ā09-29-2012 11:36 AM - edited ā03-16-2019 01:27 PM
for the life of me I can't get this dial-peer to match so I can route fax to email. I've attached the relavant config areas. I need to make it so that when someone dials into the line 4801234567 it matches dial-peer 7. It always grabs dial-peer 8 and is sent into the auto attendant. We have a PRI that brings in around 20 phone lines to the serial 0/2/0:23 port. I have tried to remove dial-peer 8 and dial-peer 7 still won't match. I have included information from the debug voip dial-peer.
What am I doing wrong? thanks
Voice Translations
voice translation-rule 1
rule 1 /4801234567/ /801/
voice translation-rule 4
rule 15 // //
voice translation-rule 5
rule 15 // //
voice translation-rule 9
rule 1 /^911$/ /911/
rule 2 /^9\(.*\)/ /\1/
rule 3 /^1400/ /400/
rule 4 /^3335/ /212/
rule 5 /^6366/ /201/
rule 6 /^08../ /400/
rule 7 /^63../ /400/
voice translation-rule 1000
rule 1 /.*/ //
voice translation-rule 1111
voice translation-rule 1112
rule 1 /^8/ //
voice translation-rule 2002
rule 1 /^6/ //
voice translation-rule 2222
rule 1 /^91900......./ //
rule 2 /^91976......./ //
voice translation-profile CALLER_ID_TRANSLATION_PROFILE
translate calling 1111
voice translation-profile CallBlocking
translate called 2222
voice translation-profile INCOMING-FAX
translate called 1
voice translation-profile OUTGOING_TRANSLATION_PROFILE
translate called 1112
voice translation-profile PROFILE_ALL_T1E1
translate calling 5
voice translation-profile XFER_TO_VM_PROFILE
translate redirect-called 2002
voice translation-profile nondialable
translate called 1000
voice translation-profile translation-incoming
translate called 9
Dial-Peers
dial-peer cor list call-internal
member internal
dial-peer cor list call-local
member local
dial-peer cor list call-domestic
member domestic
dial-peer cor list call-international
member international
dial-peer cor list call-900
member 900
dial-peer cor list call-976
member 976
dial-peer cor list user-internal
member internal
member emergency
dial-peer cor list user-local
member internal
member local
member emergency
member toll-free
dial-peer cor list user-domestic
member internal
member local
member domestic
member local-plus
member national
member emergency
member toll-free
dial-peer cor list user-international
member internal
member local
member domestic
member local-plus
member national
member national-plus
member emergency
member toll-free
dial-peer cor list user900-internal
member internal
member 900
member 976
dial-peer cor list user900-local
member internal
member local
member 900
member 976
dial-peer cor list user900-domestic
member internal
member local
member domestic
member 900
member 976
dial-peer cor list user900-international
member internal
member local
member domestic
member 900
member 976
dial-peer cor list call-local-plus
member local-plus
dial-peer cor list call-national
member national
dial-peer cor list call-national-plus
dial-peer cor list call-emergency
member emergency
dial-peer cor list call-toll-free
member toll-free
dial-peer cor list user-local-plus
member internal
member local
member local-plus
member emergency
member toll-free
dial-peer cor list user-national
member internal
member local
member domestic
member local-plus
member national
member emergency
member toll-free
dial-peer cor list user-national-plus
member internal
member local
member domestic
member local-plus
member national
member emergency
member toll-free
dial-peer voice 1 pots
service stcapp
port 0/0/0
dial-peer voice 2 pots
service stcapp
port 0/0/1
dial-peer voice 3 pots
service stcapp
port 0/0/2
dial-peer voice 4 pots
service stcapp
port 0/0/3
dial-peer voice 5 pots
description ** MOH Port **
destination-pattern ABC
port 0/4/0
no sip-register
dial-peer voice 50 pots
description ** incoming dial peer **
incoming called-number ^AAAA$
port 0/1/0
dial-peer voice 51 pots
port 0/1/1
dial-peer voice 52 pots
port 0/1/2
dial-peer voice 53 pots
port 0/1/3
dial-peer voice 2000 voip
description ** cue voicemail pilot number **
translation-profile outgoing XFER_TO_VM_PROFILE
destination-pattern 401
session protocol sipv2
session target ipv4:10.1.10.1
dtmf-relay sip-notify
codec g711ulaw
no vad
dial-peer voice 2001 voip
description ** cue auto attendant number **
translation-profile outgoing PSTN_CallForwarding
destination-pattern 400
codec g711ulaw
no vad
dial-peer voice 54 pots
corlist outgoing call-emergency
description **CCA*North American-10-Digit*Emergency**
translation-profile outgoing OUTGOING_TRANSLATION_PROFILE
preference 5
destination-pattern 8911
port 0/2/0:23
forward-digits all
no sip-register
dial-peer voice 55 pots
preference 5
destination-pattern 911
port 0/2/0:23
forward-digits all
no sip-register
dial-peer voice 56 pots
corlist outgoing call-local
description **CCA*North American-10-Digit*10-Digit Local**
preference 5
destination-pattern 8[2-9]..[2-9]......
port 0/2/0:23
forward-digits all
no sip-register
dial-peer voice 57 pots
description **CCA*North American-10-Digit*Service Numbers**
preference 5
destination-pattern 8[2-9]11
port 0/2/0:23
forward-digits all
no sip-register
dial-peer voice 58 pots
corlist outgoing call-national
description **CCA*North American-10-Digit*Long Distance**
preference 5
destination-pattern 81[2-9]..[2-9]......
port 0/2/0:23
forward-digits all
no sip-register
dial-peer voice 60 pots
corlist outgoing call-international
description **CCA*North American-10-Digit*International**
preference 5
destination-pattern 8011T
port 0/2/0:23
forward-digits all
no sip-register
dial-peer voice 61 pots
corlist outgoing call-toll-free
description **CCA*North American-10-Digit*Toll-Free**
preference 5
destination-pattern 81800.......
port 0/2/0:23
forward-digits all
no sip-register
dial-peer voice 62 pots
preference 5
destination-pattern 81888.......
port 0/2/0:23
forward-digits all
no sip-register
dial-peer voice 63 pots
preference 5
destination-pattern 81877.......
port 0/2/0:23
forward-digits all
no sip-register
dial-peer voice 64 pots
preference 5
destination-pattern 81866.......
port 0/2/0:23
forward-digits all
no sip-register
dial-peer voice 2012 voip
description ** cue prompt manager number **
destination-pattern 402
b2bua
voice-class sip outbound-proxy ipv4:10.1.10.1
codec g711ulaw
no vad
dial-peer voice 2500 mmoip
description FAX TO EMAIL
service fax_on_vfc_onramp_app out-bound
information-type fax
session target mailto:801@10.1.10.1
dial-peer voice 8 pots
description ** T1 PRI pots dial-peer **
incoming called-number .
direct-inward-dial
port 0/2/0:23
dial-peer voice 7 pots
description ** Incoming FAX **
translation-profile incoming INCOMING-FAX
service onramp
incoming called-number 4801234567
direct-inward-dial
port 0/2/0:23
Debug
UC520#a debug voip dialpeer inout ce call
Sep 29 18:11:16.021: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
Calling Number=4808625579, Called Number=400, Voice-Interface=0x868C6AF8,
Timeout=TRUE, Peer Encap Type=ENCAP_VOICE, Peer Search Type=PEER_TYPE_VOICE,
Peer Info Type=DIALPEER_INFO_SPEECH
Result=Success(0) after DP_MATCH_INCOMING_DNIS; Incoming Dial-peer=8
Calling Number=4808625579, Called Number=400, Voice-Interface=0x0,
Peer Info Type=DIALPEER_INFO_FAX
Result=NO_MATCH(-1) After All Match Rules Attempt
Sep 29 18:11:16.021: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
Calling Number=, Called Number=400, Peer Info Type=DIALPEER_INFO_SPEECH
Match Rule=DP_MATCH_DEST; Called Number=400
Sep 29 18:11:16.025: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
Result=Success(0) after DP_MATCH_DEST
Sep 29 18:11:16.025: //-1/xxxxxxxxxxxx/DPM/dpMatchPeers:
Result=SUCCESS(0)
List of Matched Outgoing Dial-peer(s):
1: Dial-peer Tag=2001
Sep 29 18:11:16.029: //-1/E4F06F4F8059/DPM/dpMatchPeersCore:
Sep 29 18:11:16.029: //-1/E4F06F4F8059/DPM/dpMatchPeersMoreArg:
Result=SUCCESS(0)
Sep 29 18:11:16.029: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
Calling Number=400, Called Number=400, Peer Info Type=DIALPEER_INFO_SPEECH
Sep 29 18:11:16.029: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
Result=SUCCESS(0)
Result=SUCCESS(0)
Sep 29 18:11:16.029: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
Calling Number=400, Called Number=, Voice-Interface=0x0,
Timeout=TRUE, Peer Encap Type=ENCAP_VOIP, Peer Search Type=PEER_TYPE_VOICE,
Result=Success(0) after DP_MATCH_ORIGINATE; Incoming Dial-peer=2001
Sep 29 18:11:16.033: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
Sep 29 18:11:16.033: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
Result=SUCCESS(0)
Sep 29 18:11:16.033: //-1/E4F06F4F8059/DPM/dpMatchPeersCore:
Sep 29 18:11:16.033: //-1/E4F06F4F8059/DPM/dpMatchPeersMoreArg:
Result=SUCCESS(0)
Sep 29 18:11:16.089: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
Calling Number=, Called Number=4808625579, Peer Info Type=DIALPEER_INFO_SPEECH
Solved! Go to Solution.
ā09-30-2012 12:52 AM
Here is the config
(First dial 801 internally and check what are you getting
(Second be sure that the incoming number is always 6363 and not nothing else
You are using rules that they are overlapping ..Remove anything that is not neccessary
(Save config and reload the router)
application
service onramp flash:/faxtoemail/app_faxmail_onramp.2.0.1.3.tcl
fax receive called-subscriber 6363
fax interface-type fax-mail
mta send server 192.168.10.5 port 25
mta send subject FAX Message
mta send postmaster fax@technologyspec.com
mta send mail-from hostname technologyspec.com
mta send mail-from username $s$
description FAX to EMAIL
session target mailto:801@technologyspec.com
description Incoming Fax
service onramp
incoming called-number 6363
direct-inward-dial
port 0/2/0:23
description Incoming General
direct-inward-dial
preference 1
rule 1 /6363/ /801/
translate called 1
ā09-29-2012 11:57 AM
My advice is to proceed with the below..
ONLY AS I SHOW BELOW AND TRY A TEST CALL
direct-inward-dial
service onramp
port 0/2/0:23
From the debug that you have provided i saw 400 called number and not 801.So we need also deb isdn q931, amd debug voice dial peer
ā09-29-2012 12:14 PM
thank you for your quick response.
so you are saying that if it used dial-peer 7 it would have shown the called number as 801 due to translating it? I did what you asked. here is output. seems to be throwing it in that 400 called number still. not sure why.
Sep 29 19:17:03.168: ISDN Se0/2/0:23 Q931: RX <- SETUP pd = 8 callref = 0x0F57
Bearer Capability i = 0x8090A2
Standard = CCITT
Transfer Capability = Speech
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0xA18381
Preferred, Channel 1
Facility i = 0x9F8B0100A116020101020100800E5348554D414B45522C4A45535345
Protocol Profile = Networking Extensions
0xA116020101020100800E5348554D414B45522C4A45535345
Component = Invoke component
Invoke Id = 1
Operation = CallingName
Name Presentation Allowed Extended
Name = SHUMAKER,JESSE
Calling Party Number i = 0x0080, '4808625579'
Plan:Unknown, Type:Unknown
Called Party Number i = 0x80, '6363'
Sep 29 19:17:03.168: ISDN Se0/2/0:23 Q931: Received SETUP callref = 0x8F57 callID = 0x005E switch = primary-ni interface = User
Sep 29 19:17:03.168: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
Sep 29 19:17:03.172: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
Sep 29 19:17:03.172: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
Sep 29 19:17:03.172: //-1/xxxxxxxxxxxx/DPM/dpMatchPeers:
Result=SUCCESS(0)
Sep 29 19:17:03.176: //-1/159F456B805F/DPM/dpMatchPeersCore:
Sep 29 19:17:03.176: //-1/159F456B805F/DPM/dpMatchPeersMoreArg:
Result=SUCCESS(0)
Sep 29 19:17:03.176: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
Sep 29 19:17:03.176: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
Result=SUCCESS(0)
Result=SUCCESS(0)
Sep 29 19:17:03.176: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
Sep 29 19:17:03.180: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
Sep 29 19:17:03.180: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
Sep 29 19:17:03.180: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
Result=SUCCESS(0)
Sep 29 19:17:03.180: //-1/159F456B805F/DPM/dpMatchPeersCore:
Sep 29 19:17:03.180: //-1/159F456B805F/DPM/dpMatchPeersMoreArg:
Result=SUCCESS(0)
Sep 29 19:17:03.188: ISDN Se0/2/0:23 Q931: TX -> CALL_PROC pd = 8 callref = 0x8F57
Channel ID i = 0xA98381
Exclusive, Channel 1
Sep 29 19:17:03.248: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
Match Rule=DP_MATCH_DEST; Called Number=4808625579
No Outgoing Dial-peer Is Matched; Result=NO_MATCH(-1)
Sep 29 19:17:03.248: //-1/xxxxxxxxxxxx/DPM/dpMatchPeers:
Result=NO_MATCH(-1)
Result=SUCCESS(0)
Sep 29 19:17:03.248: ISDN Se0/2/0:23 Q931: TX -> ALERTING pd = 8 callref = 0x8F57
Sep 29 19:17:03.304: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
Sep 29 19:17:03.304: //-1/xxxxxxxxxxxx/DPM/dpMatchPeers:
Result=NO_MATCH(-1)
Result=SUCCESS(0)
Sep 29 19:17:03.304: ISDN Se0/2/0:23 Q931: TX -> CONNECT pd = 8 callref = 0x8F57
Sep 29 19:17:03.328: ISDN Se0/2/0:23 Q931: RX <- CONNECT_ACK pd = 8 callref = 0x0F57
Sep 29 19:17:03.328: %ISDN-6-CONNECT: Interface Serial0/2/0:0 is now connected to 4808625579 N/A
Sep 29 19:17:06.548: ISDN Se0/2/0:23 Q931: RX <- DISCONNECT pd = 8 callref = 0x0F57
Cause i = 0x8290 - Normal call clearing
Sep 29 19:17:06.548: %ISDN-6-CONNECT: Interface Serial0/2/0:0 is now connected to 4808625579 N/A
Sep 29 19:17:06.548: %ISDN-6-DISCONNECT: Interface Serial0/2/0:0 disconnected from 4808625579 , call lasted 3 seconds
Sep 29 19:17:06.552: ISDN Se0/2/0:23 Q931: TX -> RELEASE pd = 8 callref = 0x8F57
Sep 29 19:17:06.568: ISDN Se0/2/0:23 Q931: RX <- RELEASE_COMP pd = 8 callref = 0x0F57
ā09-29-2012 12:28 PM
You hit rule 7 (this is the problem)
So 6363 translated to 400..
what is the called number that you dial
chrysostomos
ā09-29-2012 05:55 PM
** READ MY NEXT POST BELOW **
ok so with that said how can I make the translation rule 1 take precedence over 9? the number is 4807296363.
I guess from now understanding this and seeing that only the last 4 digits arrive to my call manager, I need to modify rule 7 and place it under my voice translation 1 in order for the fax to use it. how does what I've changed look? so it's the only number that will be used. should I keep the rule 7 in place as it is because it will fall in after rule 1 and pick up all the numbers that start in 63 but end in other digits?
rule 1 /^6363/ /801/
ā09-29-2012 01:35 PM
Your translation profile for incoming call is using rule set 9. To what do you have the below profile attached?
translate called 9
Please rate all useful posts.
ā09-29-2012 07:14 PM
any ideas?
It looks like I still need this to be the dial-peer that takes the incoming call, mainly because it will start the onramp fax service. I'm just not sure how to make it the dial-peer that grabs calls to this number (4807296363).
service onramp
incoming called-number .6363
direct-inward-dial
port 0/2/0:23
thanks
ā09-29-2012 08:24 PM
Matching an inbound dial-peer is usually done using the incoming called-number.
Configure dial-peer 7 to have incoming called of 6363 and dial peer 8 to have incoming called of ....
Both should be four digits (or symbols) so that the more specific one will be selected. If 8 has a shorter pattern than 7, ios will always pick 8.
Sent from Cisco Technical Support Android App
ā09-29-2012 08:30 PM
What's the purpose of the translation? Why not leave it a the 6363 it comes with?
ā09-29-2012 10:09 PM
well I tried that and it gave the following debug output and gave a dial tone when I dialed the number from my phone. the number being 4807296363. nothing worked so I changed it back. here's the config now. I'm using it for inbound fax to email. I basically need the dial-peer 7 to grab calls to this number so it sends it into the fax service.
Here is the link I'm following on doing this:
https://communities.cisco.com/thread/7861
Fax Code
fax receive called-subscriber 4807296363
application
Voice Translations
rule 15 // //
rule 15 // //
rule 1 /.*/ //
rule 1 /^8/ //
rule 1 /^6/ //
translate called 1
translate calling 5
translate called 9
Dial Peers
service stcapp
port 0/0/0
service stcapp
port 0/0/1
service stcapp
port 0/0/2
service stcapp
port 0/0/3
port 0/4/0
no sip-register
port 0/1/0
port 0/1/1
port 0/1/2
port 0/1/3
codec g711ulaw
no vad
codec g711ulaw
no vad
preference 5
port 0/2/0:23
forward-digits all
no sip-register
preference 5
port 0/2/0:23
forward-digits all
no sip-register
preference 5
port 0/2/0:23
forward-digits all
no sip-register
preference 5
port 0/2/0:23
forward-digits all
no sip-register
preference 5
port 0/2/0:23
forward-digits all
no sip-register
preference 5
port 0/2/0:23
forward-digits all
no sip-register
preference 5
port 0/2/0:23
forward-digits all
no sip-register
preference 5
port 0/2/0:23
forward-digits all
no sip-register
preference 5
port 0/2/0:23
forward-digits all
no sip-register
preference 5
port 0/2/0:23
forward-digits all
no sip-register
b2bua
codec g711ulaw
no vad
incoming called-number ....
direct-inward-dial
service onramp
direct-inward-dial
port 0/2/0:23
Sep 30 04:58:54.160: ISDN Se0/2/0:23 Q931: RX <- SETUP pd = 8 callref = 0x0F71
Standard = CCITT
Invoke Id = 1
Sep 30 04:58:54.160: ISDN Se0/2/0:23 Q931: Received SETUP callref = 0x8F71 callID = 0x0078 switch = primary-ni interface = User
Sep 30 04:58:54.164: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
Result=Success(0) after DP_MATCH_PORT; Incoming Dial-peer=54
Sep 30 04:58:54.172: ISDN Se0/2/0:23 Q931: TX -> CALL_PROC pd = 8 callref = 0x8F71
Sep 30 04:58:54.172: ISDN Se0/2/0:23 Q931: TX -> CONNECT pd = 8 callref = 0x8F71
Sep 30 04:58:54.200: ISDN Se0/2/0:23 Q931: RX <- CONNECT_ACK pd = 8 callref = 0x0F71
Sep 30 04:58:54.200: %ISDN-6-CONNECT: Interface Serial0/2/0:0 is now connected to 4808625579 N/A
UC520#
Sep 30 04:58:57.180: ISDN Se0/2/0:23 Q931: RX <- DISCONNECT pd = 8 callref = 0x0F71
Sep 30 04:58:57.184: %ISDN-6-CONNECT: Interface Serial0/2/0:0 is now connected to 4808625579 N/A
Sep 30 04:58:57.184: %ISDN-6-DISCONNECT: Interface Serial0/2/0:0 disconnected from 4808625579 , call lasted 2 seconds
Sep 30 04:58:57.184: ISDN Se0/2/0:23 Q931: TX -> RELEASE pd = 8 callref = 0x8F71
Sep 30 04:58:57.200: ISDN Se0/2/0:23 Q931: RX <- RELEASE_COMP pd = 8 callref = 0x0F71
ā09-29-2012 11:49 PM
In the debug it shows that it uses dial peer 54 as the incoming.
Please post your entire config and both calling and called number, along with a debug isdn q931 for an incoming call to the fax.
Here is the config
application
service onramp
direct-inward-dial
port 0/2/0:23
direct-inward-dial
preference 1
rule 1 /6363/ /801/
translate called 1
ā09-30-2012 08:14 AM
thank you very much. your config fixed it all and it's working great. I did make the port on the dial-peer 7 0/2/0:23. 15 wasn't an option.
ā09-30-2012 08:30 AM
Glad to hear that
0/2/0:15 is for E1 PRI ,
In your case is 0/2/0:23 because is T1 PRI
So yes 0/2/0:15 is not an option
Thank you for the nice rating
chrysotomos
ā09-30-2012 08:38 AM
I still don't know what made the difference though compared to the other config I had last night. I couldn't get dial-peer 7 to grab the call first but it works great this morning. I removed the preference 1 on the dial-peer 8 and changed the incoming called to .... and it still grabbed dial-peer 7. This was really where the crux of the issue was.
What do you think?
