ā04-10-2017 02:06 AM - edited ā03-17-2019 10:03 AM
Hello, guys!
I try to connect a cme node to my cucm server, and have a problem with calls in cme -> cucm direction. When I try to place a call over sip dial-peer, it returns (service or option not available unspecified (63)) error.
I can't find the root cause of 63 error, and looking for any help to investigate this error cause.
Debug ccapi inout for problem call in attachment.
My config for voice:
voice service voip
cti message device-id suppress-conversion
cti csta mode basic
no cti shutdown
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
h323
no call service stop
sip
registrar server expires max 86400 min 3600
dial-peer voice 7772 voip
description CUCM-Trunk-SIP
destination-pattern 4[2,3]..$
session protocol sipv2
session target ipv4:10.177.14.130
voice-class sip dtmf-relay force rtp-nte
dtmf-relay rtp-nte
codec g711ulaw
no vad
no supplementary-service sip moved-temporarily
no supplementary-service sip refer
sccp local Loopback1
sccp ccm 10.177.20.1 identifier 1 version 7.0
sccp ccm 172.24.1.1 identifier 2 version 7.0
sccp
sccp ccm group 1
bind interface Loopback1
associate ccm 1 priority 1
associate profile 2 register confdsp1
associate profile 3 register videodsp1
associate profile 1 register mtpe4d3f19b6600
keepalive retries 5
switchover method immediate
switchback method graceful
switchback interval 30
dspfarm profile 1 transcode
codec ilbc
codec g729abr8
codec g729ar8
codec g711alaw
codec g711ulaw
codec g729r8
codec g729br8
maximum sessions 32
associate application SCCP
telephony-service
sdspfarm units 3
sdspfarm transcode sessions 32
sdspfarm tag 1 mtpe4d3f19b6600
sdspfarm tag 2 confdsp1
sdspfarm tag 3 videodsp1
conference hardware
video
maximum bit-rate 1024
max-ephones 360
max-dn 890
ip source-address 10.177.20.1 port 2000
no caller-id name-only
no service directed-pickup
system message ULAN-ASB-CME
url services http://xmlphones.appspot.com/utf-8/
cnf-file location flash:
cnf-file perphone
time-zone 31
time-format 24
date-format dd-mm-yy
dialplan-pattern 1 .... extension-length 4
max-conferences 32 gain 0
call-forward pattern .T
hunt-group logout HLog
moh "flash:cme/bacd/en_bacd_music_on_hold.au"
multicast moh 239.239.177.1 port 2001
transfer-system full-consult
transfer-pattern .T
directory last-name-first
fac standard
Solved! Go to Solution.
ā04-10-2017 02:35 AM
Cause code 63 is "Service or option not available, or unspecified". Can you try binding SIP to the interface used for communicating with CUCM as below:
voice service voip
sip
bind all source-interface gig0/0
In the above, replace gig0/0 with your corresponding interface
Rajan
Pls rate all useful posts
voice service voip
sip
Rajan
ā04-10-2017 02:50 AM
Hi, Rajan!
Thank you for advice!
I try to place it after working hours, because it's many active sip calls now, and cme returns me "There are active sip calls
The bind command change will not take effect"
I only can bind media, but it has not effect.
ā04-10-2017 02:56 AM
Are you able to dial In from CUCM to CME ?
ā04-10-2017 03:05 AM
Yes, calls from cucm to cme are correct.
ā04-13-2017 04:39 AM
Can you post a "debug ccsip messages" for both the working CUCM -> CME and the non-working CME -> CUCM scenarios ?
