01-31-2023
02:23 AM
- last edited on
01-31-2023
06:51 AM
by
rupeshah
Hi all,
I have an issue when transferring calls coming from an external line to an internal line:
Ex.:
Phone No: 010xxx
The external extension (SIP): 7xxx
Internal Line: 5xxx
When receiving the call on 7xxx can transfer to any external extension but I can't transfer to any internal extension.
CUCM Ver.: 12.5
Thank you in advance
Solved! Go to Solution.
02-08-2023 11:51 AM - edited 02-08-2023 11:52 AM
The issue has been resolved:
Thank you
01-31-2023 02:32 AM
What really happens when you transfer? Is this behaviour same when transferring calls to all internal extension or its specific with 5533?
01-31-2023 08:15 AM
For all internal extensions
After dial first digit for any internal number the call drop
02-02-2023 01:07 AM - edited 02-02-2023 01:08 AM
I try to remove the pattern but the same
Thank you
