Can't transfer call to an internal line from external line
ahmadhassan
Hi all,
I have an issue when transferring calls coming from an external line to an internal line:
Ex.:
Phone No: 010xxx
The external extension (SIP): 7xxx
Internal Line: 5xxx
When receiving the call on 7xxx can transfer to any external extension but I can't transfer to any internal extension.
CUCM Ver.: 12.5
Thank you in advance
ahmadhassan
The issue has been resolved:
  1. Found out that CSS for 89xx extensions doesn’t include the partition of 32xx extensions.
  2. Added the partition of 32xx to 89xx CSS, which resolved the issue.
Thank you
What really happens when you transfer? Is this behaviour same when transferring calls to all internal extension or its specific with 5533?
Response Signature
For all internal extensions
After dial first digit for any internal number the call drop
ahmadhassan
I try to remove the pattern but the same
ahmadhassan
Thank you
