Entry(Initial Digit Timeout=15000(ms), Inter Digit Timeout=4000(ms))
Apr 11 10:52:37.280: //2263/C1A844A5996F/CCAPI/cc_api_call_digit_begin:
Destination Interface=0x0, Destination Mask=0x3, Destination Call Id=-1,
Source Call Id=2263, Digit=9, DigitBeginFlags=0x0,
Rtp Timestamp=0xF8AC28, Rtp Expiration=0x0
Apr 11 10:52:37.280: //2263/C1A844A5996F/CCAPI/cc_api_call_digit_end:
Source Call Id=2263, Digit=9, Duration=100,
Xrule Calling Tag=0, Xrule Called Tag=0, Digit Tone Mode=DTMF
Call Entry(Handoff Depth=0)
Apr 11 10:52:37.444: //2263/C1A844A5996F/CCAPI/cc_api_call_digit_begin:
Source Call Id=2263, Digit=0, DigitBeginFlags=0x0,
Rtp Timestamp=0xF92928, Rtp Expiration=0x0
Apr 11 10:52:37.444: //2263/C1A844A5996F/CCAPI/cc_api_call_digit_end:
Source Call Id=2263, Digit=0, Duration=100,
Apr 11 10:52:37.600: //2263/C1A844A5996F/CCAPI/cc_api_call_digit_begin:
Source Call Id=2263, Digit=2, DigitBeginFlags=0x0,
Rtp Timestamp=0xF9A628, Rtp Expiration=0x0
Apr 11 10:52:37.600: //2263/C1A844A5996F/CCAPI/cc_api_call_digit_end:
Source Call Id=2263, Digit=2, Duration=100,
Apr 11 10:52:37.760: //2263/C1A844A5996F/CCAPI/cc_api_call_digit_begin:
Rtp Timestamp=0xFA2328, Rtp Expiration=0x0
Apr 11 10:52:37.760: //2263/C1A844A5996F/CCAPI/cc_api_call_digit_end:
Apr 11 10:52:37.764: //2263/C1A844A5996F/CCAPI/cc_api_call_digit_end:
Apr 11 10:52:37.920: //2263/C1A844A5996F/CCAPI/cc_api_call_digit_begin:
Source Call Id=2263, Digit=7, DigitBeginFlags=0x0,
Rtp Timestamp=0xFAA028, Rtp Expiration=0x0
Apr 11 10:52:37.920: //2263/C1A844A5996F/CCAPI/cc_api_call_digit_end:
Source Call Id=2263, Digit=7, Duration=100,
Apr 11 10:52:38.096: //2263/C1A844A5996F/CCAPI/cc_api_call_digit_begin:
Rtp Timestamp=0xFB1D28, Rtp Expiration=0x0
Apr 11 10:52:38.096: //2263/C1A844A5996F/CCAPI/cc_api_call_digit_end:
Apr 11 10:52:38.260: //2263/C1A844A5996F/CCAPI/cc_api_call_digit_begin:
Rtp Timestamp=0xFB9A28, Rtp Expiration=0x0
Apr 11 10:52:38.260: //2263/C1A844A5996F/CCAPI/cc_api_call_digit_end:
Apr 11 10:52:38.420: //2263/C1A844A5996F/CCAPI/cc_api_call_digit_begin:
Rtp Timestamp=0xFC1728, Rtp Expiration=0x0
Apr 11 10:52:38.424: //2263/C1A844A5996F/CCAPI/cc_api_call_digit_end:
Apr 11 10:52:38.580: //2263/C1A844A5996F/CCAPI/cc_api_call_digit_begin:
Rtp Timestamp=0xFC9428, Rtp Expiration=0x0
Apr 11 10:52:38.580: //2263/C1A844A5996F/CCAPI/cc_api_call_digit_end:
Apr 11 10:52:38.744: //2263/C1A844A5996F/CCAPI/cc_api_call_digit_begin:
Source Call Id=2263, Digit=3, DigitBeginFlags=0x0,
Rtp Timestamp=0xFD1128, Rtp Expiration=0x0
Apr 11 10:52:38.744: //2263/C1A844A5996F/CCAPI/cc_api_call_digit_end:
Source Call Id=2263, Digit=3, Duration=100,
Apr 11 10:52:38.900: //2263/C1A844A5996F/CCAPI/cc_api_call_digit_begin:
Rtp Timestamp=0xFD8E28, Rtp Expiration=0x0
Apr 11 10:52:38.900: //2263/C1A844A5996F/CCAPI/cc_api_call_digit_end:
Apr 11 10:52:39.060: //2263/C1A844A5996F/CCAPI/cc_api_call_digit_begin:
Rtp Timestamp=0xFE0B28, Rtp Expiration=0x0
Apr 11 10:52:39.060: //2263/C1A844A5996F/CCAPI/cc_api_call_digit_end:
Apr 11 10:52:39.064: //2263/C1A844A5996F/CCAPI/cc_api_call_digit_end:
Apr 11 10:52:40.860: //-1/C405269B9973/CCAPI/cc_api_display_ie_subfields:
cisco-username=
cisco-ani=449
cisco-anitype=0
cisco-aniplan=0
cisco-anipi=0
cisco-anisi=0
dest=
cisco-desttype=0
cisco-destplan=0
cisco-rdie=FFFFFFFF
cisco-rdn=
cisco-lastrdn=
cisco-rdntype=0
cisco-rdnplan=0
cisco-rdnpi=0
cisco-rdnsi=0
Apr 11 10:52:40.864: //-1/C405269B9973/CCAPI/cc_api_call_setup_ind_common:
Interface=0x49E786A4, Call Info(
Calling Number=449,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
Incoming Dial-peer=20020, Progress Indication=ORIGINATING SIDE IS NON ISDN(3), Calling IE Present=TRUE,
Apr 11 10:52:40.864: //-1/C405269B9973/CCAPI/ccCheckClipClir:
In: Calling Number=449(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
Out: Calling Number=449(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
Apr 11 10:52:40.864: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Apr 11 10:52:40.864: :cc_get_feature_vsa malloc success
Apr 11 10:52:40.864: cc_get_feature_vsa count is 4
Apr 11 10:52:40.864: :FEATURE_VSA attributes are: feature_name:0,feature_time:1185844392,feature_id:4147
Apr 11 10:52:40.864: //2264/C405269B9973/CCAPI/cc_api_call_setup_ind_common:
Set Up Event Sent;
Call Info(Calling Number=449(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
Apr 11 10:52:40.864: //2264/C405269B9973/CCAPI/cc_process_call_setup_ind:
Event=0x483BAFE8
Apr 11 10:52:40.864: //2264/C405269B9973/CCAPI/ccCallSetContext:
Context=0x4A382358
>>>>CCAPI handed cid 2264 with tag 20020 to app "_ManagedAppProcess_Default"
Apr 11 10:52:40.868: //2264/C405269B9973/CCAPI/ccCallSetupAck:
Call Id=2264
Apr 11 10:52:40.868: //2264/C405269B9973/CCAPI/cc_api_set_transfer_info:
Apr 11 10:52:40.868: //2264/C405269B9973/CCAPI/ccGenerateToneInfo:
Tone Direction=Network, Params=0x0, Call Id=2264
Apr 11 10:52:40.868: //2264/C405269B9973/CCAPI/ccSetDigitTimeouts:
Apr 11 10:52:40.868: //2264/xxxxxxxxxxxx/CCAPI/ccCallReportDigits:
(callID=0x8D8, digit_event=0x1, enable=TRUE, consume=FALSE)
Apr 11 10:52:40.868: //2264/C405269B9973/CCAPI/ccCallReportDigits:
Enabled=TRUE, Call Id=2264
Apr 11 10:52:40.868: //2264/xxxxxxxxxxxx/CCAPI/cc_api_call_report_digits_done:
(vdbPtr=0x49E786A4, callID=0x8D8, disp=0, digit_event=0x1, enable=TRUE, consume=FALSE)
Apr 11 10:52:40.868: //2264/C405269B9973/CCAPI/cc_api_call_report_digits_done:
Enabled=TRUE, Disposition=0x0, Interface=0x49E786A4, Call Id=2264
Apr 11 10:52:41.832: //2264/C405269B9973/CCAPI/cc_api_call_digit_begin:
Source Call Id=2264, Digit=9, DigitBeginFlags=0x0,
Rtp Timestamp=0x589F80, Rtp Expiration=0x0
Apr 11 10:52:41.832: //2264/C405269B9973/CCAPI/cc_api_call_digit_end:
Source Call Id=2264, Digit=9, Duration=100,
Apr 11 10:52:42.032: //2264/C405269B9973/CCAPI/cc_api_call_digit_begin:
Source Call Id=2264, Digit=0, DigitBeginFlags=0x0,
Rtp Timestamp=0x591C80, Rtp Expiration=0x0
Apr 11 10:52:42.032: //2264/C405269B9973/CCAPI/cc_api_call_digit_end:
Source Call Id=2264, Digit=0, Duration=100,
Apr 11 10:52:42.232: //2264/C405269B9973/CCAPI/cc_api_call_digit_begin:
Source Call Id=2264, Digit=1, DigitBeginFlags=0x0,
Rtp Timestamp=0x599980, Rtp Expiration=0x0
Apr 11 10:52:42.232: //2264/C405269B9973/CCAPI/cc_api_call_digit_end:
Source Call Id=2264, Digit=1, Duration=100,
Apr 11 10:52:42.432: //2264/C405269B9973/CCAPI/cc_api_call_digit_begin:
Source Call Id=2264, Digit=2, DigitBeginFlags=0x0,
Rtp Timestamp=0x5A1680, Rtp Expiration=0x0
Apr 11 10:52:42.432: //2264/C405269B9973/CCAPI/cc_api_call_digit_end:
Source Call Id=2264, Digit=2, Duration=100,
Apr 11 10:52:42.632: //2264/C405269B9973/CCAPI/cc_api_call_digit_begin:
Source Call Id=2264, Digit=5, DigitBeginFlags=0x0,
Rtp Timestamp=0x5A9380, Rtp Expiration=0x0
Apr 11 10:52:42.632: //2264/C405269B9973/CCAPI/cc_api_call_digit_end:
Source Call Id=2264, Digit=5, Duration=100,
Apr 11 10:52:42.832: //2264/C405269B9973/CCAPI/cc_api_call_digit_begin:
Source Call Id=2264, Digit=6, DigitBeginFlags=0x0,
Rtp Timestamp=0x5B1080, Rtp Expiration=0x0
Apr 11 10:52:42.832: //2264/C405269B9973/CCAPI/cc_api_call_digit_end:
Source Call Id=2264, Digit=6, Duration=100,
Apr 11 10:52:43.032: //2264/C405269B9973/CCAPI/cc_api_call_digit_begin:
Source Call Id=2264, Digit=7, DigitBeginFlags=0x0,
Rtp Timestamp=0x5B8D80, Rtp Expiration=0x0
Apr 11 10:52:43.032: //2264/C405269B9973/CCAPI/cc_api_call_digit_end:
Source Call Id=2264, Digit=7, Duration=100,
Apr 11 10:52:43.064: //2263/C1A844A5996F/CCAPI/cc_handle_inter_digit_timer:
Generate inter-digit timeout CC_EV_CALL_DIGIT_END event
Apr 11 10:52:43.064: //2263/xxxxxxxxxxxx/CCAPI/ccCallReportDigits:
(callID=0x8D7, digit_event=0x0, enable=FALSE, consume=FALSE)
Apr 11 10:52:43.064: //2263/C1A844A5996F/CCAPI/ccCallReportDigits:
Apr 11 10:52:43.064: //2263/xxxxxxxxxxxx/CCAPI/cc_api_call_report_digits_done:
(vdbPtr=0x49DE632C, callID=0x8D7, disp=0, digit_event=0x0, enable=FALSE, consume=FALSE)
Apr 11 10:52:43.064: //2263/C1A844A5996F/CCAPI/cc_api_call_report_digits_done:
Apr 11 10:52:43.064: //2263/C1A844A5996F/CCAPI/ccCallProceeding:
Progress Indication=NULL(0)
Apr 11 10:52:43.068: //2263/C1A844A5996F/CCAPI/ccCallSetupRequest:
Destination=, Calling IE Present=TRUE, Mode=0,
Outgoing Dial-peer=1, Params=0x4A3895D8, Progress Indication=ORIGINATING SIDE IS NON ISDN(3)
Apr 11 10:52:43.068: //2263/C1A844A5996F/CCAPI/ccCheckClipClir:
In: Calling Number=393447(TON=Subscriber, NPI=ISDN, Screening=Not Screened, Presentation=Allowed)
Out: Calling Number=393447(TON=Subscriber, NPI=ISDN, Screening=Not Screened, Presentation=Allowed)
Destination Pattern=9T, Called Number=2079022320, Digit Strip=TRUE
Calling Number=393447(TON=Subscriber, NPI=ISDN, Screening=Not Screened, Presentation=Allowed),
Called Number=2079022320(TON=National, NPI=ISDN),
Redirect Number=, Display Info=Pamela Vaughan
Account Number=, Final Destination Flag=FALSE,
Guid=C1A844A5-A1CC-11E2-996F-9D10B6883F86, Outgoing Dial-peer=1
Apr 11 10:52:43.068: //2263/C1A844A5996F/CCAPI/cc_api_display_ie_subfields:
ccCallSetupRequest:
cisco-username=
cisco-ani=393447
cisco-anitype=4
cisco-aniplan=1
cisco-anipi=0
cisco-anisi=0
dest=2079022320
cisco-desttype=2
cisco-destplan=1
cisco-rdie=FFFFFFFF
cisco-rdn=
cisco-lastrdn=
cisco-rdntype=0
cisco-rdnplan=0
cisco-rdnpi=0
cisco-rdnsi=0
Apr 11 10:52:43.068: //2263/C1A844A5996F/CCAPI/ccIFCallSetupRequestPrivate:
Interface=0x48402CE4, Interface Type=6, Destination=, Mode=0x0,
Call Params(Calling Number=393447,(Calling Name=Pamela Vaughan)(TON=Subscriber, NPI=ISDN, Screening=Not Screened, Presentation=Allowed),
Called Number=2079022320(TON=National, NPI=ISDN), Calling Translated=FALSE,
Subscriber Type Str=RegularLine, FinalDestinationFlag=FALSE, Outgoing Dial-peer=1, Call Count On=FALSE,
Source Trkgrp Route Label=, Target Trkgrp Route Label=, tg_label_flag=0, Application Call Id=)
Apr 11 10:52:43.068: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Apr 11 10:52:43.068: :cc_get_feature_vsa malloc success
Apr 11 10:52:43.068: cc_get_feature_vsa count is 5
Apr 11 10:52:43.068: :FEATURE_VSA attributes are: feature_name:0,feature_time:1185844168,feature_id:4148
Apr 11 10:52:43.068: //2265/C1A844A5996F/CCAPI/ccIFCallSetupRequestPrivate:
SPI Call Setup Request Is Success; Interface Type=6, FlowMode=1
Apr 11 10:52:43.068: //2265/C1A844A5996F/CCAPI/ccCallSetContext:
Context=0x4A389588
Apr 11 10:52:43.068: //2263/C1A844A5996F/CCAPI/ccSaveDialpeerTag:
Apr 11 10:52:43.072: ISDN Se0/0/0:15 Q931: Applying typeplan for sw-type 0x12 is 0x4 0x1, Calling num 393447
Apr 11 10:52:43.076: ISDN Se0/0/0:15 Q931: Sending SETUP callref = 0x01DB callID = 0x815C switch = primary-net5 interface = User
Apr 11 10:52:43.076: ISDN Se0/0/0:15 Q931: TX -> SETUP pd = 8 callref = 0x01DB
Bearer Capability i = 0x8090A3
Standard = CCITT
Transfer Capability = Speech
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0xA98382
Exclusive, Channel 2
Progress Ind i = 0x8183 - Origination address is non-ISDN
Calling Party Number i = 0x4180, '393447'
Plan:ISDN, Type:Subscriber(local)
Called Party Number i = 0xA1, '2079022320'
Plan:ISDN, Type:National
Apr 11 10:52:43.232: //2264/C405269B9973/CCAPI/cc_api_call_digit_begin:
Source Call Id=2264, Digit=8, DigitBeginFlags=0x0,
Rtp Timestamp=0x5C0A80, Rtp Expiration=0x0
Apr 11 10:52:43.232: //2264/C405269B9973/CCAPI/cc_api_call_digit_end:
Source Call Id=2264, Digit=8, Duration=100,
Apr 11 10:52:43.316: ISDN Se0/0/0:15 Q931: RX <- SETUP_ACK pd = 8 callref = 0x81DB
Progress Ind i = 0x8288 - In-band info or appropriate now available
Apr 11 10:52:43.320: //2265/C1A844A5996F/CCAPI/cc_api_call_cut_progress:
Interface=0x48402CE4, Progress Indication=INBAND(8), Signal Indication=INTERCEPT(2),
Cause Value=0
Call Entry(Responsed=TRUE)
Apr 11 10:52:43.320: //2263/C1A844A5996F/CCAPI/ccCallCutProgress:
Progress Indication=INBAND(8), Signal Indication=INTERCEPT(2), Cause Value=0
Voice Call Send Alert=FALSE, Call Entry(Alert Sent=FALSE)
Apr 11 10:52:43.320: //2263/C1A844A5996F/CCAPI/ccGenerateToneInfo:
Stop Tone On Digit=FALSE, Tone=Null,
Apr 11 10:52:43.320: //2263/xxxxxxxxxxxx/CCAPI/ccConferenceCreate:
(confID=0x4A44C654, callID1=0x8D7, callID2=0x8D9, tag=0x0)
(confID=0x4A44C654, callID1=0x8D7, gcid=C1A844A5-A1CC11E2-996F9D10-B6883F86, tag=0x0)
Apr 11 10:52:43.320: //2265/xxxxxxxxxxxx/CCAPI/ccConferenceCreate:
(confID=0x4A44C654, callID2=0x8D9, gcid=C1A844A5-A1CC11E2-996F9D10-B6883F86, tag=0x0)
Apr 11 10:52:43.320: //2263/C1A844A5996F/CCAPI/ccConferenceCreate:
Conference Id=0x4A44C654, Call Id1=2263, Call Id2=2265, Tag=0x0
Apr 11 10:52:43.320: //2263/xxxxxxxxxxxx/CCAPI/cc_api_bridge_done:
Conference Id=0x317, Source Interface=0x49DE632C, Source Call Id=2263,
Destination Call Id=2265, Disposition=0x0, Tag=0xFFFFFFFF
Apr 11 10:52:43.324: //2265/xxxxxxxxxxxx/CCAPI/cc_api_bridge_done:
Conference Id=0x317, Source Interface=0x48402CE4, Source Call Id=2265,
Destination Call Id=2263, Disposition=0x0, Tag=0xFFFFFFFF
Apr 11 10:52:43.324: //2263/C1A844A5996F/CCAPI/cc_generic_bridge_done:
Apr 11 10:52:43.324: //2263/C1A844A5996F/CCAPI/ccConferenceCreate:
Call Entry(Conference Id=0x317, Destination Call Id=2265)
Apr 11 10:52:43.324: //2265/C1A844A5996F/CCAPI/ccConferenceCreate:
Call Entry(Conference Id=0x317, Destination Call Id=2263)
Apr 11 10:52:43.324: //2263/C1A844A5996F/CCAPI/cc_api_caps_ind:
Destination Interface=0x48402CE4, Destination Call Id=2265, Source Call Id=2263,
Caps(Codec=0x1, Fax Rate=0x2, Vad=0x1,
Modem=0x2, Codec Bytes=160, Signal Type=2)
Caps(Playout Mode=1, Playout Initial=60(ms), Playout Min=40(ms),
Playout Max=1000(ms), Fax Nom=300(ms))
Apr 11 10:52:43.324: //2265/C1A844A5996F/CCAPI/cc_api_caps_ind:
Destination Interface=0x49DE632C, Destination Call Id=2263, Source Call Id=2265,
Caps(Codec=0x1, Fax Rate=0x1, Vad=0x1,
Apr 11 10:52:43.324: //2265/C1A844A5996F/CCAPI/cc_api_caps_ack:
Caps(Codec=g711ulaw(0x1), Fax Rate=FAX_RATE_VOICE(0x2), Vad=OFF(0x1),
Modem=ON(0x2), Codec Bytes=160, Signal Type=2, Seq Num Start=7922)
Apr 11 10:52:43.324: //2263/C1A844A5996F/CCAPI/cc_api_caps_ack:
Caps(Codec=g711ulaw(0x1), Fax Rate=FAX_RATE_NONE(0x1), Vad=OFF(0x1),
Modem=ON(0x2), Codec Bytes=160, Signal Type=2, Seq Num Start=1709)
Apr 11 10:52:43.324: //2263/C1A844A5996F/CCAPI/cc_api_voice_mode_event:
Call Id=2263
Call Entry(Context=0x4A386F78)
Apr 11 10:52:43.328: //2263/C1A844A5996F/CCAPI/cc_process_notify_bridge_done:
Conference Id=0x317, Call Id1=2263, Call Id2=2265
Apr 11 10:52:43.328: //2263/C1A844A5996F/CCAPI/ccCallFeature:
Feature Type=25, Call Id=2263
Apr 11 10:52:43.328: //2265/C1A844A5996F/CCAPI/cc_api_voice_mode_event:
Call Id=2265
Call Entry(Context=0x4A389588)
Apr 11 10:52:43.432: //2264/C405269B9973/CCAPI/cc_api_call_digit_begin:
Rtp Timestamp=0x5C8780, Rtp Expiration=0x0
Apr 11 10:52:43.432: //2264/C405269B9973/CCAPI/cc_api_call_digit_end:
Apr 11 10:52:43.632: //2264/C405269B9973/CCAPI/cc_api_call_digit_begin:
Rtp Timestamp=0x5D0480, Rtp Expiration=0x0
Apr 11 10:52:43.632: //2264/C405269B9973/CCAPI/cc_api_call_digit_end:
Apr 11 10:52:43.809: ISDN Se0/0/0:15 Q931: RX <- CALL_PROC pd = 8 callref = 0x81DB
Apr 11 10:52:43.813: //2265/C1A844A5996F/CCAPI/cc_api_call_proceeding:
Interface=0x48402CE4, Progress Indication=NULL(0)
Apr 11 10:52:43.833: //2264/C405269B9973/CCAPI/cc_api_call_digit_begin:
Rtp Timestamp=0x5D8180, Rtp Expiration=0x0
Apr 11 10:52:43.833: //2264/C405269B9973/CCAPI/cc_api_call_digit_end:
Apr 11 10:52:44.033: //2264/C405269B9973/CCAPI/cc_api_call_digit_begin:
Rtp Timestamp=0x5DFE80, Rtp Expiration=0x0
Apr 11 10:52:44.033: //2264/C405269B9973/CCAPI/cc_api_call_digit_end:
Apr 11 10:52:44.201: ISDN Se0/0/0:15 Q931: RX <- ALERTING pd = 8 callref = 0x81DB
Apr 11 10:52:44.205: //2265/C1A844A5996F/CCAPI/cc_api_call_alert:
Interface=0x48402CE4, Progress Indication=NULL(0), Signal Indication=NOT PRESENT(255)
Call Entry(Retry Count=0, Responsed=TRUE)
Apr 11 10:52:44.205: //2263/C1A844A5996F/CCAPI/ccCallAlert:
Progress Indication=INBAND(8), Signal Indication=NOT PRESENT(255)
Call Entry(Responsed=TRUE, Alert Sent=TRUE)
Apr 11 10:52:48.033: //2264/C405269B9973/CCAPI/cc_handle_inter_digit_timer:
Apr 11 10:52:48.033: //2264/xxxxxxxxxxxx/CCAPI/ccCallReportDigits:
(callID=0x8D8, digit_event=0x0, enable=FALSE, consume=FALSE)
Apr 11 10:52:48.033: //2264/C405269B9973/CCAPI/ccCallReportDigits:
Apr 11 10:52:48.033: //2264/xxxxxxxxxxxx/CCAPI/cc_api_call_report_digits_done:
(vdbPtr=0x49E786A4, callID=0x8D8, disp=0, digit_event=0x0, enable=FALSE, consume=FALSE)
Apr 11 10:52:48.033: //2264/C405269B9973/CCAPI/cc_api_call_report_digits_done:
Apr 11 10:52:48.033: //2264/C405269B9973/CCAPI/ccCallProceeding:
Apr 11 10:52:48.037: //2264/C405269B9973/CCAPI/ccCallSetupRequest:
Outgoing Dial-peer=1, Params=0x4A392E18, Progress Indication=ORIGINATING SIDE IS NON ISDN(3)
Apr 11 10:52:48.037: //2264/C405269B9973/CCAPI/ccCheckClipClir:
In: Calling Number=393449(TON=Subscriber, NPI=ISDN, Screening=Not Screened, Presentation=Allowed)
Out: Calling Number=393449(TON=Subscriber, NPI=ISDN, Screening=Not Screened, Presentation=Allowed)
Destination Pattern=9T, Called Number=1256788016, Digit Strip=TRUE
Calling Number=393449(TON=Subscriber, NPI=ISDN, Screening=Not Screened, Presentation=Allowed),
Called Number=1256788016(TON=National, NPI=ISDN),
Redirect Number=, Display Info=449
Guid=C405269B-A1CC-11E2-9973-9D10B6883F86, Outgoing Dial-peer=1
Apr 11 10:52:48.037: //2264/C405269B9973/CCAPI/cc_api_display_ie_subfields:
ccCallSetupRequest:
cisco-username=
cisco-ani=393449
cisco-anitype=4
cisco-aniplan=1
cisco-anipi=0
cisco-anisi=0
dest=1256788016
cisco-desttype=2
cisco-destplan=1
cisco-rdie=FFFFFFFF
cisco-rdn=
cisco-lastrdn=
cisco-rdntype=0
cisco-rdnplan=0
cisco-rdnpi=0
cisco-rdnsi=0
Apr 11 10:52:48.037: //2264/C405269B9973/CCAPI/ccIFCallSetupRequestPrivate:
Call Params(Calling Number=393449,(Calling Name=449)(TON=Subscriber, NPI=ISDN, Screening=Not Screened, Presentation=Allowed),
Called Number=1256788016(TON=National, NPI=ISDN), Calling Translated=FALSE,
Apr 11 10:52:48.037: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Apr 11 10:52:48.037: :cc_get_feature_vsa malloc success
Apr 11 10:52:48.037: cc_get_feature_vsa count is 6
Apr 11 10:52:48.037: :FEATURE_VSA attributes are: feature_name:0,feature_time:1185843944,feature_id:4149
Apr 11 10:52:48.037: //2266/C405269B9973/CCAPI/ccIFCallSetupRequestPrivate:
Apr 11 10:52:48.037: //2266/C405269B9973/CCAPI/ccCallSetContext:
Context=0x4A392DC8
Apr 11 10:52:48.037: //2264/C405269B9973/CCAPI/ccSaveDialpeerTag:
Apr 11 10:52:48.045: ISDN Se0/0/0:15 Q931: Applying typeplan for sw-type 0x12 is 0x4 0x1, Calling num 393449
Apr 11 10:52:48.045: ISDN Se0/0/0:15 Q931: Sending SETUP callref = 0x01DC callID = 0x815D switch = primary-net5 interface = User
Apr 11 10:52:48.045: ISDN Se0/0/0:15 Q931: TX -> SETUP pd = 8 callref = 0x01DC
Standard = CCITT
Channel ID i = 0xA98383
Exclusive, Channel 3
Calling Party Number i = 0x4180, '393449'
Called Party Number i = 0xA1, '1256788016'
Apr 11 10:52:48.313: ISDN Se0/0/0:15 Q931: RX <- CALL_PROC pd = 8 callref = 0x81DC
Apr 11 10:52:48.317: //2266/C405269B9973/CCAPI/cc_api_call_proceeding:
Apr 11 10:52:49.689: ISDN Se0/0/0:15 Q931: RX <- DISCONNECT pd = 8 callref = 0x81DC
Cause i = 0x8281 - Unallocated/unassigned number
Apr 11 10:52:49.689: ISDN Se0/0/0:15 Q931: call_disc: PI received in disconnect; Postpone sending RELEASE for callid 0x815D
Apr 11 10:52:49.689: //2266/C405269B9973/CCAPI/cc_api_call_disc_prog_ind:
Cause Value=1, Progress Indication=INBAND(8), Interface=0x48402CE4
Event(Progress Indication=0x8), Call Entry(Responsed=TRUE)
Apr 11 10:52:49.689: //2264/C405269B9973/CCAPI/ccCallDiscProgInd:
Call Entry(Responsed=TRUE, Disconnect Cause=1)
Apr 11 10:52:49.689: //2264/xxxxxxxxxxxx/CCAPI/ccConferenceCreate:
(confID=0x4A44C5C4, callID1=0x8D8, callID2=0x8DA, tag=0x0)
(confID=0x4A44C5C4, callID1=0x8D8, gcid=C405269B-A1CC11E2-99739D10-B6883F86, tag=0x0)
Apr 11 10:52:49.689: //2266/xxxxxxxxxxxx/CCAPI/ccConferenceCreate:
(confID=0x4A44C5C4, callID2=0x8DA, gcid=C405269B-A1CC11E2-99739D10-B6883F86, tag=0x0)
Apr 11 10:52:49.689: //2264/C405269B9973/CCAPI/ccConferenceCreate:
Conference Id=0x4A44C5C4, Call Id1=2264, Call Id2=2266, Tag=0x0
Apr 11 10:52:49.693: //2264/xxxxxxxxxxxx/CCAPI/cc_api_bridge_done:
Conference Id=0x318, Source Interface=0x49E786A4, Source Call Id=2264,
Destination Call Id=2266, Disposition=0x0, Tag=0xFFFFFFFF
Apr 11 10:52:49.693: //2266/xxxxxxxxxxxx/CCAPI/cc_api_bridge_done:
Conference Id=0x318, Source Interface=0x48402CE4, Source Call Id=2266,
Destination Call Id=2264, Disposition=0x0, Tag=0xFFFFFFFF
Apr 11 10:52:49.693: //2264/C405269B9973/CCAPI/cc_generic_bridge_done:
Apr 11 10:52:49.693: //2264/C405269B9973/CCAPI/ccConferenceCreate:
Call Entry(Conference Id=0x318, Destination Call Id=2266)
Apr 11 10:52:49.693: //2266/C405269B9973/CCAPI/ccConferenceCreate:
Call Entry(Conference Id=0x318, Destination Call Id=2264)
Apr 11 10:52:49.693: //2264/C405269B9973/CCAPI/cc_api_caps_ind:
Destination Interface=0x48402CE4, Destination Call Id=2266, Source Call Id=2264,
Apr 11 10:52:49.693: //2266/C405269B9973/CCAPI/cc_api_caps_ind:
Destination Interface=0x49E786A4, Destination Call Id=2264, Source Call Id=2266,
Apr 11 10:52:49.693: //2266/C405269B9973/CCAPI/cc_api_caps_ack:
Modem=ON(0x2), Codec Bytes=160, Signal Type=2, Seq Num Start=4219)
Apr 11 10:52:49.693: //2264/C405269B9973/CCAPI/cc_api_caps_ack:
Modem=ON(0x2), Codec Bytes=160, Signal Type=2, Seq Num Start=2071)
Apr 11 10:52:49.693: //2264/C405269B9973/CCAPI/cc_process_notify_bridge_done:
Conference Id=0x318, Call Id1=2264, Call Id2=2266
Apr 11 10:52:49.693: //2264/C405269B9973/CCAPI/cc_api_voice_mode_event:
Call Id=2264
Apr 11 10:52:49.697: //2264/C405269B9973/CCAPI/cc_api_voice_mode_event:
Call Entry(Context=0x4A382358)
Apr 11 10:52:49.697: //2264/C405269B9973/CCAPI/ccCallFeature:
Feature Type=25, Call Id=2264
Apr 11 10:52:49.701: //2266/C405269B9973/CCAPI/cc_api_voice_mode_event:
Call Id=2266
Call Entry(Context=0x4A392DC8)
Apr 11 10:52:51.373: //-1/CA49386D9979/CCAPI/cc_api_display_ie_subfields:
cisco-username=
cisco-ani=455
cisco-anitype=0
cisco-aniplan=0
cisco-anipi=0
cisco-anisi=0
dest=
cisco-desttype=0
cisco-destplan=0
cisco-rdie=FFFFFFFF
cisco-rdn=
cisco-lastrdn=
cisco-rdntype=0
cisco-rdnplan=0
cisco-rdnpi=0
cisco-rdnsi=0
Apr 11 10:52:51.373: //-1/CA49386D9979/CCAPI/cc_api_call_setup_ind_common:
Interface=0x49EDD59C, Call Info(
Calling Number=455,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
Incoming Dial-peer=20026, Progress Indication=ORIGINATING SIDE IS NON ISDN(3), Calling IE Present=TRUE,
Apr 11 10:52:51.373: //-1/CA49386D9979/CCAPI/ccCheckClipClir:
In: Calling Number=455(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
Out: Calling Number=455(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
Apr 11 10:52:51.373: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Apr 11 10:52:51.373: :cc_get_feature_vsa malloc success
Apr 11 10:52:51.373: cc_get_feature_vsa count is 7
Apr 11 10:52:51.373: :FEATURE_VSA attributes are: feature_name:0,feature_time:1185843720,feature_id:4150
Apr 11 10:52:51.377: //2267/CA49386D9979/CCAPI/cc_api_call_setup_ind_common:
Set Up Event Sent;
Call Info(Calling Number=455(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
Apr 11 10:52:51.377: //2267/CA49386D9979/CCAPI/cc_process_call_setup_ind:
Event=0x483BAFE8
Apr 11 10:52:51.377: //2267/CA49386D9979/CCAPI/ccCallSetContext:
Context=0x4A3966E0
>>>>CCAPI handed cid 2267 with tag 20026 to app "_ManagedAppProcess_Default"
Apr 11 10:52:51.381: //2267/CA49386D9979/CCAPI/ccCallSetupAck:
Call Id=2267
Apr 11 10:52:51.381: //2267/CA49386D9979/CCAPI/cc_api_set_transfer_info:
Apr 11 10:52:51.381: //2267/CA49386D9979/CCAPI/ccGenerateToneInfo:
Tone Direction=Network, Params=0x0, Call Id=2267
Apr 11 10:52:51.381: //2267/CA49386D9979/CCAPI/ccSetDigitTimeouts:
Apr 11 10:52:51.381: //2267/xxxxxxxxxxxx/CCAPI/ccCallReportDigits:
(callID=0x8DB, digit_event=0x1, enable=TRUE, consume=FALSE)
Apr 11 10:52:51.381: //2267/CA49386D9979/CCAPI/ccCallReportDigits:
Enabled=TRUE, Call Id=2267
Apr 11 10:52:51.381: //2267/xxxxxxxxxxxx/CCAPI/cc_api_call_report_digits_done:
(vdbPtr=0x49EDD59C, callID=0x8DB, disp=0, digit_event=0x1, enable=TRUE, consume=FALSE)
Apr 11 10:52:51.381: //2267/CA49386D9979/CCAPI/cc_api_call_report_digits_done:
Enabled=TRUE, Disposition=0x0, Interface=0x49EDD59C, Call Id=2267
Apr 11 10:52:52.493: //2267/CA49386D9979/CCAPI/cc_api_call_digit_begin:
Source Call Id=2267, Digit=4, DigitBeginFlags=0x0,
Rtp Timestamp=0x13ADD78, Rtp Expiration=0x0
Apr 11 10:52:52.493: //2267/CA49386D9979/CCAPI/cc_api_call_digit_end:
Source Call Id=2267, Digit=4, Duration=100,
Apr 11 10:52:52.493: ISDN Se0/0/0:15 Q931: RX <- CONNECT pd = 8 callref = 0x81DB
Apr 11 10:52:52.505: %ISDN-6-CONNECT: Interface Serial0/0/0:1 is now connected to 2079022320 N/A
Apr 11 10:52:52.505: ISDN Se0/0/0:15 Q931: TX -> CONNECT_ACK pd = 8 callref = 0x01DB
Apr 11 10:52:52.509: //2267/CA49386D9979/CCAPI/cc_api_call_digit_begin:
Rtp Timestamp=0x13B5A78, Rtp Expiration=0x0
Apr 11 10:52:52.509: //2267/CA49386D9979/CCAPI/cc_api_call_digit_end:
Source Call Id=2267, Digit=5, DigitBeginFlags=0x0,
Rtp Timestamp=0x13BD778, Rtp Expiration=0x0
Source Call Id=2267, Digit=5, Duration=100,
Apr 11 10:52:52.513: //2267/CA49386D9979/CCAPI/cc_api_call_digit_end:
Apr 11 10:52:52.513: //2265/C1A844A5996F/CCAPI/cc_api_call_connected:
Interface=0x48402CE4, Data Bitmask=0x1, Progress Indication=NULL(0),
Connection Handle=0
Call Entry(Connected=TRUE, Responsed=TRUE, Retry Count=0)
Apr 11 10:52:52.521: //2267/xxxxxxxxxxxx/CCAPI/ccCallReportDigits:
(callID=0x8DB, digit_event=0x0, enable=FALSE, consume=FALSE)
Apr 11 10:52:52.521: //2267/CA49386D9979/CCAPI/ccCallReportDigits:
Apr 11 10:52:52.521: //2267/xxxxxxxxxxxx/CCAPI/cc_api_call_report_digits_done:
(vdbPtr=0x49EDD59C, callID=0x8DB, disp=0, digit_event=0x0, enable=FALSE, consume=FALSE)
Apr 11 10:52:52.521: //2267/CA49386D9979/CCAPI/cc_api_call_report_digits_done:
Apr 11 10:52:52.521: //2263/C1A844A5996F/CCAPI/ccCallConnect:
Progress Indication=NULL(0), Data Bitmask=0x1
Call Entry(Connected=TRUE, Responsed=TRUE)
Apr 11 10:52:52.521: //2263/C1A844A5996F/CCAPI/ccCallFeature:
Apr 11 10:52:52.529: //2267/CA49386D9979/CCAPI/ccCallProceeding:
Apr 11 10:52:52.529: //2267/CA49386D9979/CCAPI/ccCallSetupRequest:
Outgoing Dial-peer=20016, Params=0x4A38E1F8, Progress Indication=ORIGINATING SIDE IS NON ISDN(3)
Apr 11 10:52:52.529: //2267/CA49386D9979/CCAPI/ccCheckClipClir:
Apr 11 10:52:52.533: //2267/CA49386D9979/CCAPI/ccCheckClipClir:
Apr 11 10:52:52.533: //2267/CA49386D9979/CCAPI/ccCallSetupRequest:
Destination Pattern=445$, Called Number=445, Digit Strip=TRUE
Called Number=445(TON=Unknown, NPI=Unknown),
Redirect Number=, Display Info=455
Guid=CA49386D-A1CC-11E2-9979-9D10B6883F86, Outgoing Dial-peer=20016
Apr 11 10:52:52.533: //2267/CA49386D9979/CCAPI/cc_api_display_ie_subfields:
ccCallSetupRequest:
cisco-username=
cisco-ani=455
cisco-anitype=0
cisco-aniplan=0
cisco-anipi=0
cisco-anisi=0
dest=445
cisco-desttype=0
cisco-destplan=0
cisco-rdie=FFFFFFFF
cisco-rdn=
cisco-lastrdn=
cisco-rdntype=0
cisco-rdnplan=0
cisco-rdnpi=0
cisco-rdnsi=0
Apr 11 10:52:52.533: //2267/CA49386D9979/CCAPI/ccIFCallSetupRequestPrivate:
Interface=0x49DE9FF8, Interface Type=6, Destination=, Mode=0x0,
Call Params(Calling Number=455,(Calling Name=455)(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
Called Number=445(TON=Unknown, NPI=Unknown), Calling Translated=FALSE,
Subscriber Type Str=RegularLine, FinalDestinationFlag=FALSE, Outgoing Dial-peer=20016, Call Count On=FALSE,
Apr 11 10:52:52.533: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Apr 11 10:52:52.533: :cc_get_feature_vsa malloc success
Apr 11 10:52:52.533: cc_get_feature_vsa count is 8
Apr 11 10:52:52.533: :FEATURE_VSA attributes are: feature_name:0,feature_time:1185843496,feature_id:4151
Apr 11 10:52:52.533: //2268/CA49386D9979/CCAPI/ccIFCallSetupRequestPrivate:
Apr 11 10:52:52.533: //2268/CA49386D9979/CCAPI/ccCallSetContext:
Context=0x4A38E1A8
Apr 11 10:52:52.533: //2267/CA49386D9979/CCAPI/ccSaveDialpeerTag:
Apr 11 10:52:52.537: //2268/CA49386D9979/CCAPI/cc_api_update_call_info:
Interface=0x49DE9FF8, Call Id=0x8DC
Apr 11 10:52:52.541: //2268/CA49386D9979/CCAPI/cc_api_call_proceeding:
Interface=0x49DE9FF8, Progress Indication=NULL(0)
Apr 11 10:52:52.541: //2268/CA49386D9979/CCAPI/cc_api_call_alert:
Interface=0x49DE9FF8, Progress Indication=NULL(0), Signal Indication=SIGNAL RINGBACK(1)
Apr 11 10:52:52.545: //2267/CA49386D9979/CCAPI/ccCallAlert:
Apr 11 10:52:52.545: //2267/CA49386D9979/CCAPI/ccCallFeature:
Feature Type=25, Call Id=2267
Apr 11 10:52:54.693: //2268/CA49386D9979/CCAPI/cc_api_call_connected:
Interface=0x49DE9FF8, Data Bitmask=0x1, Progress Indication=NULL(0),
Connection Handle=0
Apr 11 10:52:54.693: //2267/CA49386D9979/CCAPI/ccGenerateToneInfo:
Apr 11 10:52:54.693: //2267/xxxxxxxxxxxx/CCAPI/ccConferenceCreate:
(confID=0x4A44C45C, callID1=0x8DB, callID2=0x8DC, tag=0x0)
(confID=0x4A44C45C, callID1=0x8DB, gcid=CA49386D-A1CC11E2-99799D10-B6883F86, tag=0x0)
Apr 11 10:52:54.693: //2268/xxxxxxxxxxxx/CCAPI/ccConferenceCreate:
(confID=0x4A44C45C, callID2=0x8DC, gcid=CA49386D-A1CC11E2-99799D10-B6883F86, tag=0x0)
Apr 11 10:52:54.693: //2267/CA49386D9979/CCAPI/ccConferenceCreate:
Conference Id=0x4A44C45C, Call Id1=2267, Call Id2=2268, Tag=0x0
Apr 11 10:52:54.693: //2267/xxxxxxxxxxxx/CCAPI/cc_api_bridge_done:
Conference Id=0x319, Source Interface=0x49EDD59C, Source Call Id=2267,
Destination Call Id=2268, Disposition=0x0, Tag=0xFFFFFFFF
Apr 11 10:52:54.693: //2268/xxxxxxxxxxxx/CCAPI/cc_api_bridge_done:
Conference Id=0x319, Source Interface=0x49DE9FF8, Source Call Id=2268,
Destination Call Id=2267, Disposition=0x0, Tag=0xFFFFFFFF
Apr 11 10:52:54.693: //2267/CA49386D9979/CCAPI/cc_generic_bridge_done:
Apr 11 10:52:54.697: //2267/CA49386D9979/CCAPI/ccConferenceCreate:
Call Entry(Conference Id=0x319, Destination Call Id=2268)
Apr 11 10:52:54.697: //2268/CA49386D9979/CCAPI/ccConferenceCreate:
Call Entry(Conference Id=0x319, Destination Call Id=2267)
Apr 11 10:52:54.697: //2267/CA49386D9979/CCAPI/cc_api_caps_ind:
Destination Interface=0x49DE9FF8, Destination Call Id=2268, Source Call Id=2267,
Apr 11 10:52:54.697: //2268/CA49386D9979/CCAPI/cc_api_caps_ind:
Destination Interface=0x49EDD59C, Destination Call Id=2267, Source Call Id=2268,
Apr 11 10:52:54.697: //2268/CA49386D9979/CCAPI/cc_api_caps_ack:
Modem=ON(0x2), Codec Bytes=160, Signal Type=2, Seq Num Start=4277)
Apr 11 10:52:54.697: //2267/CA49386D9979/CCAPI/cc_api_caps_ack:
Modem=ON(0x2), Codec Bytes=160, Signal Type=2, Seq Num Start=7644)
Apr 11 10:52:54.697: //2268/CA49386D9979/CCAPI/cc_api_voice_mode_event:
Call Id=2268
Call Entry(Context=0x4A38E1A8)
Apr 11 10:52:54.701: //2267/CA49386D9979/CCAPI/cc_process_notify_bridge_done:
Conference Id=0x319, Call Id1=2267, Call Id2=2268
Apr 11 10:52:54.701: //2267/CA49386D9979/CCAPI/ccCallConnect:
Apr 11 10:52:54.705: //2267/CA49386D9979/CCAPI/ccCallFeature:
Apr 11 10:52:54.705: //2267/CA49386D9979/CCAPI/cc_api_voice_mode_event:
Call Id=2267
Call Entry(Context=0x4A3966E0)
Apr 11 10:52:58.829: //2264/C405269B9973/CCAPI/cc_api_call_disconnected:
Cause Value=16, Interface=0x49E786A4, Call Id=2264
Call Entry(Responsed=TRUE, Cause Value=1, Retry Count=0)
Apr 11 10:52:58.829: //2264/C405269B9973/CCAPI/ccConferenceDestroy:
Conference Id=0x318, Tag=0x0
Apr 11 10:52:58.829: //2264/xxxxxxxxxxxx/CCAPI/cc_api_bridge_drop_done:
Destination Call Id=2266, Disposition=0x0, Tag=0x0
Apr 11 10:52:58.829: //2266/xxxxxxxxxxxx/CCAPI/cc_api_bridge_drop_done:
Destination Call Id=2264, Disposition=0x0, Tag=0x0
Apr 11 10:52:58.829: //2264/C405269B9973/CCAPI/cc_generic_bridge_done:
Apr 11 10:52:58.829: //2266/C405269B9973/CCAPI/ccCallDisconnect:
Cause Value=1, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=1)
Cause Value=1, Call Entry(Responsed=TRUE, Cause Value=1)
Apr 11 10:52:58.829: //2266/C405269B9973/CCAPI/cc_api_get_transfer_info:
Transfer Number Is Null
Apr 11 10:52:58.833: //2264/C405269B9973/CCAPI/ccCallDisconnect:
Apr 11 10:52:58.833: //2264/C405269B9973/CCAPI/cc_api_get_transfer_info:
Apr 11 10:52:58.833: //2264/C405269B9973/CCAPI/cc_api_call_disc_cause_update:
Cause Value=1
Call Entry(Disconnect Cause=1)
Apr 11 10:52:58.837: //2264/C405269B9973/CCAPI/cc_api_call_disconnect_done:
Disposition=0, Interface=0x49E786A4, Tag=0x0, Call Id=2264,
Call Entry(Disconnect Cause=1, Voice Class Cause Code=0, Retry Count=0)
Call Disconnect Event Sent
Apr 11 10:52:58.837: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Apr 11 10:52:58.837: :cc_free_feature_vsa freeing 46AE8CA0
Apr 11 10:52:58.837: vsacount in free is 7
Apr 11 10:52:58.853: //2266/C405269B9973/CCAPI/cc_api_call_disc_cause_update:
Cause Value=1
Apr 11 10:52:58.853: //2266/C405269B9973/CCAPI/cc_api_call_disconnect_done:
Disposition=0, Interface=0x48402CE4, Tag=0x0, Call Id=2266,
Apr 11 10:52:58.857: //2266/C405269B9973/CCAPI/cc_api_call_disconnect_done:
Apr 11 10:52:58.857: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Apr 11 10:52:58.857: :cc_free_feature_vsa freeing 46AE8AE0
Apr 11 10:52:58.857: vsacount in free is 6
Apr 11 10:52:58.857: ISDN Se0/0/0:15 Q931: TX -> RELEASE pd = 8 callref = 0x01DC
Apr 11 10:52:59.553: ISDN Se0/0/0:15 Q931: RX <- RELEASE_COMP pd = 8 callref = 0x81DC
Apr 11 10:53:22.414: ISDN Se0/0/0:15 Q931: RX <- SETUP pd = 8 callref = 0x0001
Sending Complete
Standard = CCITT
Called Party Number i = 0x81, '704707'
Plan:ISDN, Type:Unknown
Apr 11 10:53:22.414: ISDN Se0/0/0:15 Q931: Received SETUP callref = 0x8001 callID = 0x00B8 switch = primary-net5 interface = User
Apr 11 10:53:22.418: //-1/DCC9BD8D80B9/CCAPI/cc_api_display_ie_subfields:
cisco-username=
cisco-ani=
cisco-anitype=0
cisco-aniplan=0
cisco-anipi=0
cisco-anisi=0
dest=707
cisco-desttype=0
cisco-destplan=1
cisco-rdie=FFFFFFFF
cisco-rdn=
cisco-lastrdn=
cisco-rdntype=-1
cisco-rdnplan=-1
cisco-rdnpi=-1
cisco-rdnsi=-1
cisco-redirectreason=-1 fwd_final_type =0
Apr 11 10:53:22.418: //-1/DCC9BD8D80B9/CCAPI/cc_api_call_setup_ind_common:
Interface=0x48402CE4, Call Info(
Calling Number=,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
Called Number=707(TON=Unknown, NPI=ISDN),
Calling Translated=FALSE, Subscriber Type Str=RegularLine, FinalDestinationFlag=TRUE,
Incoming Dial-peer=10, Progress Indication=NULL(0), Calling IE Present=FALSE,
Apr 11 10:53:22.418: //-1/DCC9BD8D80B9/CCAPI/ccCheckClipClir:
In: Calling Number=(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
Out: Calling Number=(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
Apr 11 10:53:22.418: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Apr 11 10:53:22.418: :cc_get_feature_vsa malloc success
Apr 11 10:53:22.418: cc_get_feature_vsa count is 7
Apr 11 10:53:22.418: :FEATURE_VSA attributes are: feature_name:0,feature_time:1185843944,feature_id:4152
Apr 11 10:53:22.418: //2269/DCC9BD8D80B9/CCAPI/cc_api_call_setup_ind_common:
Set Up Event Sent;
Call Info(Calling Number=(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
Called Number=707(TON=Unknown, NPI=ISDN))
Apr 11 10:53:22.422: //2269/DCC9BD8D80B9/CCAPI/cc_process_call_setup_ind:
Event=0x483B91D0
Apr 11 10:53:22.422: //-1/xxxxxxxxxxxx/CCAPI/cc_setupind_match_search:
Try with the demoted called number 707
Apr 11 10:53:22.422: //2269/DCC9BD8D80B9/CCAPI/ccCallSetContext:
Context=0x4A3953D8
>>>>CCAPI handed cid 2269 with tag 10 to app "_ManagedAppProcess_Default"
Apr 11 10:53:22.422: //2269/DCC9BD8D80B9/CCAPI/ccCallProceeding:
Apr 11 10:53:22.426: //-1/xxxxxxxxxxxx/CCAPI/ccUpdateRedirectingNumber:
type=6 redirecting_number=707
Apr 11 10:53:22.426: //-1/xxxxxxxxxxxx/CCAPI/ccUpdateRedirectNumber:
type=6 Original Called Number=707, Called Number=707, Calling Number=, Calling DN=-1 Calling Id=2269,
Redirect Number=455, Redirect Reason=15
Apr 11 10:53:22.426: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Apr 11 10:53:22.426: :cc_get_feature_vsa malloc success
Apr 11 10:53:22.426: cc_get_feature_vsa count is 8
Apr 11 10:53:22.426: :FEATURE_VSA attributes are: feature_name:0,feature_time:1185844392,feature_id:4153
Apr 11 10:53:22.426: //-1/xxxxxxxxxxxx/CCAPI/cc_update_feature_vsa:
Apr 11 10:53:22.426: feature_vsa is 46AE8AE0,featname is 0
Apr 11 10:53:22.426: cc_get_feature_vsa count is 9
Apr 11 10:53:22.426: :FEATURE_VSA attributes are: feature_name:0,feature_time:1185843272,feature_id:4154
Apr 11 10:53:22.426: : Generating new featurevsa,inserting it
Apr 11 10:53:22.426: feature call forward featname is 1
Apr 11 10:53:22.426: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Apr 11 10:53:22.426: :cc_free_feature_vsa freeing 46AE8CA0
Apr 11 10:53:22.426: vsacount in free is 8
Apr 11 10:53:22.430: ISDN Se0/0/0:15 Q931: TX -> CALL_PROC pd = 8 callref = 0x8001
Apr 11 10:53:22.430: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Apr 11 10:53:22.430: :cc_get_feature_vsa malloc success
Apr 11 10:53:22.430: cc_get_feature_vsa count is 9
Apr 11 10:53:22.430: :FEATURE_VSA attributes are: feature_name:0,feature_time:1185844392,feature_id:4155
Apr 11 10:53:22.430: //-1/xxxxxxxxxxxx/CCAPI/cc_update_feature_vsa:
Apr 11 10:53:22.430: feature call forward featname is 1
Apr 11 10:53:22.430: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Apr 11 10:53:22.430: :cc_free_feature_vsa freeing 46AE8CA0
Apr 11 10:53:22.430: vsacount in free is 8
Apr 11 10:53:22.430: //2269/DCC9BD8D80B9/CCAPI/ccGetTBCTCap:
TGRM TBCT Enabled; TBCT Capability=0
Apr 11 10:53:22.434: //2269/DCC9BD8D80B9/CCAPI/ccCallSetupRequest:
Destination=, Calling IE Present=FALSE, Mode=0,
Outgoing Dial-peer=20026, Params=0x4A38BBE8, Progress Indication=ORIGINATING SIDE IS NON ISDN(3)
Apr 11 10:53:22.434: //2269/DCC9BD8D80B9/CCAPI/ccCheckClipClir:
Destination Pattern=455$, Called Number=455, Digit Strip=TRUE
Called Number=455(TON=Unknown, NPI=ISDN),
Redirect Number=707, Display Info=
Account Number=, Final Destination Flag=TRUE,
Guid=DCCC2EC5-A1CC-11E2-9982-9D10B6883F86, Outgoing Dial-peer=20026
Apr 11 10:53:22.434: //2269/DCC9BD8D80B9/CCAPI/cc_api_display_ie_subfields:
ccCallSetupRequest:
cisco-username=
cisco-ani=
cisco-anitype=0
cisco-aniplan=0
cisco-anipi=0
cisco-anisi=0
dest=455
cisco-desttype=0
cisco-destplan=1
cisco-rdie=73
cisco-rdn=707
cisco-lastrdn=
cisco-rdntype=0
cisco-rdnplan=0
cisco-rdnpi=0
cisco-rdnsi=0
cisco-redirectreason=15 fwd_final_type =0
Apr 11 10:53:22.434: //2269/DCC9BD8D80B9/CCAPI/ccIFCallSetupRequestPrivate:
Interface=0x49EDD59C, Interface Type=6, Destination=, Mode=0x0,
Call Params(Calling Number=,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
Called Number=455(TON=Unknown, NPI=ISDN), Calling Translated=FALSE,
Subscriber Type Str=RegularLine, FinalDestinationFlag=TRUE, Outgoing Dial-peer=20026, Call Count On=FALSE,
Apr 11 10:53:22.434: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Apr 11 10:53:22.434: :cc_get_feature_vsa malloc success
Apr 11 10:53:22.434: cc_get_feature_vsa count is 9
Apr 11 10:53:22.434: :FEATURE_VSA attributes are: feature_name:0,feature_time:1185844392,feature_id:4156
Apr 11 10:53:22.434: //2270/DCC9BD8D80B9/CCAPI/ccIFCallSetupRequestPrivate:
Apr 11 10:53:22.434: //2270/DCC9BD8D80B9/CCAPI/ccCallSetContext:
Context=0x4A38BB98
Apr 11 10:53:22.434: //2269/DCC9BD8D80B9/CCAPI/ccSaveDialpeerTag:
Apr 11 10:53:22.434: //-1/xxxxxxxxxxxx/CCAPI/cc_update_feature_vsa:
Apr 11 10:53:22.434: feature call forward featname is 1
Apr 11 10:53:22.434: feature_vsa is 46AE8CA0,featname is 0
Apr 11 10:53:22.434: cc_get_feature_vsa count is 10
Apr 11 10:53:22.434: :FEATURE_VSA attributes are: feature_name:0,feature_time:1185843048,feature_id:4157
Apr 11 10:53:22.434: : Generating new featurevsa,inserting it
Apr 11 10:53:22.438: //2270/DCC9BD8D80B9/CCAPI/cc_api_update_call_info:
Interface=0x49EDD59C, Call Id=0x8DE
Apr 11 10:53:22.442: //2270/DCC9BD8D80B9/CCAPI/cc_api_call_proceeding:
Interface=0x49EDD59C, Progress Indication=NULL(0)
Apr 11 10:53:22.442: //2270/DCC9BD8D80B9/CCAPI/cc_api_call_alert:
Interface=0x49EDD59C, Progress Indication=NULL(0), Signal Indication=SIGNAL RINGBACK(1)
Apr 11 10:53:22.446: //2269/DCC9BD8D80B9/CCAPI/ccCallAlert:
Apr 11 10:53:22.446: //2269/DCC9BD8D80B9/CCAPI/ccGenerateToneInfo:
Stop Tone On Digit=FALSE, Tone=Ring Back,
Tone Direction=Network, Params=0x0, Call Id=2269
Apr 11 10:53:22.446: //2270/DCC9BD8D80B9/CCAPI/ccCallFeature:
Feature Type=25, Call Id=2270
Apr 11 10:53:22.450: ISDN Se0/0/0:15 Q931: TX -> ALERTING pd = 8 callref = 0x8001
Progress Ind i = 0x8188 - In-band info or appropriate now available
04-11-2013 04:13 AM
Pete,
You will need to speak to your Telco provider...They are disconnecting the call. Looks like they cant route these local numbers
04-11-2013 04:51 AM
Hi Pete,
Something doesn't tie up. The output you posted shows the call using a Dial Peers that I can't see listed in your config.
Also noticed that further down it attempts to use Incoming Dial-peer=20020.
Can you post your Dial-Peer config? It seems your router may be trying to send the numbers down the wrong dial peer. Best to run a "debug voice ccapi inout" to find which Dial Peer it is definitely using.
04-11-2013 05:06 AM
I am certain this is a CCME setup..Thats why you see those dial-peers.
Incoming dial-peer 20020 is a different call and it is for xtension 449.
04-11-2013 05:35 AM
It's quite a busy system so it's likely there are other calls going on at the same time as my debug logs.
See below for full config, minus a few details stripped out:
version 12.4
service password-encryption
boot-start-marker
boot system flash c2800nm-spservicesk9-mz.124-24.T2.bin
boot-end-marker
card type e1 0 0
logging message-counter syslog
logging buffered 51200 warnings
enable password 7 13151601181B0B382F
no aaa new-model
clock timezone GMT 0
clock summer-time BST recurring last Sun Mar 1:00 last Sun Oct 1:00
network-clock-participate wic 0
network-clock-select 1 E1 0/0/0
dot11 syslog
ip source-route
ip cef
ip dhcp pool Voice
no ipv6 cef
isdn switch-type primary-net5
voice rtp send-recv
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
supplementary-service h450.12
fax protocol cisco
h323
h225 timeout setup 3
modem passthrough nse codec g711alaw
voice class codec 1
codec preference 1 g711alaw
codec preference 2 g711ulaw
rule 1 /^3934/ /4/
rule 2 /^7047/ /7/
voice-card 0
username Administrator privilege 15 secret
archive
log config
hidekeys
controller E1 0/0/0
framing NO-CRC4
pri-group timeslots 1-31
no ip ftp passive
interface GigabitEthernet0/0
description ***LAN Interface***
ip address 172.16.2.230 255.255.255.0
duplex auto
speed auto
interface GigabitEthernet0/1
no ip address
shutdown
duplex auto
speed auto
interface Serial0/0/0:15
no ip address
encapsulation hdlc
isdn overlap-receiving T302 6000
isdn incoming-voice voice
isdn send-alerting
isdn bchan-number-order ascending
no cdp enable
interface Integrated-Service-Engine1/0
ip unnumbered GigabitEthernet0/0
ip ospf network point-to-point
service-module ip address 172.16.2.231 255.255.255.0
!Application: CUE Running on NME
service-module ip default-gateway 172.16.2.230
no keepalive
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 172.16.2.254
ip route 172.16.2.231 255.255.255.255 Integrated-Service-Engine1/0
ip http server
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip http path flash:
tftp-server SCCP70.9-1-1SR1S.loads alias SCCP70.9-1-1SR1S.loads
tftp-server cmterm-7942_7962-sccp.8-3-2SR1/apps42.8-3-2SR1.sbn alias apps42.8-3-2SR1.sbn
tftp-server cmterm-7942_7962-sccp.8-3-2SR1/cnu42.8-3-2SR1.sbn alias cnu42.8-3-2SR1.sbn
tftp-server cmterm-7942_7962-sccp.8-3-2SR1/cvm42sccp.8-3-2SR1.sbn alias cvm42sccp.8-3-2SR1.sbn
tftp-server cmterm-7942_7962-sccp.8-3-2SR1/dsp42.8-3-2SR1.sbn alias dsp42.8-3-2SR1.sbn
tftp-server cmterm-7942_7962-sccp.8-3-2SR1/jar42sccp.8-3-2SR1.sbn alias jar42sccp.8-3-2SR1.sbn
tftp-server cmterm-7942_7962-sccp.8-3-2SR1/SCCP42.8-3-2SR1S.loads alias SCCP42.8-3-2SR1S.loads
tftp-server cmterm-7942_7962-sccp.8-3-2SR1/term42.default.loads alias term42.default.loads
tftp-server cmterm-7942_7962-sccp.8-3-2SR1/term62.default.loads alias term62.default.loads
control-plane
voice-port 0/0/0:15
cptone GB
ccm-manager music-on-hold
port 0/0/0:15
direct-inward-dial
voice-class codec 1
dial-peer voice 801 voip
description Voicemail
destination-pattern 801
session protocol sipv2
session target ipv4:172.16.2.231
dtmf-relay sip-notify
codec g711ulaw
no vad
dial-peer voice 999 pots
description ** Emergency calls **
destination-pattern 999
port 0/0/0:15
prefix 999
dial-peer voice 9990 pots
destination-pattern 9999
port 0/0/0:15
prefix 999
sip-ua
mwi-server ipv4:172.16.2.231 expires 3600 port 5060 transport udp unsolicited
telephony-service
authentication credential Administrator nbvuga
max-ephones 110
max-dn 288
ip source-address 172.16.2.230 port 2000
timeouts interdigit 4
url services http://172.16.2.230/voiceview/common/login.do
url authentication http://172.16.2.230/CCMCIP/authenticate.asp
cnf-file location flash:
load 7942 SCCP42.8-3-2SR1S
load 7970 SCCP70.9-1-1SR1S
time-zone 21
time-format 24
date-format dd-mm-yy
voicemail 801
max-conferences 8 gain -6
call-forward pattern .T
moh music-on-hold.au
multicast moh 239.1.1.1 port 16384
web admin system name Administrator secret 5 $1$oBGz$qGlAWDYs066Y4uafQ3l2n/
dn-webedit
time-webedit
transfer-system full-consult
transfer-pattern .T
secondary-dialtone 9
create cnf-files version-stamp 7960 Apr 04 2013 22:48:59
ephone-hunt 1 sequential
pilot 01256000000
list 463, 439, 434, 437
line con 0
password 7 03145A1815182E5E4A
login
line aux 0
line 66
no activation-character
no exec
transport preferred none
transport input all
transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
line vty 0 4
password 7
login
transport input telnet ssh
line vty 5 15
password 7 021605481811003348
login
scheduler allocate 20000 1000
end
04-11-2013 05:42 AM
It looks like you are stripping 90 rather than just 9 before sending the dialled digits to the ISDN switch - assume this is in Basingstoke UK? - the telco will not route the call if it is missing the leading zero
04-11-2013 05:44 AM
I did think that. Is that on the 103 rule?
Assuming we should be removing the rule 2 from here?
04-11-2013 05:50 AM
Pete,
04-11-2013 05:51 AM
James (+5) good spot..Didnt even realise this was a UK number
04-11-2013 05:57 AM
Removed rule 2, still the same issue.
Also tried removing rule 1 and again - the same issue.
Next ideas?
04-11-2013 05:59 AM
Ah, so should I be switching the translate calling / called around?
calling 103 and called 102?
04-11-2013 06:01 AM
Yes..
Please send a new debug isdn q931..so we can see what you are sending out
04-11-2013 06:22 AM
Fantastic, that's the winner!
Changing the translate calling / called around seems to have done the trick.
Massive thanks to all for your assistance.
